Homebrew PCBs
Yahoo- Etching is getting MUCH better...
2005-09-08 by lcdpublishing
Hi all,
WOW, what a difference a little bit of practice makes and a new
etching tank.  I posted images of my latest attempt in the files
section - root directory.
Process outline...
Designed in PCB Wizard
Printed on Pulsar paper using HP laserjet 6p
Transferred with iron, two 15 second pressings @ 360 degrees F
Etched in ferric Chloride, warm, with air bubbles.
Wiped off toner with Acetone
And that is what you see.  Next up, I will try the tinning process
using solder paste as outlined here about a week or so ago.
I am amazed at how much better these came out compared to my
previous attempts.
The change in transfer was shorter pressing time (was about 90
seconds or more) and perhaps a bit less heat, didn't measure temp
last time.  Also, made sure to re-position iron during pressing so
as to make sure the steam vent hole areas would be re-pressed with a
different part of the iron sole.
I used ferric chloride last time, but in a small tray with gentle
rocking for agitation.  This time, the tank is much larger 1/2
gallon and am using fish tank bubblers for agitation.
Chris
Re: Yahoo- Etching is getting MUCH better...
2005-09-08 by Phil
pretty clean.  Some pinholing and a few trace blooms but very
respectable.  The trace blooms are due to too much pressure, by the
way.  With an iron, it's very very hard to avoid.
I'm suprised that the pulsar process has pinholes.  Guess it's just
toner transfer with pricey paper.
--- In Homebrew_PCBs@yahoogroups.com, "lcdpublishing"
<lcdpublishing@y...> wrote:
> Hi all,
> Process outline...
> previous attempts.
> Chris
I didn't use the pulsar process completely, just the toner transfer
paper.  Their process uses another iron on transfer product, then
you scrub the board with the chemicals - didn't like that idea.
The "Bloom" I think you are referring to is from my touch up on the
toner where I thought I saw some missing spots - my hands are not
steady enough to just dab the spots so it looks kind of nasty.
The pin-holing would probably be much less if I could figure out how
to turn up the density of this particlar laser printer 6P.  I don't
think it is putting down enough toner for a really good job.
> > Hi all,
> > Process outline...
process
> > previous attempts.
temp
so
with a
gentle
> > Chris
Re: Yahoo- Dumb a$$
Well,
I just realized all this back patting I am giving myself for making
some really good boards and come to find out I screwed up big time.  I
mirrored the image for the solder side and I shouldn't have done that,
now everything is backwards.
I think I may still use them if it can put the components on the trace
side, that should "re-reverse" everything.
Live and learn right :-(
RE: [Homebrew_PCBs] Re: Yahoo- Dumb a$$
2005-09-08 by Joaquim Boavida
Welcome to the club!!
Been there done that :(
Joaquim
-----Mensagem original-----
De: lcdpublishing [mailto:lcdpublishing@...]
Enviada: quinta-feira, 8 de Setembro de 2005 18:51
Para: Homebrew_PCBs@yahoogroups.com
Assunto: [Homebrew_PCBs] Re: Yahoo- Dumb a$$
Well,
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBs
If Files or Photos are running short of space, post them here:
http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
Yahoo! Groups Links
Re: Yahoo- Dumb a$$
When are the meetings for this club? :-)
Chris
--- In Homebrew_PCBs@yahoogroups.com, "Joaquim Boavida"
> Joaquim
> De: lcdpublishing [mailto:lcdpublishing@y...]
> Well,
making
time.  I
that,
trace
and Photos:
2005-09-08 by Phil
Yeah, I think they call the second layer "green" or some such.
been there, done that...  Thank God the electrons don't care about
looks, though.  Your pressure is pretty good then.
I use a copier to lay down the toner and even when I crank up the
density I still get pinholing.  It's the nature of the toner process.
 If you look at the transfered toner with a microscope, you can see
that it is still just a bunch of plastic particles.   However, with a
really fast etch, I find pinholing to be much reduced.  That's an
argument for hotter etchant.
I have some ideas to try out to further reduce pinholing - one is to
reflow the toner after it has been transfered.  One idea is use hot
air to melt the toner particles so they flow slightly and fill up the
pinholes.  Another one is to spray a light coating of acetone on the
transfered board.  Not enough to cause runs but enough to disolve the
toner and have it flow together.  I'm not sure where to get a sprayer
with acetone resistant parts, though.
Phil
Re: Yahoo- Dumb a$$
2005-09-08 by Phil
That club is pretty big and meets EVERY day...
It is very easy to fall into that trap.  One way to make sure you get
it right is to put text on copper layers that tells you which way it
should go.  I used to put "stop" on the top layer and know that, if I
can read it on the transfer art, it's wrong.  "Bot" on the bottom
reads correctly.  If I can read it forward on the transfer art, its
wrong.  If my cad package allowed me to I'd put "stop" reversed on the
bottom layer.
if you try to use the other side, keep in mind that you don't have
plated through holes and will need to solder on the side where a trace
comes into a pad.  you can do it for most parts but sockets, relays,
many connectors and radial electrolyics are impossible.  You can even
pry up the plastic pads on pin headers and solder the top side.
By the way, watch out for relays when you make library parts.  All the
relay datasheets seem to have the pinouts shown from the bottom side.
 I had to chuck a board because of that - stupid me for not dry
testing it first.
Phil
> Well,
2005-09-08 by Bob_xyz
<snip>
sprayer
There's a commercial product for doing this. It's called "Laser
Buddy".
http://laserbuddy.com/
Regards, Bob
Re: Yahoo- Dumb a$$
I do have some sockets going on this board, but if I recall
correctly, I can put a shim of wood under the socket which lifts it
up enough to solder it pretty easily (as you can tell from that
comment, I have been down this path befor).  I still have those
shims from the last time so I guess I knew I would do it again :-)
You might be onto something with heating the toner, after transfer,
with a hot air gun.  I suspect it will flow out and turn shiny.  I
too will try that on my next job.
See you at the meeting!
Chris
get
it
if I
> bottom layer.
trace
relays,
even
side.
> testing it first.
> Phil
> > Well,
making
time.  I
that,
trace
Re: Yahoo- Dumb a$$ - SCREAM!
Well,
I guess I won't have to worry about soldering the components on the
trace side of the board. I just spent about 20 minutes drilling the
holes on both circuit boards.  I then went over to fit up some parts
and they hole spacing is off!
To be exact, the whole circuit printout was reduced by 5%, due to a
bug in the software I suspect.  I upgraded right after printing out
the transfers I used.  Arghhhhhhhhh !
Now I can pretty much bet on the next time around the transfers or
etching or tinning won't come out as nice as these two boards.
Arghhhh, scream!!!!!!!!!!
Is there a club for this sort of problems!
Chris
Re: [Homebrew_PCBs] Re: Yahoo- Dumb a$$
2005-09-08 by JanRwl@AOL.COM
In a message dated 9/8/2005 2:54:05 P.M. Central Daylight Time,
lcdpublishing@... writes:
In the end, I BET it will be LESS hassle to simply make  all-NEW boards, and
hang the bad ones on the wall with a (tiny) note:   "IFU"
Re: Yahoo- Dumb a$$
LOL!  IFU, Wait till you read the next message I posted
about "Shrinkage" when printing out those circuits.
I can also add a TFU to the note!
Chris
> lcdpublishing@y... writes:
boards, and
In a message dated 9/8/2005 4:39:04 P.M. Central Daylight Time,
Yes, I did.
All this is "good training," per the cadre at Fort Polk in  1966.  Did you
use a laser-printer?  I have heard (well, READ!) that  some of those printers
become "creative" when asked to print a given size  image.  My INK-JET (not any
good for toner images, of course) does at  least 5% smaller (or was it
larger?) than a specified  size.  But I am an OLD Flatulent with about $1000 worth of
Bishop Graphics  "stick-ons" still in a drawer.  They are most long-past
their "good  until..." dates, but most still work fine, anyway.  One uses an
Xacto-knife  to pick-off the pads and IC patterns, sticks 'em to grid-paper VERY
carefully,  then "wires up" with precision black tape (I have only several 0.05"
to  0.25" widths, though they are (were?) made by DOZENS of widths, and at
least  three colors, both "mylar" and "crepe black."  This was what we OLD GUYS
did before puters could "draw" a PCB for us "on-screen".  Just getting it
photo-printable is the problem.  But the 2X "art" I did could be  photographed
by the "PC House" to make a 1X negative, and the size was  PERFECT.
I realize most of their customers now just bring in a 3½  floppy taped to a
purchase-order, and four-layer with gold and tin-plating is  routine.  But it's
been some years since I did a 100-count order of a PTH  double-side, so I
don't even have a CLUE what-all is done, nowadays!  As  was bragged in that old
spiritual, "Free at last, free at last!  Thank  Gawd-Amighty, we free at
last!"                Jan  Rowland
2005-09-08 by Phil
Hey, thanks for the tip, if hot air doesn't do it (and it sounds like
it might), I'll get a can of that.
What I got a kick out of was the "high resolution in a can" on the
can.  Now really....
> <snip>
> the
> sprayer
> Buddy".
> Regards, Bob
2005-09-09 by John
I'll wager that you are the first person to ever do that, except for me of course.
lcdpublishing <lcdpublishing@...> wrote:
Well,
SPONSORED LINKS
Electrical engineering degree Printed circuit board Electrical engineering Electrical engineering course Electrical engineering graduate school Electrical engineering program
YAHOO! GROUPS LINKS
    Visit your group "Homebrew_PCBs" on the web.
 Homebrew_PCBs-unsubscribe@yahoogroups.com
John
K7SVV
Do You Yahoo!?
http://mail.yahoo.com
2005-09-09 by Stefan Trethan
On Thu, 08 Sep 2005 21:18:33 +0200, lcdpublishing
> Chris
Right here, every day. Don't worry this is apparently a normal feature,
not a mistake on your part.
ST
Re: [Homebrew_PCBs] Re: Yahoo- Etching is getting MUCH better...
With inkjet paper and a fuser i don't have pinholing, but with silicone
paper i get it again, which is kind of a problem and why i don't use it
anymore at the moment. Must try hot air reflow of the toner one day....
ST
2005-09-09 by lcdpublishing
I did look over my traces after removing the toner, no pin holes
that I could see with a loupe.  To make sure i was getting a good
look, I went outside where the sun is shining and looked again, very
good, solid, copper traces.  I don't know for sure if it is because
of the transfer paper I used or the heat gun - flash over of the
toner after transfer.  Either way, three boards, no pin holes which
for this cat is pretty darn exciting!
Chris
--- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan"
process.
see
with a
silicone
use it
day....
> ST
2005-09-09 by Phil
> Chris
That's good to know.  The biggest issue for me with pinholing is on
large areas of resist like ground planes.  I like to minimize the
amount of copper to remove - every area possible on my boards is
ground.  I'm about to crank up a couple of boards so I will try it out.
