Doepfer
Re: Instead of new module suggestions -> module size
2005-03-07 by selfoscillate
hello florian,
i fully agree.
best wishes
ingo
--- In Doepfer_a100@yahoogroups.com, Florian Anwander
<Florian.Anwander@c...> wrote:
> Hi,
> I received a lot of new modules the last weeks. So I rearranged the
> modules in my system ... and found it quite annoying, that there
are
> again modules with a width of uneven or impairy numbers of HPs. I
really
> would appreciate it, if the modules would have at least a width of
4HPs
> (like A180) and multiples of 4HPs.
> I wouldn't mind if some modules would have more surface space; this
> would make a more user friendly "interface". It would be easier
also to
> add input jacks or switches for optional features, which are given
on
> the pcb already.
> Any oppinions about that? (I know that we would have to buy more
19"
> frames...)
> Florian
Re: [Doepfer_a100] Instead of new module suggestions -> module size
2005-03-07 by Julian
I would strongly dislike module size being standardised.
For me, the beauty of the doepfer system is its size.  If i was wanted the interface bigger i would have gone for one of the 5u
systems.
Anything that makes the synth take up more space is, in my eyes, a very bad idea.
I know blanking pannels may not be the height of fashion, but they do the job for those gaps...
So far as adding stuff goes, its easy enough to fit a blanking pannel next to the modified pannel too, with your additional switches
and jacks on it, isnt it?
My 2 pence worth,
Julian
hello julian,
your point is also valid.
my opinion is that if a module has 14 hp, it
wouldn't be so bad if it had 16 hp.
the 2 hp more size wouldn't hurt too much and the
module would still be a lot smaller than the
5u units.
anyway, i have a bunch of 2 hp blank panels,
so i don't have a problem with gaps.
i was just thinking about other users which
move their modules around a lot.
best wishes
ingo
> systems.
very bad idea.
> My 2 pence worth,
> Julian
2005-03-07 by Florian Anwander
modules in my system ... and found it quite annoying, that there are
again modules with a width of uneven or impairy numbers of HPs. I really
would appreciate it, if the modules would have at least a width of 4HPs
would make a more user friendly "interface". It would be easier also to
add input jacks or switches for optional features, which are given on
the pcb already.
Any oppinions about that? (I know that we would have to buy more 19"
frames...)
Florian
AW: [Doepfer_a100] Instead of new module suggestions -> module size
2005-03-07 by Dieter Doepfer
> Von: Florian Anwander [mailto:Florian.Anwander@consol.de]
> Gesendet: Montag, 7. März 2005 14:01
> Betreff: [Doepfer_a100] Instead of new module suggestions -> module size
> Hi,
There are no A-100 modules with an uneven number of HPs. All A-100 front
panels are a multiple of 2 HP.
Best wishes
Dieter Doepfer
RE: [Doepfer_a100] Re: Instead of new module suggestions -> module size
2005-03-07 by unknown freak
I just as fully disagree.  An extra 2P on any two modules in a row and you
just lost space for a clock divider, sample-and-hold, ring mod, inverter, or
multiple.  Couple that with the price of a G6 and you'll find yourself
spending hundreds of extra dollars/euros for the privilege of a nominally
neater rack.
--Chuck
From: selfoscillate [mailto:synaptic_music@yahoo.com]
Sent: Monday, March 07, 2005 7:56 AM
Subject: [Doepfer_a100] Re: Instead of new module suggestions -> module size
hello florian,
i fully agree.
best wishes
ingo
> Hi,
are
really
4HPs
also to
on
> the pcb already.
19"
> frames...)
> Florian
neater rack.
--Chuck
hello florian,
i fully agree.
best wishes
ingo
> Hi,
are
really
4HPs
also to
on
> the pcb already.
19"
> frames...)
> Florian
Re: AW: [Doepfer_a100] Instead of new module suggestions -> module size
Hi Dieter
Sorry, you're right. I should have corrected this sentence. As I wrote
two sentences later: I meant, the minimum step of panel width should be 4HP.
Florian
btw: There are really a lot of great new modules. I appreciate the A-136
and the A-137; what richness comes to simple single VCO voices!
The Steiner Parker Filter and the SSM2044 Filter are beautiful (the
kicked the CEM3320 Filters out of wonderland...). The Trautonium Filter
is the perfect counterpart to the A-128!  Great job!
2005-03-08 by selfoscillate
A-136
Filter
thats why i can't resist, when new modules come out.
they are so adorable, useful and well-sounding.
and there is no end in sight :-)
best wishes
ingo
