Fwd: Second PSU(dieter's answer)
2003-07-31 by Bakis Sirros
--- Dieter Doepfer <hardware@doepfer.de> wrote: > From: "Dieter Doepfer" <hardware@doepfer.de> > To: "Bakis Sirros" <synth_freak_2000@yahoo.com> > Subject: Second PSU > Date: Thu, 31 Jul 2003 13:54:27 +0200 > > > Hi, > > > > when I had the A-129 vocoder (129/1 and 129/2) 650 > mA wasn�t enough for > > my G6 case. I tried to run it with around 700mA, > but then the VCOs were > > quite unstable. So a PSU with like 900mA - 1A > would be nice. > > > > Paul > > One could install another power supply on the second > back panel that is > normally unused (only used if a +5V power supply is > installed). The second > power supply is then used for the upper bus board > and the already existing > power supply for the lower bus board. > > Your module collection is one of the few cases that > the 650 mA PSU is not > sufficient. > > Best regards > Dieter Doepfer > ===== synthfreak(parallel worlds) athens-greece [Doepfer_a100] group owner __________________________________ Do you Yahoo!? Yahoo! SiteBuilder - Free, easy-to-use web site design software http://sitebuilder.yahoo.com
