Expansion of pcb when heated for TT
2007-02-01 by Lez
Ok I am seeing the same problem with this 'working' paper as my other papers, and now I'm on a laminator, not an iron.... My problem is when I heat the paper/toner onto the board, all looks fine, as the board cools, the paper 'bubbles' up in some areas. This is more noticeable on larger (say 6*5inch) boards than smaller, say 3*3, on the smaller sizes, the paper sometimes just 'pops' or lifts off. Am I the only one suffering this? It cant be too much heat, the new laminator is so 'warm' its not melting the toner properly, but I still see the expansion. I'm on a thick (1.6mm?) fibreglass board I thought it was my water was too cold and was a 'shock' to the board, but just letting it air-cool is causing it also. -- Lez
