Ferric Chloride - muck at bottom of tank question
2006-05-06 by lcdpublishing
Hi guys, I use Ferric Chloride for my etchant, I know there is "neater" stuff out there, but this works okay for me - plus I have a couple more bags of the stuff to use up. I have a couple questions regarding useage of it... 1) I don't know why I started doing this, but, before etching a board, I stir up all the muck at the bottom of the tank. Then I drop in my bubble rock and etch my boards. Is the mucky stuff at the bottom the Ferric Chloride crystals or is it just useless muck? If I don't have to stir it up before use - that would save me a bit of messy work. 2) I have lost count of how many boards I have etched with the batch I am using right now. If I were to guess, I would have to say probably in the area of 20-25 8" x 10" boards. Most of those board were single sided and all copper removed except for the traces and pads. It currently takes about 20~25 minutes to etch a board with the chemicals at around 68 degrees F. To be honest, I have no idea how long it took when I first mixed up the batch :-) So, I am just trying to get a feel for the "Status" of this batch as to whether it's time to dump it or keep using it? 3) I know that for some chemical etchants, you use heaters to speed up the process. I recall someone telling me not to use a heater with Ferric Chloride so I never did. However, I did buy a fish tank heater, but never used it. I don't mind waiting 20 minutes to etch a board if it is safer than doing it faster with the heater. If a heater is okay to use with this stuff, at what temperature should I shoot for? (SAFELY!) Thanks guys! Chris
