Softening solder paste
2008-02-17 by Marko Pavlin
Hi! I have following solder paste: http://alphametals.com/products/product.asp?ID=OM-5002 which has expired year ago. It's too hard for printing. Is there any way to soften the paste? May I use any of "normal" solvents, like ethanol, aceton etc.. to make it softer? Marko
2008-02-17 by Stefan Trethan
I tried, with no luck at all! Whenever i tried to thin SMD paste it turned into explosive paste ;-) What i mean to say is the components were catapulted right off the PCB as soon as i heated it. I tried alcohol (ethanol and isopropyl), and glycerine. Same result. Did not try acetone, possibly it could evaporate before the heat is applied. Did not try propylene glycol, may do so at some point. I would also like to know a solvent/softener. My research has led nowhere, the manufacturers say toss it out. If you find anything let me know. ST
On Feb 17, 2008 5:27 PM, Marko Pavlin <mp@...> wrote: > Hi! > > I have following solder paste: > http://alphametals.com/products/product.asp?ID=OM-5002 > which has expired year ago. It's too hard for printing. Is there any way > to soften the paste? May I use any of "normal" solvents, like ethanol, > aceton etc.. to make it softer? > > Marko > >
2008-02-18 by Bill Maxwell
I have had great results using a Flux Pen, type SMF12P, manufactured by Electrolube, to soften dried out solder paste, Marko. It would be useful to know just what the solvent used in that product is. A tub of it would be very handy on the work-bench. Bill Marko Pavlin wrote:
> Hi! > > I have following solder paste: > http://alphametals.com/products/product.asp?ID=OM-5002 > which has expired year ago. It's too hard for printing. Is there any way > to soften the paste? May I use any of "normal" solvents, like ethanol, > aceton etc.. to make it softer? > > Marko > > > Be sure to visit the group home and check for new Links, Files, and Photos: > http://groups.yahoo.com/group/Homebrew_PCBs > Yahoo! Groups Links > > > > >
2008-02-18 by michael_haberler
--- In Homebrew_PCBs@yahoogroups.com, Bill Maxwell <wrmaxwell@...> wrote: > > I have had great results using a Flux Pen, type SMF12P, manufactured by > Electrolube, to soften dried out solder paste, Marko. It would be > useful to know just what the solvent used in that product is. A tub of > it would be very handy on the work-bench. I've read up the safety description of the SMF12P Flux Pen - see http://www.farnell.com/datasheets/60861.pdf . It lists Propan-2-ol (Isopropanol) - should be easy to get. -Michael
2008-02-18 by Stefan Trethan
Well i tried IPA and it popped the components off. But IPA is notorious for containing water, so maybe that's the culprit. ST
On Feb 18, 2008 9:31 AM, michael_haberler <reg5612@...> wrote: > --- In Homebrew_PCBs@yahoogroups.com, Bill Maxwell <wrmaxwell@...> wrote: > > > > I have had great results using a Flux Pen, type SMF12P, manufactured by > > Electrolube, to soften dried out solder paste, Marko. It would be > > useful to know just what the solvent used in that product is. A tub of > > it would be very handy on the work-bench. > > I've read up the safety description of the SMF12P Flux Pen - see > http://www.farnell.com/datasheets/60861.pdf . > > It lists Propan-2-ol (Isopropanol) - should be easy to get. > > -Michael > > > > > > Be sure to visit the group home and check for new Links, Files, and Photos: > http://groups.yahoo.com/group/Homebrew_PCBs > Yahoo! Groups Links > > > > >
2008-02-18 by Myc Holmes
Most Isopropanol that you buy in a drug store is 70%, the rest water. Check with the pharmasist, he/she may have some 90%. In a last resort, you can purchase anhydrous (100%) for a chemical supply company. But keep the bottle closed as it will absord water form the air. Myc On Feb 18, 2008 3:54 AM, Stefan Trethan <stefan_trethan@...> wrote: > Well i tried IPA and it popped the components off. > But IPA is notorious for containing water, so maybe that's the culprit. > > ST > > On Feb 18, 2008 9:31 AM, michael_haberler <reg5612@...<reg5612%40mah.priv.at>> > wrote: > > --- In Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs%40yahoogroups.com>, > Bill Maxwell <wrmaxwell@...> wrote: > > > > > > I have had great results using a Flux Pen, type SMF12P, manufactured > by > > > Electrolube, to soften dried out solder paste, Marko. It would be > > > useful to know just what the solvent used in that product is. A tub of > > > it would be very handy on the work-bench. > > > > I've read up the safety description of the SMF12P Flux Pen - see > > http://www.farnell.com/datasheets/60861.pdf . > > > > It lists Propan-2-ol (Isopropanol) - should be easy to get. > > > > -Michael > > > > > > > > > > > > Be sure to visit the group home and check for new Links, Files, and > Photos: > > http://groups.yahoo.com/group/Homebrew_PCBs > > Yahoo! Groups Links > > > > > > > > > > > > > [Non-text portions of this message have been removed]
2008-02-18 by Leon
From: "Myc Holmes" <mycroft2152y@...> To: <Homebrew_PCBs@yahoogroups.com> Sent: Monday, February 18, 2008 1:34 PM Subject: Re: [Homebrew_PCBs] Re: Softening solder paste > Most Isopropanol that you buy in a drug store is 70%, the rest water. > Check > with the pharmasist, he/she may have some 90%. In a last resort, you can > purchase anhydrous (100%) for a chemical supply company. But keep the > bottle > closed as it will absord water form the air. 99.7% IPA is available in the UK, supplied by Electrolube, and available from most electronic suppliers. I've got a can of it. Leon -- Leon Heller Amateur radio call-sign G1HSM Yaesu FT-817ND transceiver Suzuki SV1000S motorcycle leon355@... http://www.geocities.com/leon_heller
I know, and i didn't buy it at a drug store as rubbing alcohol, but i still don't trust it. Maybe someone else will try, i'd like to know something that revives old paste, even if it's only for an emergency, when i need it _now_. ST
On Feb 18, 2008 2:34 PM, Myc Holmes <mycroft2152y@...> wrote: > Most Isopropanol that you buy in a drug store is 70%, the rest water. Check > with the pharmasist, he/she may have some 90%. In a last resort, you can > purchase anhydrous (100%) for a chemical supply company. But keep the bottle > closed as it will absord water form the air. > > Myc >
Come to think of it, Electrolube's Isopropanol is what I use to clean off the boards after soldering, so I should have recognised the smell and thereby,the solvent...Put that down to sinusitis. Bill Leon wrote:
> ----- Original Message ----- > From: "Myc Holmes" <mycroft2152y@...> > To: <Homebrew_PCBs@yahoogroups.com> > Sent: Monday, February 18, 2008 1:34 PM > Subject: Re: [Homebrew_PCBs] Re: Softening solder paste > > > >> Most Isopropanol that you buy in a drug store is 70%, the rest water. >> Check >> with the pharmasist, he/she may have some 90%. In a last resort, you can >> purchase anhydrous (100%) for a chemical supply company. But keep the >> bottle >> closed as it will absord water form the air. >> > > 99.7% IPA is available in the UK, supplied by Electrolube, and available > from most electronic suppliers. I've got a can of it. > > Leon > -- > Leon Heller > Amateur radio call-sign G1HSM > Yaesu FT-817ND transceiver > Suzuki SV1000S motorcycle > leon355@... > http://www.geocities.com/leon_heller > > > > Be sure to visit the group home and check for new Links, Files, and Photos: > http://groups.yahoo.com/group/Homebrew_PCBs > Yahoo! Groups Links > > > > >
