Homebrew PCBs
UV LCD exposure
UV LCD exposure
2008-02-18 by Dave Miller
Does any one know if LCDs are transparent to UV? Would it be possible
to replace the backlight on a LCD display (like a LCD computer monitor)
and do a contact exposure to a sensitized PCB with the PCB image
displayed on the LCD? A number of monitors have sufficient resolution
to do fine traces if when the LCD is clear UV is transmitted and the UV
is blocked when the LCD is dark (or visa versa if you have positive or
negative resist).
Having disassembled a LCD monitor it does not look like it would be too
difficult to replace the cold cathode lamp with UV LEDs. (Unfortunately
the LCD was cracked or I would have tried the experiment). This would
eliminate the need for photo-plotting, printing on Velum, or overhead
material. With a white light behind the LCD, you would get what you saw.
Re: [Homebrew_PCBs] UV LCD exposure
2008-02-18 by Leslie Newell
That one has occurred to me before. I even got as far as disassembling
an old black and white laptop to investigate. The biggest problem I can
see is the thickness of the glass. Unless you have extremely good
collimation of the light you will get severe undercutting.
Les
> negative resist).
2008-02-18 by Dylan Smith
I doubt it would work - the LCD would expose a grid onto your light
sensitive material (look at your LCD monitor closely - it's a grid of
pixels - positive exposure, you'd get tracks composed of very small
squares).
It would only work with diffuse, very un-collimated light (to avoid just
getting a grid pattern), which would mean you'd only be able to use it for
very large features.
Re: UV LCD exposure
disassembling
I can
of
> squares).
just
it for
I wondered about that as well, however in their efforts to make every
thing thin and light, the glass screens are getting very thin. If you
had a UV source that gave you reasonably good collimation it might
work.
You might be right about the pixilation problem, however, even the
ink jet and laser printers have that problem. Many times that problem
goes away because when you iron or laminate the paper to the boards
the toner spreads out a little. Perhaps the light spreading out a
little from the thickness of the glass will act the same.
I have a small TV screen I think I will dissasemble and try it on, is
there any one willing to sacrifice a 4" x 4" sensitised board? I have
the UV LED source, but no sensitized boards.
Re: UV LCD exposure
2008-02-18 by Andrew
> to UV? Would it be possible to replace
> LCD computer monitor) and do a contact
> image displayed on the LCD? A number of
> <SNIP>
What monitor do you have there?
The finest dot pitch LCD I have around here
(exluding <30mm monochrome projector LCDs
units) is a 10" SXGA off a fujitsu lifebook
P7000 series.
At 1280 dots across its 8" width only makes
160 DPI.
Your desktop monitor might have >1600 dots
across it but its going to be 20+ inches
diagonal so 16+ inches across which makes
for worse than 100 DPI
