Homebrew PCBs
Ferric Chloride and silicone ?
2005-11-07 by lcdpublishing
Last week you all may remember me having a ton of problems getting
toner to stick to some PCB material.  Alan suggested that I pre-etch
the board to see if that would help.  It was tried and seem to improve
the adhesion on the smaller test samples, but not on the larger
boards.
I am wondering if any of you chemically smart folks here can shed some
light on what would happen to silicone when imersed int he ferric
chloride?
This new board material is rather shiny, more so than the previous
material I have bought in the past.  So I suspect that there is some
sort of coating on the boards that is causing me these problems.
Thanks for the input!
Chris
Re: [Homebrew_PCBs] Ferric Chloride and silicone ?
2005-11-07 by Stefan Trethan
On Mon, 07 Nov 2005 22:29:54 +0100, lcdpublishing
> boards.
> chloride?
> Chris
I'm not chemically smart, but silicone sealant is not attaacked by CuCl. I
dunno about silicone oil/grease but i do no think it is cleaned off.
Make sure first it is really the material. Get some old stock and make
100% identical test. I do suspect it might be something else.
ST
Re: Ferric Chloride and silicone ?
Okay, will do some side-by-side comparitive tests.  I don't have
much left of the material I was using, but hopefully there is enough
here that is big enough to do some good comparisons.
Thanks!
Chris
--- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan"
getting
etch
improve
> > boards.
shed some
> > chloride?
previous
some
> > Chris
CuCl. I
off.
make
> ST
2005-11-07 by adicont2
Theoreticaly, silicone sealant is chemically inert. So should no
interact whith no other chemical element. This is the reason for
silicone usings in  medicine.
This is also the reason for bad things. Silicone grease is verry hard
to remouve. If an object is contaminated whith this grease...bad news.
Is allmost imposible to paint it, glue it, or etch it.
Adrian
--- In Homebrew_PCBs@yahoogroups.com, "lcdpublishing"
improve
> boards.
some
> chloride?
> Chris
Hi Adrian,
Thanks for the info. The boards do etch fine, I just can't get toner
to stick to them.  However, I am sure there is something on the boards
making them stay shiny and also there is a good chance they use
something in the mfg process to lubricate the rollers and such while
forming the copper.  However, I would think if they used silicone
during the copper mfg. process, they would have trouble bonding the
copper to the epoxy-glass boards.
WIll report back any further findings...
Thanks again!
Chris
hard
news.
> Adrian
Re: [Homebrew_PCBs] Re: Ferric Chloride and silicone ?
On Mon, 07 Nov 2005 23:51:25 +0100, lcdpublishing
> Hi Adrian,
> Thanks again!
> Chris
Chris,
it makes no sense to coat the PCBs with something that prevents coating
with resist, intentionally or by accident.
The manufacturer could not sell the material so he can not produce it.
If it was coated with some "mystery material" it must have been by
accident later on, or maybe a silly person "preventing corrosion".
In PCB houses the boards are cleaned by motorised scrubbers and water
only, usually, i'm told.
ST
> Adrian
It can not be solved by solvents like acetone?
ST
I don't think so, but not sure. Like someone mentioned last week,
autobody shops have a horrible time dealing with "Fish eyes" in the
paint.  This is caused by silicone "waxes" people apply to their
cars to keep them shiny and new looking.  I know that laquer thinner
doesn't seem to remove it good enough to prevent problems. Don't
know about acetone though, never seen the body shops use acetone.
However, I scrubbed the boards good with acetone prior to
transfering the toner.
Gosh this is frustrating.  What was working so perfectly now works
horridly.  I hope to get some time to focus on this and get to the
bottom of it in the coming weeks.
Also, for what it is worth, I tried many different ink jet papers
(glossy stuff), pages from magazines, toner transfer paper, and the
pulsar transfer paper, and something else of which I can't remember
now.  All yielded nearly identical problems, in other words, none of
them performed better than the other - so now I know I don't have to
buy the expensive papers anymore - just use the glossy papers :-)
CHris
hard
news.
> > Adrian
> ST
Stefan,
By chance do you happen to know what process the board MFGs use to
remove the excess copper? (as in etching boards the way we do to leave
only the traces)
 I am guessing it is a chemical etching of some sort, but have no idea
beyond a guess.
Chris
coating
it.
water
> ST
2005-11-08 by Stefan Trethan
On Tue, 08 Nov 2005 00:12:41 +0100, lcdpublishing
> Stefan,
> only the traces)
> beyond a guess.
> Chris
usually chemical etching. as far as i know mostly sulphuric etchants and
some CuCl, conveyor spraying any maybe bubble tanks in smaller operations
i think.
Most seem to use laminated film resists (as those are tenting THP), or
"inverted" resist and tin plating with sulphuric etchants.
That's what i gathered seems common, not 100% sure. Never seen a
industrial etching shop inside, actually. There are sure ppl here that
have seen some.
ST
2005-11-08 by adicont2
In my knowledge there is no solvent for silicone. Don't ask me how the
manufacturers of silicone products deal whith this problem.
All this products, is made by mixing some aditives and silicone.
Imagine this mysterious silicone like microscopic balls, mixed in some
oil or grease. When you try to remove it, you use acetone. The acetone
wash aditives but not the balls. Some balls, because there is no
aditive to stick them in place, will be removed. Never all.
Your problem is allmost sure not a silicone problem, because you can
etch the PCB. Is a realy weird problem. Maybe is related to copper
quality like thermal or electrostatic proprieties.
Adrian
> CHris
> hard
> news.
> > > Adrian
> > ST
Silicone solvents Re: Ferric Chloride and silicone ?
2005-11-08 by ballendo
Some potentially related info:
 http://www.eng-tips.com/viewthread.cfm?qid=28166
The best advice here IMO is to Ask the mfr.!
Funny how seldom we do that...
Hope this helps,
Ballendo
<snip>
2005-11-08 by JanRwl@AOL.COM
In a message dated 11/7/2005 3:31:57 P.M. Central Standard Time,
lcdpublishing@... writes:
Chris!
If so (I'd have NO clue!), then scrub off all the "shiny" with  grey
Scotchbrite, using liquid soap (like one uses for dishes!) and hot  water.  RINSE
super-well with clean water, dry, and try that.
In a message dated 11/7/2005 5:05:06 P.M. Central Standard Time,
stefan_trethan@... writes:
no
In a message dated 11/7/2005 5:10:13 P.M. Central Standard Time,
it makes  no sense to coat the PCBs with something that prevents coating with
 resist, intentionally or by accident.  The manufacturer could not sell  the
material so he can not produce it.  If it was coated with some  "mystery
material" it must have been by accident later on, or maybe a  silly person
"preventing corrosion".<<
ST!  SURE it makes sense!  An "invisible" goop that  keeps the fresh copper
bright is a "sales tool", of course!  The USERS must  realize this must be
scrubbed off before resist-application!
> with
> the
> person
> copper
> be
But surely, if they put some protection on (and they seem to do on my
boards) it must be something that is easily cleaned off, NOT silicone
grease!
ST
2005-11-09 by JanRwl@AOL.COM
In a message dated 11/8/2005 4:02:27 A.M. Central Standard Time,
grease!
I agree with you, there!
