Homebrew PCBs
HP PCL programming language?
2007-04-10 by lcdpublishing
Hi guys,
I am working on another idea - still pretty rough at the moment.  If
things are the same as they were years back, all HP laser printers
using their PCL language.  I used to have some documentation on that
but have since lost it many years ago.  I am wondering if anyone has
a link to any such documentation?
What I am working on is a way to take the PCL output for a printed
PCB and use that information to control "something" to apply a
resist to the PCB material.  In other words, print to a file using a
laser printer driver. Then I would use that information to control
the "Something" that would apply the resist of some sort.
It's a bit of a hair brained idea at the moment, but might be worth
looking into further.
Thanks
Chris
Re: HP PCL programming language?
2007-04-10 by docstein99
I have found the PCL language reference attached with old printer
manuals.  I have seen them on the internet before, probably in the HP
7445 or 7550 plotter manuals.
But if your using a laser printer, it simply prints what you print in
windows - if you print a circuit board pattern thats what prints out.
If you modify the laserjet in any way - and if whatever your doing
works, it will rastorize just as it normally does using the windows
printer driver without having to learn the PCL programming language.
Re: [Homebrew_PCBs] HP PCL programming language?
2007-04-10 by Richard Holbert
lcdpublishing wrote:
> Hi guys,
> Thanks
> Chris
> http://groups.yahoo.com/group/Homebrew_PCBs
> If Files or Photos are running short of space, post them here:
> http://groups.yahoo.com/group/Homebrew_PCBs_Archives/
Postscript might be easier to work with.
Rick
2007-04-10 by scratch_6057
--- In Homebrew_PCBs@yahoogroups.com, Richard Holbert <rholbert@...>
> > Hi guys,
If
printers
that
has
printed
using a
control
worth
> > Thanks
> > Chris
and Photos:
> > Yahoo! Groups Links
> Rick
If anyone wants to investigate the postscript options
Don  Lancaster's Guru's Lair has information in the
Flutterwumper Library at (http://www.tinaja.com/flut01.asp)
Newbie questions
2007-04-10 by jusdebra
I'm a Marine Biologist that needs a non fishy hobby.  I've always been interested in electronics and I've been reading and experimenting for a few months.  I'm staying with low voltage DC stuff for now, mostly LED's.  (I tried an AC nightlight circuit and discovered the hard way that the decimal point on the 200v cap was a speck of dirt.  Did you know those things will explode?)
  I have some ideas for LED wall displays but want to make a circuit board instead of all that hookup wire.
  I've read quite a bit but just wonder what is the best way to start.  There seems to be some disagreement on chemicals, making transfers and all that stuff.  Is there a basic setup I can use?  Where is the best place to buy supplies? I currently have a laser printer and rubber gloves.
  That's a good start, huh? :)
  debra
  florida
 Get your own web address.
 Have a HUGE year through Yahoo! Small Business.
Re: [Homebrew_PCBs] Newbie questions
2007-04-11 by DJ Delorie
Assuming you want to use the laser printer (and not an inkjet or other
print/etch technologies), there seem to be two basic techniques.
First, toner transfer.  Easiest way to get started (if you don't mind
spending a little for equipment) is to get Pulsar's starter kit, which
includes a laminator, the water-release paper, sealer foil, some PCBs,
and maybe even the solvent (requires hazmat shipping).
Second is photomask.  You buy pre-sensitized boards, print to a
transparency, and use UV light (or sunlight) to expose the mask.
You'll need some chemicals to develop the mask, and a mini-darkroom.
For both of these, you'll need etching chemicals too.  One choice is
FeCl, which you can buy at your local Radio Shack.  The other is a
H2O2/HCl mix, the parts for which you may be able to buy at a pool
supply shop.
2007-04-11 by Leon
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Wednesday, April 11, 2007 4:26 AM
Subject: Re: [Homebrew_PCBs] Newbie questions
You don't need a darkroom, standard positive resist isn't affected by
daylight or artificial lighting during the process provided that it is
developed soon after exposure.
Leon
Leon Heller
Amateur radio call-sign G1HSM
Yaesu FT-817ND and FT-857D transceivers
Suzuki SV1000S motorcycle
leon355@...
http://www.geocities.com/leon_heller
"Leon" <leon355@...> writes:
Are the chemicals rather tame these days too?  I wouldn't mind tring
out photoetch, but I'm not a big fan of having lots of chemicals in
the house.
2007-04-11 by Russell Shaw
Dilute Na2CO3 (from pool shop), and dilute NaOH.
> the house.
Then stop eating and cleaning;)
2007-04-11 by Leon
Sent: Wednesday, April 11, 2007 2:09 PM
> the house.
Dilute sodium hydroxide solution (about 10g/litre) is what I use.
Leon
Russell Shaw <rjshaw@...> writes:
But are they tame?  I mean, do they outgas during use, do I need vent
fans, special cleanup rules, etc?  FeCl is messy, but not "dangerous"
that way, and it doesn't go bad if I don't use it for a while.
> > I wouldn't mind trying out photoetch, but I'm not a big fan of
> > having lots of chemicals in the house.
That reminds me, I still have some sulfuric acid kicking around from
many years ago.  Is that at all useful in pcb making?
Re: Newbie questions
2007-04-11 by derekhawkins
Yep, you'll keel over on the first whiff.
2007-04-11 by Leon
Sent: Wednesday, April 11, 2007 4:46 PM
No, they don't generate any gas. Keep it away from your eyes and don't get
it on your skin. Oven cleaner is mostly NaOH, and it's used in dishwasher
tablets.
Not really. HCl can be useful for etching.
Leon
2007-04-11 by Dave Miller
> --- In Homebrew_PCBs@yahoogroups.com, DJ Delorie <dj@> wrote:
Check out the developing and striping solutions you can mix up on Think
and Tinker's website:
http://thinktink.com/stack/volumes/voliii/consumbl/devmix.htm
The Soda Ash mentioned is the same as Washing Soda (sodium carbonate
monohydrate) that can be picked up in your local grocery store in the
laundry section, it is a common soap used to clean clothes and fairly
beign.
The Sodium Hydoxide is of course Lye, which is often found in the drain
cleaner section (you want pure Sodium Hydoxide, not mixed with any
thing else). Lye is more damaging and should be treated with
appropriate care. (Gloves, safety glasses, plenty of ventalation, plus
always add the lie to the water, not the other way around).
They also give you the concentrations normally used to develop and
strip the the boards.
10% Na2CO3 is used for negative developer and doesn't gas, even
when i heat it to 25-30degC in the microwave.
10% NaOH is used for negative resist stripping and doesn't gas, even
when i heat it to 80degC in the microwave.
I can't recall it being useful for any pcb stuff. It might be useful
for electroplating.
Re: [Homebrew_PCBs] Re: Newbie questions
"Dave Miller" <dmiller45@...> writes:
Hmm... I wonder if the supermarket carries "DOT Class 8 Corrosive"
stickers :-P
2007-04-11 by jusdebra
OMG, my dad is a Dave Miller.  Almost freaked me out when I saw it.  I was thinking, "Is he in this group?"
  Anyway, you guys have me confused again.  Some recommend acid and some alkali.  I've worked with both in some very strong concentrations and know how to handle them.  I have a $300 respirator with O2 feed and lots of gloves.  My biggest question is the type of paper you use in the printer so you can get a transfer.  Where do you get it?  Also a good source for blank boards (single side to start with).  What about software?  Is there a freeware that works good for simple layouts?  Is there a standard commercial package that everyone uses or is the most popular.  I've read about Eagle????
  I've done some layouts by hand with a felt tip pen, but it's time consuming and difficult to edit.
  Thanks again,
  debra miller
beign.
Yahoo! Groups Links
No need to miss a message. Get email on-the-go
with Yahoo! Mail for Mobile. Get started.
2007-04-11 by Leon
Sent: Wednesday, April 11, 2007 9:17 PM
Subject: Re: [Homebrew_PCBs] Re: Newbie questions
> about Eagle????
We were discussing the photo etch process, not toner transfer. NaOH solution
is for developing the resist after UV exposure.
Everyone uses different software. I use Pulsonix which is excellent but
rather expensive. A free version of Eagle is available that will do small
boards, but it isn't an easy program to use. Then there is PCB (completely
free) which is usually run under Linux. KiCAD is another free program.
Leon
2007-04-11 by Stefan Trethan
There is an etchant made from sulphuric acid and H2O2 much like CuCl (only
of course copper sulphate). Sulphuric acid would have some neat qualities
compared to HCl, but there was some catch making it unsuitable for me,
which sadly i do not remember. But it is used industrially in some cases.
ST
2007-04-11 by Myc Holmes
Take a look at Diptrace. It's much easier to learn than EAGLE and the free
version does not limit board size. The limit is 250 pins in a desgn.
Works well for me wth toner transfer.
Myc
2007-04-11 by Len Warner
Newbies should also note that in this group we are
often a bit hit-and-miss, sometimes going on slapdash,
in our reagent concentrations...
>laundry section [snip]
Not the first time that kind of thing has been posted here.
Better read this too ;-)
http://www.pburch.net/dyeing/FAQ/sodaash.shtml
"FAQ: What is soda ash, and what's it used for in dyeing?"
 > Hydration
 > Some forms of soda ash (e.g. that labeled as 'washing soda')
 > contain more water molecules than others, which makes them
 > weigh more and be larger for a given number of sodium carbonate
 > molecules - this means that you need to measure out a larger
 > quantity of the hydrated form in order to get the same results.
 > If you buy sodium carbonate without the extra water molecules,
 > then store it for several years in humid conditions, it will absorb
 > the water and appear to lose strength, when in fact it has merely
 > 'bulked up' and needs to be used in larger volumes.
 > The type of sodium carbonate used in washing soda is a decahydrate,
 > so you need to use almost three times as much washing soda as
 > you would anhydrous soda ash - assuming that you are able to find
 > washing soda that is suitable for use in dyeing, which may be
 > difficult in the US.
Molecular Weight Calculator should make it easier:
http://www.lmnoeng.com/molecule.htm
(enter the number of atoms of each element)
Molecular Weight (g/mole):
180.1528   10H2O
105.98844  Na2CO3
286.14124  Na2CO3.10H2O
286.14124 / 105.98844 = 2.6997
So you need 2.7 times as much of those nice glassy
washing soda crystals than of the anhydrous soda ash.
Regards, LenW
It is more hazardous in handling than hydrochloric acid:
because it not volatile - so un-neutralized splashes get
more concentrated as they dry, rather than evaporating;
and also, diluting concentrated sulphuric acid is highly
exothermic. (Always add acid to water, not water to acid.)
Conc. sulphuric (98%) is more concentrated than conc.
hydrochloric which is limited to around 40%.
Of other grades, "battery acid" at 33.5% is close to
commercial HCl "muriatic acid" strength.
You may find sulphuric acid sales are more tightly
controlled than hydrochloric acid, since it can be used
to make nitric acid and explosives.
Regards, LenW
2007-04-12 by Russell Shaw
Leon wrote:
> From: "jusdebra" <pookie_debra@...>
>> about Eagle????
I use 10% Na2CO3 sodium carbonate for the developing. Unlike NaOH,
it's much less reactive to skin.
2007-04-12 by Andrew
> the developing. Unlike NaOH, it's much
Does anyone use sodium silcate?
I beleive that is what is in the little
packets I get from computronics.
2007-04-12 by Adam Seychell
Positive resists use a much stronger alkaline developer, like 1% NaOH or
Na2SO3. Negative dryfilm resist require a much gentler alkaline like 1%
Na2CO3. I gave up on positive resists years ago, but been told silicate
is much easer to use than the hydroxide.
Russell Shaw wrote:
> Leon wrote:
>> ----- Original Message -----
>>> about Eagle????
Correction: It was 1% Na2CO3 sodium carbonate i use for negative resist.
> a much gentler alkaline like 1% Na2CO3.
> ago, but been told silicate is much
OK - so the stuff I buy from them is
just Na2CO3.  Will give some stuff from
the super market a try then.
2007-04-12 by Leon
Sent: Thursday, April 12, 2007 6:26 AM
It's actually sodium metasilicate. It has a lot more latitude than NaOH. I
prefer NaOH because it's a lot cheaper and I can buy it from a local
hardware shop.
Leon
2007-04-12 by pgdion1
Laser Printer & gloves is a great start
I do both Toner transfer and the photo method (as discussed here ... I
do the positive process as it is a little easier and the results are
still excellent). Although the photo method makes the best boards, I
do TT 90% of the time because it's very quick and easy and the boards
turn out pretty good (especially for projects like your descriping ...
anything through hole and larger SMD is a breeze ... I stick with the
larger SMD as it eliminates all the drilling).
For TT, I use Hammermill paper which can be bought from Sam's Club
online (among others).  My paper is:
 	 Hammermill OfficeOne Glossy Paper  #229030
I also think this would work good (but haven't tried it):
 	 Hammermill Color Laser Gloss Paper  #292253
Steve Trethan (forgive the name butchering) has a good paper too from
staples. It's also an office type business gloss (basically a cheap
glossy paper).
For layout I use Dip Trace.  The free demo version is quite capable
and full versions are not all that expesive either. I've been using it
a lot and really like it (and as I come from OrCAD, that says a lot).
http://www.diptrace.com/
OrCad also has a free demo version and their software is top notch but
the pcb layout in the demo is very limitted. DipTrace is much more
generous on design size.
I lay out the board with DipTrace, mirror the image (in DipTrace) for
the top layer (mirror top layer only if doing 2 sides), and print it
on the hammermill paper. To save sheets, you can cut them in half and
send half sheets through the printers single sheet slot. (you do know
this group is notoriously cheap right?)
Clean the board, I use dawn soap and a scotch-brite pad
Then I place the image on the board and iron the be-jeepers out of it
(iron on high, I iron fairly frim for 2 to 3 minutes depending on the
board size ... move the iron slowly over the board , push down between
movements but ease up a little when moving it so the traces don't smudge).
soak and peel (5 minutes of soak and then start rubbing the paper off
I etch in Ferric Chloride as the toner is very resistant to it.
I also etched a couple in Muratic Acid. It worked well and was fast
but the boards need to come out right away or the acid starts to eat
under the toner and lifts it off. And there are the nasty fumes too.
Works good though (50/50 Muratic acid from Menards and Hydrogen
Peroxide from the drugstore as both are already diluted)
For blank boards I shop Jameco (www.jameco.com) and Digi-Key.
Digi-Key has a larger selection and actually very good prices on their
stock.
Radio Shack used to sell pcb stock too although the boards aren't as
good (I like FR-4, I'm not sure if they carry that). Good place to get
something quick though.
- phil
KA0HBG
2007-04-12 by Dale Chatham
Or, grocery store (Drano).
> hardware shop.
> Leon
2007-04-12 by Leon
Sent: Thursday, April 12, 2007 3:03 PM
We don't have Drano here in the UK. We have something called Mr Muscle Drain
Cleaner, but that contains lots of other stuff as well.
Leon
2007-04-12 by Dave Miller
> stickers :-P
If it was a new product being introduced today they would probably have
to label it as hazardus, and may not be able to introduce it at all,
however, it has been arround for much greater than I care to think
about, so it is probubly grandfathered under some rule or other!
> Snip <
Your Dad would probably be one of the first to agree with me that Dave
Miller is a fairly common name. There are 3 of us in the company I
currently work for and we constantly get each other's e-mail, in a
previous company, there were two of us in the same department, it
caused confusion to say the least!
2007-04-12 by Stefan Trethan
> glossy paper).
Mine's not from staples (since we don't have them here, although they are
in Germany already...).
But glossy inkjet is a good start, matte clay coated papers are very
likely to work, but gloss gives me no pinholes and better resolution, so
it is worth the effort to find the right one.
ST
Will it really concentrate? Sulphuric acid is very hygroscopic, should it
not absorb moisture from the air?
But this was not the catch making it unsuitable for me, that much i
remember.
ST
2007-04-12 by jusdebra
Thanks Phil (and others),
  I think I'm ready to mess up my first board.  My dad and I built a plastic tray and he used a propeller with shaft to provide agitation.  I don't know what it's made of, some kind of polyethylene or plastic and I think the etching solution we use will be determined by what doesn't melt the little propeller. LOL  He was going to do air, but was afraid the bubbles would stick to the board in the wrong places.
  I'll order some stuff in the next couple days and draw a small circuit to sacrifice in the first try.  I;'ll let you know.
  You guys are great.  I wouldn't attempt this without your help.
  OK, I probably would, but I will find success sooner with your help.  How's that?
  debra
glossy paper).
stock.
- phil
KA0HBG
Yahoo! Groups Links
Never miss an email again!
Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out.
I know it's common, so is my name.  I was going to change it to, Juanshettia Adafolarin, but chickend out.
  debra
  (The Dave Miller's that I know are GREAT guys!)
> Snip <
Yahoo! Groups Links
Ahhh...imagining that irresistible "new car" smell?
 Check outnew cars at Yahoo! Autos.
2007-04-12 by Leon
Sent: Thursday, April 12, 2007 6:16 PM
Hand agitation works fine - just rock the container. It helps to have it in
a larger container with a couple of inches of hot water in it. Wear rubber
gloves, of course.
Leon
2007-04-13 by derekhawkins
I use sodium metasilicate with off-the-shelf positive resist boards. An
80 cent packet lasts about a year. Have NaOH in abundance but use it
only for stripping the remaining resist after etching.
2007-04-13 by Len Warner
>should it not absorb moisture from the air?
Conc. sulphuric acid is a powerful dessicating agent and would
absorb atmospheric moisture.
If you splash conc. sulphuric acid onto organic matter it will
dehydrate it quickly  - viz. the sugar/sulphuric acid carbon volcano
demonstration. So handle conc. sulphuric with great care and as
little as possible.
I meant working-strength dilution. Dilute sulphuric acid will lose
water vapour and will not evaporate much H2SO4 until the
concentration rises to around 77% - which strength is not
something you would like to leave laying around the place and
may be higher than the concentration you are bought it at!
Whereas conc. hydrochloric acid starts at around 35% and
when spilled will evaporate completely, though not necessarily
without causing some damage; sulphuric acid, diluted to a
similar strength to make it easier to handle, when spilled will
linger and strengthen and so be likely to cause "acid burn" stains
and possibly start actual fires (as oxidizing oil does in old rags).
So protect against splashes, wear synthetic clothing, and
wash down all contaminated surfaces well then neutralize with
sodium bicarbonate (or carbonate) solution. (Or, if you want
minimum residues and don't mind the smell, ammonia water.)
Regards, LenW
2007-04-13 by pgdion1
My "Darkroom" is my shop in the basement with a 60w bulb in the
corner. This provides sufficient light to work by and still allows for
long times working with the photo-pcb's before developing.
I know it could be brighter but this seems sufficient to see by and is
very board safe.
- phil
KA0HBG
--- In Homebrew_PCBs@yahoogroups.com, "Leon" <leon355@...> wrote:
> From: "DJ Delorie" <dj@...>
> Leon
> Leon Heller
> leon355@...
Re: [Homebrew_PCBs] Re: Hammermill Office One Glossy Paper
2007-04-13 by Roland F. Harriston
Can anyone provide me with the UPC number for Hammermill
Office One Glossy Paper?
The item number (229030) previously posted here by a member does not
seem to exist in
any of the Hammermill product listings I have access to..
Perhaps this number is a Sam's Club stock number or some such, but it
does not ring a bell with Hammermill suppliers
Thanks
Roland F. Harriston
>is very board safe.
Here's a tip, change the light switch for a dimmer-switch, that way you
can use a brighter bulb and still meet lighting levels for all
occasions. I also have a dimmer-switch in the bathroom for development.
2007-04-14 by izzo47
Looks like Sam's,online, maybe the only place to order. Tried Staples &
Office Max...Office Max had another Hammerhill paper very similar.
Sam's Club Description:
Hammermill Office One Business Glossy Papar #229030
Paper, Color, Laser, 32lb, 92 Brightness, 81/2 x 11 White 300 Sheets
$7.06
Don't know IF you need a membership card to order online...my guess is
yes?
Izzo
--- In Homebrew_PCBs@yahoogroups.com, "Roland F. Harriston"
> seem to exist in
> Thanks
> Roland F. Harriston
2007-04-14 by Roland F. Harriston
Izzo:
Thanks for the response.
I did see Hammermill #229030 listed on the Sam's Club website,
but one has to be a paid-up member to order online,
and I'm not such.
The Office Max folks told me that they have never
seen the given Hammermill number, and could not
order it for me unless I came up with a "real"
Hammermill number.
Anyway, the paper I purchased from Fry's, which is
their # 2687282 works quite well and does not require
the customary water-soak to remove the paper.
Roland F. Harriston
> $7.06
> yes?
> Izzo
> --- In Homebrew_PCBs@ yahoogroups. com
> <mailto:Homebrew_PCBs%40yahoogroups.com>, "Roland F. Harriston"
> > seem to exist in
> > Thanks
> > Roland F. Harriston
Newbie questions
2010-01-04 by jimofc300
While I'm an experienced design engineer, I've never done a PC board in 40+ years of design. We had a special department to do that. Now retired, I thought I'd try inventing. I find PCBs important to that goal.
In getting together a kit to do this, I had a few thoughts and questions. I hope you more experienced (though not necessarily older) and (presumably) wiser folks :-) can address some of these questions.
1)  I've looked into photo paper and "Press-N-Peel" to transfer toner as resist. Do you think laser T-shirt transfer paper, which is probably cheaper, would work, too? Has someone tried this?
2)  Do you think latex gloves, as you'd find in a doctor's office, would be safe for handling boards and etchant? They're cheap at Walgreens and disposable to reduce cleanup effort.
3)  If ferric chloride wouldn't destroy them, would kitchen plastic bags (ZipLock-type) work for etching boards? They'd probably save on etchant and, if I don't slop too much, reduce cleanup.
4)  How nasty is used ferric chloride? Is it a HazMat material? How do you folks dispose of it in an eco-friendly manner?
5)  Would Krylon spray clear coating and/or spray paint work as a solder mask? My thought is to spray the board immediately after etching and touch-up. Then, I would assume, soldering would burn off the paint instantly. Would a second coat be necessary after assembly?
Thanks for considering my questions. I'll probably have more later.
Jim Barnes
2010-01-05 by Harvey White
On Mon, 04 Jan 2010 07:59:12 -0000, you wrote:
>Hi,
Works for me.
I'll give it a try.
T shirt transfer paper (at least, the inkjet type) has a film that
goes over the whole page area.   You'd be covering the board with
that.  You want something that doesn't add a coating to the board,
only transfers the resist.  I happen to use the pulsar paper well, but
I've also done photoetching.
Cheaper at Harbor freight.  But I use the nitrile ones, and throw them
away after one use.  However, the yellow gloves, perhaps the "chemical
resistant ones" are more resistant to hot etchant and last longer.
They are also more tear resistant, but they will die eventually.
Ferric chloride won't destroy them during one use.  I'd try the
freezer style, they're tougher.
Pulsar has some fast etch techniques.  Not done them with a lot of
success, but you can speed up the etching if you gently rub some areas
of the board.  Etch resist has to be tough, though.
varies in opinion and locale.  Others use a mixture of hydrogen
peroxide and muriatic acid,  which seems to be a nicer etchant.  I'll
be trying it later.
Not a solder mask, but moderately decent for board coating.  I put
parts on both sides, so not so useful.  I think it would be less heat
resistant than you want, so how to make it a solder mask is a good
question.
Works for me.
Harvey
>Jim Barnes
>http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
2010-01-05 by DJ Delorie
"jimofc300" <jim@...> writes:
That's what I used until I got a pair of the heavy-duty rubber gloves.
Just be careful that the sharp edges of the PCB don't tear them.
Use a plastic one-gallon milk jug.  Cut it vertically into two halves,
keeping the spout on one half and the handle on the other.  Use the
spout half as a tray, it's got a built-in funnel :-)
Mine is still sitting under the lab sink in its original decades-old
bottle.  The FeCl itself is relatively harmless when diluted, but the
copper in it isn't.
2010-01-05 by David Griffith
On Mon, 4 Jan 2010, jimofc300 wrote:
> Hi,
> goal.
Might be worth a try.  Lots of people have success with the slick pages of
magazines.  The ink already there won't transfer and the clay will hold
the toner just enough to let you do a heat transfer.  Look up "Gootee
board" for the guy who came up with it.
Those would work fine.  The biggest hazard with ferric chloride is that it
stains just about everything including glass and skin.  So, think twice
before you borrow your wife's cassarole dish for etching.  My custard cups
now have an odd tinge of yellow.
I never thought of that.  Maybe.  Another method to be stingy with etchant
is to wipe the board with a small sponge or swab.  It takes a lot longer
that way though.
Small amounts down the drain is generally considered okay.  See also
http://hackaday.com/2009/01/26/ferric-chloride-etching-chemistry/
for other ideas and alternative etchants.
You can do that, but it won't work as a soldermask because the heat of
soldering burns off the film.  It'll do the other job of soldermask:
keeping the copper untarnished.  Transparent Green Candy Apple by Testors
gives something very close to the classic green soldermask and lets the
traces show through.  A spray afterwards probably isn't necessary.
David Griffith
dgriffi@...
A: Because it fouls the order in which people normally read text.Q: Why is top-posting such a bad thing?
A: Top-posting.
Q: What is the most annoying thing in e-mail?
2010-01-05 by Leon Heller
Sent: Monday, January 04, 2010 7:59 AM
Subject: [Homebrew_PCBs] Newbie questions
> Hi,
I tried it years ago, it just makes a nasty mess on the board.
I use ordinary kitchen rubber gloves. Latex is too thin and you will burn
your hands.
Ziplock bags work, apparently. Put the bag etc. in very hot water. I use a
small plastic food container in an old washing uip bowl with about 1" of
very hot water in it. WEtching takes about 5 mins with fresh etchant.
Ferric chloride is quite safe, it's actually used in water treatment. Don't
get it in your eyes, though.
You can buy a proper spray-on flux, which helps soldering, or a special
lacquer, which burns through when soldering. I don't bother, as I use
photo-etch and my boards don't oxidise because of the thin film of resist
remaining on the copper.
Leon
2010-01-05 by Piers Goodhew
On 05/01/2010, at 8:15 PM, Leon Heller wrote:
> From: "jimofc300" <jim@...>
I use what was a sliced peach jar. Relatively thick HDPE with a screw top, slightly less than 1" of hot water, throw an extra teaspoon of Amm. Persulfate in when it stops working (I don't go anywhere near the volumes that would merit a permanent CuCl tank). You can screw the lid on and swish the jar around.
I've also just left the toner on the traces (cleared it off the pads w/- Qtip). But once you go to SMD/hotplate there's no going back (no drilling!), and that's not an option then. (Actually, I only assume it's not an option, never tried but I reckon it would burn/smoke)
PG
2010-01-05 by Brian Lalor
I haven’t etched my first board, yet (getting asymptotically closer;
maybe this week if I can get my toner sorted) so I’m watching this
with extreme interest. :-)
I bought a container of MG Chemical’s “Liquid Tin”, Mouser part number
590-421-500ML.  Once the board’s etched, you just swish it around in
some of this stuff and it tins the remaining copper.  It’s supposed to
prevent oxidation, but it is not a solder mask.  Mine came with a good
amount of precipitate on the bottom; anyone know if that’s normal?
Brian Lalor
blalor@bravo5.org
