Laminator temperature control
2008-01-16 by josemj1
There seems to be a lively discussion about the use of laminators, so I think I should chime-in. I bought a cheap 9" pocket laminator from a Wal-Mart, then ripped out all the temperature control wiring. I then wired-in a cheap process controller (such as can be found on Ebay for ~$35), using some type-T thermocouple wire. This lets me precisely set the laminator temperature. The process controller had an internal relay capable of switching 2 amps, which happily was also the load which the heating element presented. The laminator provides superior uniformity, compared to a clothes iron. With an HP toner cartridge, Staples "Photo Basic Glossy" paper, and the temperature set to 145 degC, I get utterly repeatable results. The transferred toner is durable enough to withstand vigorous scrubbing with a soft toothbrush. 15 mil lines and pads are clearly defined, making a TQFP package usable for the first time in MY experience. As I said, the laminator helps mostly with uniformity, but the paper is the other part of my process which really makes it successful. Presumably an old laser printer fuser assembly can be modified in a similar way. Keep in mind that most of the available process controllers seem to accommodate many different types of thermocouple junctions, so you don't have to be choosy about what type you need. Marshall
