Homebrew PCBs
PCB vs stripboard/veroboard
2007-02-01 by David McNab
After getting a 'knack' for home PCB imaging/etching, I thought my
veroboard/stripboard days were well over. Especially since I've always
laid out veroboard circuits by hand 'as I go', which has been a tad
stressful.
However, an idle search turned up an excellent page on using Eagle (or
similar PCB CAD programs) for veroboard design:
http://www.geocities.com/mike_aus_us/micros/projects/Stripboard_EAGLE/Stripboard_EAGLE.htm?200722
I tried it out with a board I'm currently working on - a universal
development/debugging/programming board for PIC12F675 MCU.
Since I don't have CNC drilling at the moment (still waiting for my mech
eng to get his act together), the PCB version of the layout had 76 holes
to drill, plus 4 topside wires.
In comparison, the veroboard version had zero holes to drill, 36 track
cuts and 12 topside wires.
Result is that for this simple board, the veroboard version took way
less time and effort than etching/drilling a comparable PCB version.
I completed the track-cutting and overhead wire soldering in much less
time than it would have taken to image and etch a bare board, let alone
drill the board after etching.
Something else that made the veroboard construction easier is being able
to print out the layout onto paper and glue it onto the veroboard. This
saved a wad of time with finding the correct places to cut tracks and
solder topside wires. Another time saver was using a handheld rotary
tool with a fine tapered diamond bit for the track cutting. And a third
time-saver was using tricks from the above URL for using Eagle's board
editor for veroboard layout.
My conclusion is that veroboard is vastly easier/quicker overall for
1-off or 2-off boards, provided that:
 * one doesn't have CNC drilling
 * component density requirements are not extreme
 * all components are through-hole, no SMDs
 * board is not intended for larger scale production
 * most/all components have multiple of 100mil pin pitch (or can be bent
   to fit), and have <= .9mm drill holes
Cheers
David
Re: PCB vs stripboard/veroboard
2007-02-01 by jcarlosmor
--- In Homebrew_PCBs@yahoogroups.com, David McNab <rebirth@...> wrote:
> Hi,
always
> stressful.
(or
mech
holes
track
less
alone
able
This
and
third
board
bent
> Cheers
> David
Hi David,
Maybe for a very simple board it is true, but for a medium/advanced
PCB home maker it is faster to build a PCB than to cut traces and do
the veroboard layout. In fact you are stating the reverse of your
points, because mostly this days,
* component density requirements are becoming extreme
* generally the best and fancy components only are SMD
* same reasons for the pitch
Regarding the lack of a CNC machine I am sure as said above that it
is more faster and less stressing to drill by hand dozens of holes
than to plan the veroboard layout and cutting the traces. Maybe the
Eagle utility that you mention could be useful for using as a "do-and-
forget-what-is-happening" in the board, but most of the times the
simple implementation of parallel copper tracks with jumpers simply
does not work (RF, noise, ground loops, etc.)
I would encourage you to do some PCB experimenting. I am sure that
when you gained some minimal experiencie you will enjoy it and maybe
you could say goodbye forever to your veroboards.
Good luck.
Re: [Homebrew_PCBs] Re: PCB vs stripboard/veroboard
For complex circuits needing to fit into tight enclosures, yes. But
certainly not for my simple PIC12F675 programming/development board.
Of course I'd go the PCB route if I was using SMD-only parts.
Ditto
Believe me, it was faster and less stressing for me to cut 36 tracks
than to hand-drill 78 holes. I've done both. The cutting takes only one
second per track with a rotary hand tool with tapered diamond bit.
>  Maybe the
Well, it's useful as a 'do and *know* what is happening' layout tool.
Not a problem with simple circuits.
I've been doing plenty.
>  I am sure that
I've been doing PCBs on and off for 2 years - simple to intermediate
single-layer boards.
With the setup I'm using, I know how long it takes to create a PCB of a
given level of complexity. I made the original post because using the
info about Eagle and stripboard, I was able to get the same board built
and working on stripboard in less than half the time.
Cheers
David
