Doepfer
using guitar pedals with doepfer a100
2005-03-07 by danv_83
what are some good ways to send audio signals out of a100 modules to
guitar pedals and then back into a100 modules?
are the imedances and volumes greatly different, is there some
important impedance matching to be done??
thanks.
Re: [Doepfer_a100] using guitar pedals with doepfer a100
2005-03-07 by Florian Anwander
Hi danv_83
In general there should not be real problems using them with a modular
systems like the A100. They may expect lower signal levels (guitar
pedals are constructed always for the usage with guitars), so you
perhaps should lower the output signal of the last module before the
guitar pedal. You won't destroy the pedals electronic, but maybe they
will distort. Especially distortion/fuzz pedals and compressors will
definitely need lower levels to produce the effect you are expecting,
because the effect itself works depended on the signal level.
I use a Boss DD6, Boss Compressor, Ibanez Tubescreamer and a Ibanez
Flanger; I never had any problems.
Florian
Florian Anwander                  |ConSol
Tel.   +49(89)45841-133           |Consulting&Solutions Software GmbH
Fax    +49(89)45841-111           |Franziskanerstr. 38, D-81669 München
email: florian.anwander@consol.de |http://www.consol.de
