Solder Mask?
2007-09-29 by Bob Macklin
Is the etching mask created from a laser printer conductive? Could the same process be used to create a solder mask. I don't have a laser printer so I cannot make the measurment. I have to go to Kinko's to make the etching masks. Bob Macklin Seattle, Wa.
2007-10-01 by DJ Delorie
"Bob Macklin" <rottenrobbie0@...> writes: > Is the etching mask created from a laser printer conductive? Could > the same process be used to create a solder mask. Toner's plastic and, I think, carbon. I tested a sample and no, it doesn't seem to conduct. However, it's also not heat resistant. See: http://www.delorie.com/electronics/alarmclock/20070705-power.html At the center pin of U400 (lower left, the 7805), you can see the solder went right over the toner line. Granted, there's a lot of solder there... quick test, as I still have that board... nope, I tried soldering a trace that had toner on it, and the solder went right through it as if it weren't there. Interesting enough, the toner did survive the hotplate reflow. I suspect that's just because nothing was there to physically move it, so it just re-solidified in place.
2007-10-01 by Bob Macklin
My interest is in a coating that protect the copper from oxidation with age. I don't have a provlem soldering. Bob Macklin Kent, Wa.
2007-10-01 by David Griffith
On Sun, 30 Sep 2007, Bob Macklin wrote: > My interest is in a coating that protect the copper > from oxidation with age. I don't have a provlem > soldering. How about plating the copper with Kool-Amp silverplating powder? I've also seen transparent enamel sprays used (like candy-apple green). -- David Griffith dgriffi@... A: Because it fouls the order in which people normally read text. Q: Why is top-posting such a bad thing? A: Top-posting. Q: What is the most annoying thing in e-mail?
2007-10-01 by JanRwl@AOL.COM
In a message dated 9/30/2007 8:57:48 P.M. Central Daylight Time, rottenrobbie0@... writes: My interest is in a coating that protect the copper from oxidation with age. I don't have a provlem soldering.<< Before any other "chemistry" to the board, TIN-PLATE the copper (just a "hot-dip" for 20 min. operation). Makes it nicer to solder, and protects the copper from "turning". There is a dry "crunchy" chemical called "Tinnit" from Kepro, I think it is. Haven't used it in SO long, I forget, now. Dissolve, use heated. Has a definite "shelf-life" and "goes bad" if not used up within a few weeks (days?). ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed]
In a message dated 9/30/2007 8:57:48 P.M. Central Daylight Time, rottenrobbie0@... writes: My interest is in a coating that protect the copper from oxidation with age. I don't have a provlem soldering.<< OOPS! forgot: After you are done soldering, if a "one-sided" board, wash off the "rosin flux" with lacquer thinner and a toothbrush (let it dry completely before re-use. Else the taste is very bad!). Then, spray the "bright" just-soldered/flux-free bottom with clear Krylon, etc. IF you have some conductor on the top, you have to be VERY careful using Q-tips or whatever to clean off the bits of flux here and there, among the components on top. Be SURE and mask off all IC-sockets, screw-terminals, solder-posts, etc., and then spray the top, but be SURE not so much that it "runs all in" the IC-sockets, etc! Takes reasonable hand-care and maybe a bit of experience! Jan Rowland ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed]
Bob Macklin <rottenrobbie0@...> writes: > My interest is in a coating that protect the copper from oxidation > with age. I don't have a provlem soldering. I've been using Liquid Tin from MG, the board in that photo is one example.
2007-10-01 by keith
On Monday 01 October 2007 00:44, JanRwl@... wrote: > In a message dated 9/30/2007 8:57:48 P.M. Central Daylight Time, > rottenrobbie0@... writes: > > My interest is in a coating that protect the copper from oxidation with > age. I don't have a provlem soldering.<< As an "aftercoat" you might try some of the spray "clearcoat" that Walmart sells in the automotive section (assuming you are inthe US). It shold be tougher than the clear Krylon. -- Keith Bowers - Thomasville, NC
2007-10-03 by Ben
> > My interest is in a coating that protect the copper from oxidation with > > age. I don't have a provlem soldering.<< > As an "aftercoat" you might try some of the spray "clearcoat" that Walmart > sells in the automotive section (assuming you are inthe US). It shold be > tougher than the clear Krylon. I use Clear Lacquer Spray, get it in the paint dept of whatever Home Improvement Store you have in your area. I also do positive resist and leave the resist on, spray with clear lacquer after soldering. See the PCB on the home page of this group. Ben
2007-10-03 by Ted Bruce KX4OM
I did some tests using three types of resists; the results are in Ted-KX4OM in Photos. I tried Future Floor Finish, spar varnish, and PolyCrylic. All three are good for protection after etching. PolyCrylic was by far the most difficult to solder through. Future is very easy to solder through. It is not so good as a resist. Future is pleasant to use; it smells really, really good when soldering :) One bottle is cheap, and will last a lifetime, give or take a couple of years. The only downside to Future is that if any chemicals are still present on the board after washing, it will turn into a green crackle finish at the location of the chemicals. Future is also good for applying decals, homemade, or otherwise. Regards, Ted --- In Homebrew_PCBs@yahoogroups.com, "Ben" <bhleavi@...> wrote:
> > > > My interest is in a coating that protect the copper from oxidation > with > > > age. I don't have a provlem soldering.<< > > As an "aftercoat" you might try some of the spray "clearcoat" that > Walmart > > sells in the automotive section (assuming you are inthe US). It shold > be > > tougher than the clear Krylon. > > > I use Clear Lacquer Spray, get it in the paint dept of whatever Home > Improvement Store you have in your area. I also do positive resist and > leave the resist on, spray with clear lacquer after soldering. See the > PCB on the home page of this group. > > > Ben >
2007-10-04 by Mark Brueggemann
If I want that "extra touch" for homebrew PCB's (say, something used for a presentation) I'll use model candy spray paint (Testors). Candy green looks just like a screened resist, and solder burns through it just as readily as anything else. Candy blue and red also look great. Otherwise for "production" I usually use $1.99 clear enamel. Mark K5LXP Albuquerque, NM
