Fwd: A-100 fuses(answer from doepfer)
2003-04-22 by Bakis Sirros
--- Dieter Doepfer <hardware@doepfer.de> wrote: > From: "Dieter Doepfer" <hardware@doepfer.de> > To: "Bakis Sirros" <synth_freak_2000@yahoo.com> > Subject: A-100 fuses > Date: Tue, 22 Apr 2003 17:39:22 +0200 > > Dear Bakis, > > please forward to the group ... > > > We've had this discussion in the past, and there > seems to be a > > difference in opinion as to what type of fuse to > use. In mine (I'm UK > > based) the fuses are marked 'T100mA', which makes > them 'time lag' > > (or 'slo-blo') fuses. The point of them being > time-lag is to ensure > > that they don't blow at the moment of turn on, > when an inevitable > > surge in current occurs. If the replacements you > used were not 'T' > > types, then this may be why they blew immediately. > On the other hand, > > you may of course actually have a problem > somewhere with something > > drawing too much current! However, other list > members have suggested > > using fast blow types as an added precaution. > Probably best to > > contact your local distributor; but come to think > about it, perhaps > > if Dieter is listening in, he can put us straight > once and for all?! > > Yes, he is listening :-) > > 230V systems: 100/125mA or 0.1A/0.125A slow blow or > T100mA/T125mA (German word > for slow blow = traege) > 115V systems: 200/250mA or 0.2A/0.25A slow blow or > T200mA/T250mA > > As the main current for 115V is twice the current > for 230V versions the fuse > value has to be doubled. Normally all 230V systems > are equipped with T100mA and > 115V systems are equipped with T200mA fuses. > > Remark: The wrong fuse (e.g. 100mA instead of 200mA > in a 115V system) may not > blow immediately and a system may work for months or > even years without > problems. E.g. at the NAMM 2001 all systems were > equipped with wrong fuses > (T100mA instead af T200mA). But only the fuses in > systems with headphone modules > (A-139) blew if high A-139 levels were used. All > other systems worked well > during the NAMM even with the wrong fuses. So it > even depens upon the total > current of all modules in the system if the (wrong) > fuse will blow or not. We > recommend all user's of 115V systems to look if 200 > or 250mA fuses are > installed. Obviously some 115V systems with wrong > fuses were shipped as the > failure was not recognized during the final test of > the system. We have sent > 200mA fuses for free to all representatives in "115V > countries". So you can get > a fuse for free with your next module order :-) in > case that have a 115V frame > with a wrong fuse. > > > Dieter Doepfer > ===== synthfreak(parallel worlds) athens-greece [Doepfer_a100] group owner __________________________________________________ Do you Yahoo!? The New Yahoo! Search - Faster. Easier. Bingo http://search.yahoo.com
