Homebrew PCBs
buying LED's for a exposure box
2008-02-14 by Adam Seychell
I'm wondering if anyone knows where is a good place to buy >= 100 UV
LED's for home made PCB exposure box ? There are two sellers on eBay
that I have found: (all prices below include delivery)
http://stores.ebay.com/Winsome-House-Store
They are advertising 100 x 3000mcd(typ.) 20 degree UV LEDs for US$11.
This sounds almost too cheap.
http://stores.ebay.com/Light-of-Victory-Led-Store-lvehk
They have 100 x UV LEDs 20 degree 7000mcd(typ.) for US$32.
or 100 x UV LEDs 20 degree 3000mcd(typ.) for US$15.
It would seem I could use half as many of I buy the 7000mcd compared to
3000mcd. I'm guessing a 20mm grid spacing would be a good layout for the
LEDs.
regards,
Adam
Re: [Homebrew_PCBs] buying LED's for a exposure box
2008-02-14 by Markus Zingg
Adam,
I do have a 20mm grid spacing, and I'm so far satisfied. Even though it
never formed a problem of any kind, one can SEE the grid on the
resulting exposed laminate. It's seen like kind of darker and lighter
circular shaped areas on the exposed resist. Again, developping the
result always worked excellent with no irritations in the result whatsoever.
At the very surprisingly low prices of these LEDs, I would consider
using an even more narrow grid. My box (kingbright leds, with what I
understand only 160mcd typical) result in a one minute exposure time.
So, with the 7000mcd ones, you might be not fast enough in flashing them
on and off for the exposure :-) ....
Let us know what the outcome of this will be. Me thinks that the first
seller in your list is the more interesting one due to the fact that
those LEDs seem to have a more narrow angle and compared to what I have
(160 vs 3000) those LEDs still seem to be superior. On the other hand I
heard from a guy who bought UV leds over e-bay that they were not
useable at all. This sounds odd to me though if the specs given on the
sellers pages reflect the truth. Again, I will be interested to hear
about your experience, and with $11 you risk not that much. I probably
would try to expose a sqare inch of resist using one LED "on the fly"
(make sure you don't look into the UV but who am I to tell you this)
before I would spend the time to build a complete exposure unit to make
sure they work.
Markus
Adam Seychell schrieb:
> Hi,
> <http://stores.ebay.com/Winsome-House-Store>
> <http://stores.ebay.com/Light-of-Victory-Led-Store-lvehk>
> LEDs.
> regards,
> Adam
2008-02-14 by Ross McKenzie
Adam Seychell wrote:
> Hi,
> LEDs.
> regards,
> Adam
Hi Adam,
Twelve months ago I bought 50 UV leds from an ebay seller in Homg Kong
for US$1.99 plusd US$11 postage. One was dead on arrival but the others
were perfect. My UV light box with 7 strings each of 7 leds in series
spaced at 20 mm works perfectly for me. But you do need a diffuser to
get an even light (no hot spots). Believe it or not, I used two sheets
of baking paper. Lovely even glow. Ten minute exposure times at 60 mm
above the leds. I mount my sensitied board and the photoartwork inside a
slide in photoframe with a single sheet of glass in front. Very tight
package. No undercutting.
I just checked for the seller "jeledhk", but he is "not
found"...otherwise I would recommend him.
Best of luck.
Ross
Re: buying LED's for a exposure box
2008-02-14 by zip1zip1zip1
I to have been looking at using LED's for an exposure unit.  Since
most photo resist for PCB board are in the range of 350 - 420 nm.  I
was looking at Led's that had a wider spread in that range or in the
middle of that range might be better. Of course not having built it
yet, I can't say if that is true or not.
BestHongKong
http://stores.ebay.com/BestHongKong_W0QQtrksidZp1638.m118.l1247
List three different LED's
x561 390-395nm   100/ USD $8.75 ship $8.95
x562 395-400nm   100/ USD $7.75 ship $8.95
x563 400-410nm   100/ USD $9.95 ship $8.95
I was looking at the 390-395nm ones
Or I was also looking at
http://alan-parekh.vstore.ca/product_info.php/cPath/4_7/products_id/28
which have a range of 380 - 400 NM.
Tom
2008-02-14 by pork_u_pine2000
--- In Homebrew_PCBs@yahoogroups.com, "zip1zip1zip1" <tom@...> wrote:
> BestHongKong
> Tom
I bought about 100 of each of these grades from BestHongKong and they
seem entirely satisfactory.  I was looking at the absorption maxima
for organic materials (fish-glue gelatin and some of the
polysaccharide gums) and found that the 390-395 range looked best, but
all seem to work.  I ended up buying some UV strips with 3 LEDS
mounted on an aluminum carrier that are set up for 12v.  They seem to
produce more output than I would guess.  I have more problem with
overexposure than with underexposure.
I mounted the strips on a 1 foot chunk of heavy aluminum heat sink
(because that is what I had handy), wired about 9 of the 3 LED strips
in parallel.  I hooked the whole works to a gel cell battery (too lazy
to build an adequate power supply) and an old darkroom timer.  I put
the leds in an old, gutted HP scanjet which makes a great contact printer.
Anyway, BestHongCong has been a good source for LEDS.  I just wish
that they had more chip-type LEDs and some shorter wavelengths (365 -
385 would be helpful).  And good, cheap, stable single mode UV Laser
diodes.  I want to try direct-draw on photosensitive material with an
inkjet mechanism with the jet heads replaced with a laser diode.
-- Dave
Thanks Ross. It looks like ebay is the best to get LEDs for this
project. Diffusers only undermine light undercut. When I'm pushing the
limits out of what my inkjet printer can produce, I need minimum
undercut. I've tried banks of fluorescent tubes in the past with dismal
results. I'm using large HID mercury lamp for the time being.
I had the idea of mounting the LEDs in an array of 5mm diameter holes
drilled through a 18mm (3/4") thick MDF particle board. This will
guarantee a maximum +-8 degree from each LED. As Markus Zingg, suggested
I'd need to experiment a bit until I find optimum layout.
I know that all LEDs aren't made equal. From experimenting with normal
colour LEDs I notice some manufactures have fairly poor uniformity or
patterns of rings when shined on a white surface.
Adam Seychell
2008-02-14 by Stefan Trethan
Can a digital video camera see UV LEDs?
I know it can see IR, but i dunno about UV. It may be useful to judge
differences and illumination pattern if it can.
If it can't maybe one can build a meter with a suitable receiver to
select LEDs, or maybe it is as simple as putting a sensitized board
right up against the array and making a borderline short exposure to
weed out any extra strong or extra weak LEDs.
I am glad i do not need photoprocess for the boards i want to make.
ST
> Adam Seychell
Markus Zingg wrote:
> Adam,
That's good to hear it works despite the visible pattern. What is your
space between the LED and PCB ? I guess the larger the distance the
greater the light overlap of adjacent LED's and possibly better uniformity.
The BestHongKong ebay seller Tom pointed out had the better specs
(tighter spectrum tolerance, polar plot). Interestingly , some LEDs are
rated in mcd while others rated in mW. BestHongKong 5mm UV LED's are all
11mW 20 degree. I think I'll get these. But might also get $11 ones from
Winsome House Store just for fun.
 >.... I would spend the time to build a complete exposure unit to make
> sure they work.
For sure. Some preliminary testing will soon give me estimate of
exposure times vs grid spacing and test non-uniformity.
I'll be sure to let others know how it goes.
Adam Seychell
Re: [Homebrew_PCBs] Re: buying LED's for a exposure box
BestHongCong looks like the best so far. Their LED's are rated at 11mW
and don't know what that translates to in mcd. Anyway the specs are
better than the other two ebay sellers (which I think are identical
parts from the same factory). I think around 360nm is optimum for
photoresists as they are normally designed for exposure with the 365nm
peak from mercury lamps. The 390-395nm cost only an extra dollar or two
so I'll get those. What did you mean by "390-395 range looked best" ?
did it have a better light pattern ?
Adam
2008-02-15 by wimmie262000
--- In Homebrew_PCBs@yahoogroups.com, "Stefan Trethan"
I guess it can. Look here:
http://hackedgadgets.com/2006/10/31/uv-led-pcb-exposure-system/
There is a photo with 5 LEDs that are giving less output. They were
exchanged due to the photo "exposing" them.
Joop
2008-02-15 by javaguy11111
I went ahead and placed an order for some as well.
I am wondering if just doing simple current limiting resistors is
sufficient or if a proper LED driver chip would be the better way to
go. From what I have read, at least for visible LEDs, you want to
match the current in the LEDs to ensure that they all shine evenly.
--- In Homebrew_PCBs@yahoogroups.com, Adam Seychell <a_seychell@...>
wrote:
> Markus Zingg wrote:
> > Adam,
though it
whatsoever.
uniformity.
all
from
> > sure they work.
> Adam Seychell
2008-02-15 by James Bishop
This gave me an idea.. I wonder if it would be possible to replace the
laser diode in a laser printer with a uv one, and then run a
sensitised board through in place of the drum..
What do you guys think? Am i crazy?
> > BestHongKong
> > Tom
> -- Dave
2008-02-15 by Russell Shaw
You could measure the intensity spread by using a photodiode behind
a pinhole in alfoil.
2008-02-15 by agscal -AGSCalabrese
Even LEDs from the same batch cannot be trusted to
have the same brightness for the same current.  After
they age, it is even less likely that they will match. If you
want them to stay matched you would have to have some
kind of feedback or periodic re-calibration of each LED.
I think that is probably overkill.
I recommend that you use a current limiting resistor and
put 10 or 20 or more in a string.  This guarantees that every LED
in that string will get the same current.
For example, if you had 20 LEDs and each one had 1.7V
forward voltage drop, you would have a total forward voltage
drop of 34 volts.  If you use a 36 VDC supply you can tweak the
resistance
to get the current you want.  To get 20ma you would divide 2 volts
by .02 A to get a resistance of 100 ohms.  The 2 volts comes from
subtracting 34V from 36V.
This approach can be modified to match whatever power supply
you have laying around to the LEDs you have.
Gus
2008-02-15 by Myc Holmes
All of the designs so fr have used a rectangular grid. Since the output is
circular in shape, why not take a clue form the honey bees and set up the
LEDS in a hexagonal grid? This should result in more even coverage.
Myc
On Fri, Feb 15, 2008 at 3:48 AM, agscal -AGSCalabrese <agscal@...>
> resistance
> Gus
2008-02-15 by Markus Zingg
I think it just does not matter that much. As noted earlier, I can SEE a
difference on the exposed laminate, but this does not influence the
result after etching. It seems to me that the resist ist quite forgiving
here, well, at least with the Ordyl Alpha 900 I'm using this seesm to be
the case.
The only reason why I would want to change something if at all is to
have a bigger area (more leds I'm currently limitte to 160x100 cm sized
boards) and a higher density (currently using a 20cm grid) to shorten
the exposure time. However, the latter really is not important as I'm
exposing only one minute with the current setup.
Markus
> Myc
Hi Adam,
The space is 6 cm.
HTH
Markus
> uniformity.
2008-02-15 by Steve
I have a quicker, cheaper (maybe better?) idea: just put a sheet of
bright white paper in place of the PCB. They get paper white by
putting "brighteners" in it, which is just fluorescent colorants that
glow in visible under UV.
I have found it easier to see differences if the paper is not white,
though. I have a pack of that green fluorescent paper stock I use to
make my business cards, you can see the pattern fairly clearly.
Steve Greenfield
2008-02-15 by Steve
You should start your own thread for this.
Steve Greenfield
2008-02-15 by Leon
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Friday, February 15, 2008 6:42 AM
Subject: Re: [Homebrew_PCBs] Re: buying LED's for a exposure box
Impossible, without re-engineering the machine.
Leon
2008-02-15 by pgdion1
I hate it when people think ... Wow, great idea Myc.
Just offsetting each row by half the grid would probably be a lot more
even.  It may not matter a lot but, it's really easy to do it so why not?
I'm going to try building one of these myself.  Looks like a great
idea and would make the photo process one step easier.
btw - the UV diodes have about a 3.3v drop on them.  That's why 3 per
line on 12v works good.  But 4 would work well off a filtered 12v
transformer and 8 off of a 24v one.  I plan to run rows of 8 to keep
the current demand on the power supply down (and as mentioned, all
diodes in each group of 8 will have the same current ... nice and
easy). 12 rows of 8 would only be a 1/4 amp.
You get about 17v off the 12v when filtered and 34 off the 24. Enough
to regulated to 30v and then a small resistor for the current limit
... something around 150 to 180 ohms for the 20mA and well under 1/10
W.  The regulator might be overkill but helps make for nice clean DC.
Phil
--- In Homebrew_PCBs@yahoogroups.com, "Myc Holmes" <mycroft2152y@...>
output is
up the
> Myc
Why not make a line of LEDs spaced 7-8 mm apart.
then push the photoresist board underneath the LEDs
at a constant speed ?  If your line is 160 mm long you
can produce exposed boards 160 mm by 1,000,000 mms.
Gus
output is
Myc
 > resistance
 > Gus
way to
2008-02-15 by Stefan Trethan
if you use an old flatbed scanner you'd have all the moving parts for
that (and the board could remain in place, which is always good).
BUT the drawback is obvious, longer exposure time, ~100,000 times
longer for the board you suggest to make ;-)
ST
> Gus
> output is
> the
> Myc
>  > resistance
>  > Gus
> way to
> http://groups.yahoo.com/group/Homebrew_PCBs
http://hackedgadgets.com/2007/02/24/uv-led-pcb-exposure-scanner/
TANSTAAFL!
Myc
> ST
> On Fri, Feb 15, 2008 at 7:52 PM, agscal -AGSCalabrese <agscal@...<agscal%40gmail.com>>
> > Gus
> > output is
> > the
> > Myc
> > On Fri, Feb 15, 2008 at 3:48 AM, agscal -AGSCalabrese <agscal@...<agscal%40gmail.com>
> > > resistance
> > > Gus
> > way to
> Photos:
> > Yahoo! Groups Links
Yes, for a given number of LEDs covering a specified area, there is
no difference in time between scanning and fixed LEDs.
If you buy enough LEDs to expose 100mm by 100mm properly in 60 seconds,
then putting all those LEDs together in a line and scanning will get
the exposure
done in the same amount of time.  And the exposure should be more
uniform.
Gus
TISATAAFLP
TANSTAAFL!
Myc
 > ST
 > > Gus
 > > output is
set up
 > > the
 > > Myc
 > > > resistance
 > > > Gus
resistors is
 > > way to
want to
evenly.
 > Photos:
 > > Yahoo! Groups Links
there is such a thing as a free lunch pail ......
2008-02-16 by Stefan Trethan
Yes, if you buy the same number of LEDs.
> the exposure
> uniform.
> Gus
> TISATAAFLP
2008-02-16 by Myc Holmes
Hi Gus,
"TISATAAFLP"
LOL!
Either you are showing your age or are a Robert Heinlein fan.
Mycroft Holmes
> On Feb 15, 2008 10:30 PM, agscal -AGSCalabrese <agscal@...<agscal%40gmail.com>>
> > the exposure
> > uniform.
> > Gus
> > TISATAAFLP
2008-02-19 by Chris Horne
Sorry Guys, I was on holiday while this thread was active !
If anyone is worried about the beam pattern, it is easy enough to make
standard 5mm LEDs wider angle..
When assembled, just work the board LEDs down, on a sheet of 600 wet
and dry, in a circular motion..
do this until the tops of the LEDs are flat...
then do the same on a sheet of card, using 'T' cut or other paint
refinishing paste..
it works a treat..  you will get a good 100 degrees or so, problem
solved...
Chris
wrote:
> Markus Zingg wrote:
> > Adam,
though it
whatsoever.
uniformity.
all
from
> > sure they work.
> Adam Seychell
2008-02-20 by Dave McD
Chris and others,
  Won't increasing the emission angle of the LEDs increase the undercutting effect and ultimately the resolution achievable when exposing a board using these LEDs?  Since we are talking homebrew boards, how much do we really need to worry about light collumation vs the granularity (resolution) of the artwork?  Is there some sort of rough formula?
  dave mc
Looking for last minute shopping deals?  Find them fast with Yahoo! Search.
2008-02-20 by wimmie262000
--- In Homebrew_PCBs@yahoogroups.com, Dave McD <davemac2@...> wrote:
> Chris and others,
rough formula?
>   dave mc
There is a risk of more undercut. But I guess it depends on what kind
of mask you use and the detail required. I use a UV face tanner and
chalk paper printed in my laser printer for the mask. For a board with
small details (SMD stuff) I should not put the paper upside down
during exposure or I have undercut problems. Also I need to make sure
the PCB is pressed really flat to the chalk paper. But doing it right
I have no problems at all.
Some people have a problem with proper blackening of the masks and
claim that using two chalk paper or film layers on top of each other
is the solution. With that method I would imagine that a more
perpendicular lightsource is key. So grinding the LEDs to spread the
light, or putting a piece of chalk paper on top to get the same result
would be asking for trouble.
If you can afford more exposure time, but cannot not afford to invest
in more LEDs, I would suggest to place the LED's further away from the
PCB, rather than diffusing the light source.
Joop
2008-02-21 by Chris Horne
> Chris and others,
undercutting effect  <<   SNIP
I guess that is true.. but
I must admit I never had a problem with undercutting, even when using
dual 12" tubes 4" away..  but then I don't do really fine traces..
Nowadays I almost exclusively use toner transfer and find it quicker,
easier, cheaper and more reliable.
The only time I don't use toner transfer is when milling.
I grind LEDs for a completely different application, for which it
works really well.
Chris
2008-02-21 by Markus Zingg
Dave,
I think undercutt becomes a real issue if you apraoch 4mil traces. I
don't think it's an issue above 10mils provided you take the usual care
(make sure your film is printed in a way where the ink is on the side of
the photosensitive surface of the PCB).
A not good enough film quality will also cause trouble, but I would not
call that "undercut". So, in this context, LEDs have the advanteage to
let you aproach really fine traces and one obviousely can build a box
that is physically smaller than a tube based setup.
With the prices given from these e-bay sellers it's IMHO a no brainer
though.
Markus
Dave McD schrieb:
> Chris and others,
> rough formula?
> dave mc
--- In Homebrew_PCBs@yahoogroups.com, "Chris Horne" <chris@...> wrote:
We are all electronics savvy here, but I guess it doesn't hurt to
point out that off 12 Volts, groups of 3 LEDs in series with the
appropriate current limiting resistor is probably the most economic
way to put them together
Chris
