> Ok, then mine(Dremel Drill) is maybe 12-15 yrs old and the foot pedal
> is even older. I guess I just got lucky.
> --- In Homebrew_PCBs@yahoogroups.com, "crankorgan" <john@> wrote:
> > A Dremel MultiPro has a speed control built in. It will not run
> > off some speed control units unless you put a small lightbulb across
> > the Dremel. Older Dremel models will work with a second speed
> > controller. I use a 6 watt candelabra bulb inside my computer
> > controlled speed unit.
> > --- In Homebrew_PCBs@yahoogroups.com, "izzo47" <izzo47@> wrote:
> > > If you want to make your drill a real varible speed drill try
> this.
> > > Get you hand on a table model sewing machine foot padel. This way
> you
> > > can bring the drill bit to the place where you want to make the
> hole
> > > then lightly press ...you won't slide off so much this way. Your
> drill
> > > is a 0 - whatever rpms now, works great with my Dremil.
> > > izzo
