Homebrew PCBs
Board cleaning trials
2006-02-22 by Wayne Topa
I have followed the suggestions of those more experienced then me in
  precleaning the pcb, and found that I 'must have' been doing
  something wrong.
  My first 2 boards were cleaned using the scotch brite pad and dish
  detergent and failed when I ran the board through the laminator.
  By failed, I mean the toner did not adhere to the board.  I had to
  repeat the cleaning/transfer 3-4 times before I got good adhesion.
  Wasted a lot of TTS paper that way.
  I recently ordered some pcb's from abcfab, and on on the EBay page
  describing the boards, Bill mentioned that there were a number of
  cleaning solutions that would clean the copper, and that the
  scotch brite scrub wasn't necessary.
  One of the cleaners mentioned was Tarn-X.  I went out and bought a
  new bottle (the bottle we had must have been 5-6 years old) and
  tried it on 4 boards last night.  I pre-washed the boards with soap
  and water using a cotton ball, dried with a paper towel then using a
  cotton ball soaked with Tarn-X , simply applied it to the the boards.
  I then washed off the boards with water only and dried them, laminated
  them and after 5-6 passes through the laminator I dropped
  the boards into cold tap water and, in 2-3 minutes, the paper floated
  off and there was no toner on the carrier at all (I use Pulsar TTS)
  and the boards were perfect.  I had a hard time believing it could
  be that easy.
  The boards from abcfab were not tarnished in any way so this may be
  why this worked so well.  Even so I did see a change in the color of
  the copper as I applied the Tarn-X.  I am so pleased with the
  results, I though I better pass it on.
  This Pulsar TTS paper, though somewhat expensive, is a dream to work
  with.  The paper floats off and does not require any work at all.  I
  have tried other medium but it is just too much work getting the
  paper layers off the toner. As I am only making boards for my own
  use, I find the Pulsar TTS is the way to go.  Using the Pulsar, 1
  minute etch method, I can go from printer to finished board in about
  15-20 minutes.
  Good Transferring!
  Wayne
Re: Board cleaning trials
2006-02-22 by protonceksleeperman
That's a good one! I can't find mentioned product here, so i tried
similar stuff - tarnish remover - i found Cillit Bang in local
store, tried on some old copper and it cleaned it perfectly! I will
try transferring tomorrow to see how it works in real life, but for
now thanks for info!
--- In Homebrew_PCBs@yahoogroups.com, Wayne Topa <linuxone@...>
me in
>   something wrong.
dish
to
adhesion.
page
a
soap
using a
boards.
laminated
floated
TTS)
could
>   be that easy.
be
color of
work
all.  I
about
>   15-20 minutes.
>   Good Transferring!
>   Wayne
Re: [Homebrew_PCBs] Re: Board cleaning trials
> Paul
Sorry Paul, I should have mentioned the other cleaners he said would
work.
They are: Zap! and Restore4 (Home Depot?)
He ( Bill abcfab@...) states that
"These cleaners al return the copper to as new condition without
scratching and because they're all basically acids, they deep clean
the copper to get out gunk that may be located just below the surface.
Just be sure to rinse after cleaning and to dry with a clean towel
so you don't leave water spots."
Hope you have as good luck as I did.
Wayne
2006-02-22 by fenrir_co
will
for
> > Paul
Remember that many of these tarnish removal chemicals /also/ leave a
'protective layer' in order to prevent the metal from tarnishing
again. This can prevent adhesion - I'm surprised Tarn-X worked. I
would reccomend wiping down with 91% isporopyl (Wal-mart has this)
with Bounty's 'No Streak Glass Paper Towels', designed not to leave
residue. Some paper towels will leave their own residue - I've found
that Scott white shop rags on a roll leave a mess if used with
acetone.
tried
will
for
> > Paul
would
> work.
surface.
> Wayne
no worries...i think that problem is in the country...i'm in Europe
(slovenia) and so products here are totally different... but, i got
the point ... namely getting some brass-copper-silver cleaner. I'll
just get them a few and test them which one cleans best. They are
still cheaper than paper :-)
2006-02-22 by Leon Heller
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Wednesday, February 22, 2006 7:10 PM
Subject: [Homebrew_PCBs] Re: Board cleaning trials
That very irritating character in the Cillit Bang adverts demonstrates its
cleaning power by dipping a copper coin in the stuff.
Leon
[This E-mail has been scanned for viruses but it is your responsibility
to maintain up to date anti virus software on the device that you are
currently using to read this email. ]
--- In Homebrew_PCBs@yahoogroups.com, "Leon Heller"
<leon.heller@...> wrote:
> From: "protonceksleeperman" <protoncek@...>
tried
will
for
demonstrates its
> Leon
I agree about that character...grrrr....but, i've had a piece of old
board with very oxidized copper and it really work wonders!
It's just as a fenrir said...maybe it's a good idea to clean the
board with alcohol or similar stuff.
2006-02-22 by lists
In article <dtihah+2cnb@...>,
Have you tried Coca-cola? You can yet that pretty well anywhere. It's the
Phosphoric acid content that does the trick!
> will
> for
> > > Paul
> acetone.
I will add a 91% isporopyl to the list for my next board.
Thanks!
Wayne
Sent: Wednesday, February 22, 2006 9:44 PM
Subject: Re: [Homebrew_PCBs] Re: Board cleaning trials
It dissolves tooth enamel, as well!
Leon
2006-02-23 by soffee83
I wonder what a "watered down", wiped on mix of the actual etchants
would do in that regard?
I've also wondered at times, just how much effect the texture of the
surface plays with the toner adhesion (ie: steel wool vs. emery cloth,
etc.)
Take Care
George
2006-02-23 by wbblair3
Don't ask me how I discovered this (I don't remember), but the
commonly available (in the US anyway) "Scrub Free" soap scum remover
intended for cleaning bathroom showers, tubs and sinks cleans copper
even better than Tarn-X, is less expensive and might be something you
already have around the house (it DOES work great on soap scum, too).
 It's in one of those pump spray containers.  Its active ingredient is
the same one used in Tarn-X, sulfamic acid:
http://householdproducts.nlm.nih.gov/cgi-bin/household/brands?tbl=chem&id=11&query=sulfamic
Strange that it's not listed on the above NIH list since it does
contain sulfamic acid according to the label. For some reason, it
cleans copper more evenly than Tarn-X (I have a bottle of Tarn-X that
I don't use any more) and just as easily (sounds like I work for
them... but I don't). I spray a good amount over the board and then
swirl it around with a paper towel.  After the copper is bright
(doesn't take long), I rinse the board with tap water, dry it and do a
final cleaning using 91% IPA.  Other products that claim to be "scrub
free" tub and sink cleaners might also contain sulfamic acid, but I
haven't checked.
WB
2006-02-23 by Leon Heller
Sent: Thursday, February 23, 2006 3:02 AM
> etc.)
The usual test for cleanliness is to see if water wets the surface properly.
When I used to use TT I rubbed the copper with a special block of rubbery
abrasive compound. I've still got it and use it for cleaning PCB material
before prototyping RF circuits using 'ugly' construction.
Leon
2006-02-23 by Richard
fwiw, here is the cleaning procedure that I have used
successfully
for over 20 years...
1)  Scrub board with the scour-side of 3M kitchen-sponge and
liquid dish-detergent.  Can't recall the 'grade' name of the
sponge
(they make 3), but it's the agressive one....has a 'scratchy'
feeling.
This step removes oils, greases, and debris.  Important first
step.
2)  Microetch board for 15-60 seconds in a weak solution of
sodium persulphate....or a weak sulfuric-peroxide solution works
very good also.
Ferric Chloride is not really suitable for this task.  By using
clear-solution etchants, one can see the color of the copper
change before your eyes; from the typical "orange" look, to the
true reddish color of 100% pure clean non-oxidized copper.
It happens in just a few seconds.  I generally swish the board
around a bit in a little plastic tray while watching it.
When it's obvious that the whole surface has been microetched
to pure reddish copper; I rinse, blow dry with an air-gun (100psi
from compressor tank), and take it right to the laminator for
applying dry-film resist.
I.e., don't let it sit around for 3 days and oxidize again.
I would think that this clean-then-microetch procedure would
work equally well for toner-transfer processes.  The microetch
-guarantees- a clean surface because it makes the old surface
go away!  <grin>
Please do NOT add or "subscribe" my name to ANY lists/databases.
2006-02-23 by Stefan Trethan
Just make sure it is oil-free air ;-)
I haven't found the microetch necessary for 100% reliable transfers, but
it sure is a way to exclude cleaning errors if you have trouble.
ST
2006-02-23 by bob_ledoux
I've had 100% success with this process even with very tarnished boards:
1, Clean with Tarn-X
2. Scrub, both directions,under water, with 400 grit wet or dry paper.
3. Dry with cotton cloth (diaper).
4. Wipe with cotton swab damp with lacquer thinner.
5. Dry with cotton cloth (diaper).
6.  Apply toner transfer paper.
>   something wrong.
laminated
>   be that easy.
>   15-20 minutes.
>   Good Transferring!
>   Wayne
2006-02-23 by Mike Phillips
Wyane,
I've been dying to try a copper cleaner like you did. It's sounds like
a great solution. Thanks for reporting the results.
Mike
>   something wrong.
laminated
>   be that easy.
>   15-20 minutes.
>   Good Transferring!
>   Wayne
2006-02-23 by Wayne Topa
Just found that we had 2 Scrub Free cleaners under the sink.  Neither
has sulfamic acid listed on the label, Tilex and one called Scrub
Free.
Took a 6" x 18" copper clad blank that had some blemishes and tried
each of the scrub free cleaners in a 4x6" strip.  Both did show a
change in the color of the copper but neither took out the blemishes.
Washed off the board and dried it, then tried Tarn-X.  That fully
cleaned the board and no blemishes remain.
I think the Tarn-X cost around $5.  The label says to use rubber
gloves (the scum cleaners don't) so for my money, I will stick to the
Tarn-X.  There should be enough in the bottle to last me for many many
boards.  Maybe if I could find a Scum Cleaner that 'does' list
sulfamic acid on the label it would work better then those that don't,
but Tarn-X is working so I'm happy.
I do wonder if the other 2 cleaners that Bill mentioned, Zap! and
Restore4, might be better but so far, I have not been able to find
them.
Thanks for the tip WB.  It might help those overseas that don't have a
source for Tarn-X or the others.
Wayne
2006-02-23 by lists
In article <000a01c63808$ed0c2dd0$0301a8c0@AZATHOTH>,
> > the Phosphoric acid content that does the trick!
I know, that's why I rarely touch the stuff :-)
2006-02-23 by klmjr22
> Free.
> them.
> Wayne
I looked at the Household products database and found tarn-x is 3-5
sulfamic acid but also contains Thiourea which may help cleaning.I
found that Lime Away has < 11 percent sulfamic acid acording to the
MSDS sheet. Tried some on some BAD copper and all the dark brown areas
turned that nice reddish color you want. The black and green areas
appeared to clean up with some scrubbing. This stuff is readily
available. Assuming the sulfamic acid is what you want there is a
product called Aqua Mix Sulfamic Acid Crystals available at Lowes that
is a 99.5 percent pure sulfamic acid crystals. Don't know what it
costs yet. But Lime Away does work and it doesn't have a lot of exta
stuff in it you may not want.
Keith
On Thu, 23 Feb 2006 21:56:23 +0100, klmjr22 <keithlmartin@...>
and may get you a nice cancer too for all your troubles...
ST
> > Free.
> > them.
> > Wayne
> Keith
Way to go Keith!
Lime Away would seem to be something to try.  "Aqua Mix Sulfamic Acid
Crystals" would seem, to me, to be a bit of overkill.  I'd have to get
a rubber suit as well as boots & gloves.  :-)
I'll get some lile away tomorrow and give it a ahot.
Thanks again!
Wayne
2006-02-24 by Bill Maxwell
Anybody tried Coca Cola?  we used to clean the old aussie pennies with it
and they had a reasonably high copper content.
Bill
Sent: Friday, February 24, 2006 7:56 AM
>> Free.
>> them.
>> Wayne
> Keith
> Be sure to visit the group home and check for new Links, Files, and
> Photos:
> http://groups.yahoo.com/group/Homebrew_PCBs
> If Files or Photos are running short of space, post them here:
> http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
2006-02-24 by Leon Heller
Sent: Friday, February 24, 2006 11:26 AM
HP Sauce works quite well, also. I can remember someone who sold a quack
medecine for many years in Shepherds Bush Market, West London, who used to
demonstrate the effect HP Sauce would have on one's innards by cleaning
pennies with the stuff. I suppose it was the vinegar that did the cleaning.
He wore a hearing aid when he got older, I always wondered why his
miraculous liquid didn't cure his deafness, he claimed it cured everything
else. 8-)
That was about 50 years ago, BTW. He'd get into trouble for that sort of
thing these days.
Leon
2006-02-24 by alan00463
No need to buy a fancy cleaner.    I used to clean pennies in a
mixture of vinegar and salt.    The proportions make little
difference.   The solution strips off all the copper oxide almost
instantly.    Any kind of vinegar.   Of course, you'll have to rinse
the board in water right after doing this.
Alan
2006-02-24 by Stefan Trethan
> Alan
Ok, what i don't get here, why are you cleaning pennies? I mean, it
doesn't really matter if they are dirty when you spend them, right?
What am i missing here?
ST
2006-02-24 by lcdpublishing
Could be a collector of historical pennies?
--- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan"
rinse
> > Alan
it
> ST
Sent: Friday, February 24, 2006 4:07 PM
That's probably why HP Sauce works so well, the ingredients include vinegar
and salt. 8-)
Leon
Sent: Friday, February 24, 2006 4:59 PM
>> Alan
It's the sort of thing I used to do when I was about 10 years old. At school
we used to rub them with mercury to make them look like half-crowns - 25 x
as much. We got a bus conductor to take one, once. We told him what we'd
done before he gave us our change, he was rather angry.
Leon
2006-02-24 by wbblair3
> Keith
That NIH link:
is pretty useful (for those in the US anyway since the brands listed
are US brands) when one wants to find a substitute for a product once
the active ingredient is known.  Thanks for actually taking the time
to go to it.  As I mentioned in my previous message, I found it
strange that Scrub Free wasn't listed with the other products in the
sulfamic acid listing.  Perhaps they've changed the formulation
considering that they apparently don't list sulfamic acid on the label
any more.  Too bad, since the stuff I have cleans PCBs quickly, evenly
and effortlessly but the bottle has only about 1/3 of its contents
remaining.  BTW, I used to use Lime Away for soap scum removal, but
moved to Scrub Free because it smelled better!  Now I may have to go
back to Lime Away because it cleans PCBs better than the "new, not so
improved (for PCB cleaning)" Scrub Free. I'll have to check out the
labels on the even cheaper generic house brands to see if they contain
sulfamic acid.
WB
> Keith
I looked on the Lowes.com web page, but didn't find the Aqua Mix
Sulfamic Acid Crystals.  I called my local store and they didn't have
them either.  I did find an online source:
http://www.artistictile.net/store/aquamix.html
$5.85 for 1 lb (makes 2.5 gallons) plus whatever postage they charge.
 I'll be taking a look at the premixed Aqua Mix and other tile & grout
cleaning products at Lowes and elsewhere and looking for the crystals
just for the heck of it since Lime Away (and possibly generic
versions) will apparently do the job and can be found easily (in the
US anyway).
WB
