Homebrew PCBs
Re: [Homebrew_PCBs] Digest Number 2406
2008-02-16 by Donald H Locker
I hope someone is experimenting with hexagonal placement of the UV LEDs.  A
square pattern is guaranteed to have the greatest non-uniformity for the number
of LEDs used.
Donald.
Homebrew_PCBs@yahoogroups.com wrote:
> There are 17 messages in this issue.
[snip]
> 1d. Re: buying LED's for a exposure box
>     Posted by: "Adam Seychell" a_seychell@... a_seychell
>     Date: Thu Feb 14, 2008 2:43 pm ((PST))
> Markus Zingg wrote:
>> Adam,
>> I do have a 20mm grid spacing, and I'm so far satisfied. Even though it
>> never formed a problem of any kind, one can SEE the grid on the
>> resulting exposed laminate. It's seen like kind of darker and lighter
>> circular shaped areas on the exposed resist. Again, developping the
>> result always worked excellent with no irritations in the result whatsoever.
> That's good to hear it works despite the visible pattern. What is your
> space between the LED and PCB ? I guess the larger the distance the
> greater the light overlap of adjacent LED's and possibly better uniformity.
>> At the very surprisingly low prices of these LEDs, I would consider
>> using an even more narrow grid. My box (kingbright leds, with what I
>> understand only 160mcd typical) result in a one minute exposure time.
> The BestHongKong ebay seller Tom pointed out had the better specs
> (tighter spectrum tolerance, polar plot). Interestingly , some LEDs are
> rated in mcd while others rated in mW. BestHongKong 5mm UV LED's are all
> 11mW 20 degree. I think I'll get these. But might also get $11 ones from
> Winsome House Store just for fun.
>  >.... I would spend the time to build a complete exposure unit to make
>> sure they work.
> For sure. Some preliminary testing will soon give me estimate of
> exposure times vs grid spacing and test non-uniformity.
> I'll be sure to let others know how it goes.
> Adam Seychell
[snip]
2008-02-16 by Markus Zingg
I may try that if I will end up building another one, but hey mine -
with aparently the worest placement (20mmx20mm square) works perfectly.
Sometimes this group is surprizing me for searching to solve problems
which in reality do not exist... :-)
SCNR
Markus
> LEDs. A
> the number
> of LEDs used.
> Donald.
> Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com>
> [snip]
> <mailto:a_seychell%40yahoo.com.au> a_seychell
> > Markus Zingg wrote:
> >> Adam,
> whatsoever.
> uniformity.
> all
> from
> >> sure they work.
> > Adam Seychell
> [snip]
