Homebrew PCBs
Laser Printer Alternative
2008-05-04 by Robin
I don't have a laser printer and I don't have the funds to invest in a
laser printer right now, but I still want to create my own PCBs. All I
have access to right now are 2 Inkjet printers. One is a Lexmark Z12
inkjet and the other is a HP OfficeJet 5610 All-In-One
Printer/Scanner/Fax. How would I go about creating a PCB without
access to laser printer and only inkjet printers?
Re: [Homebrew_PCBs] Laser Printer Alternative
2008-05-04 by Leon
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Sunday, May 04, 2008 6:54 PM
Subject: [Homebrew_PCBs] Laser Printer Alternative
Just create transparencies on the inkjet printer and use the photo-etch
process. It works very well for me.
Leon
Leon Heller
Amateur radio call-sign  G1HSM
Yaesu FT-817ND transceiver
Suzuki SV1000S motorcycle
leon355@...
http://www.geocities.com/leon_heller
2008-05-04 by Roland Harriston
Robin:
I may be missing some context here, so if I am, disregard my comments.
I don't have a laser printer, but I still fab my own PCBs by taking my
original art work (PCB layout) to my local Office Max or UPS store.
I sometimes use a nearby "Mom & Pop" mailing service shop that
has several Minolta laser printers.
They make copies of my original artwork on the glossy paper that
I provide.
I use the laser copies to fab my PCBs using the iron-on technique
with etching in the popular hydrogen peroxide/muriatic acid
etch solution.
I get really good results, and I will probably never purchase a
laser printer.......at least not specifically for making PCBs.
Roland F. Harriston, P.D.
> Printer/Scanner/ Fax. How would I go about creating a PCB without
2008-05-04 by Mike
Hello,
Don't have a laser printer either, but do have an inkjet printer and
a big box office supply store in the area.
My approach is to make a copy of the PCB layout using the inkjet.  At
the big box office supply store, transfer the printed layout to the
toner transfer paper using the laser copier in the big box
store.  Most will do the coping for ~ 10 cents.
Hint: make several copies of the design or of other PCB layouts,
print them out using the inkjet printer, cut the inkjet PCB layouts
out and glue them to another piece of paper.  Have the laser copier
transfer all the layouts to the toner transfer paper.  Cut out the
PCB layout from the TT paper and make the board.  This approach
reduces the wasted TT paper.
>Be sure to visit the group home and check for new Links, Files, and Photos:
>http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
         73,
         Mike, K4GMH
2008-05-04 by Matthew Smith
Quoth Mike at 2008-05-05 07:38...
Good tip, especially for those of us on a tight-ish budget.
The same hint also applies to the very pricey 'Laserstar' film (looks
like tracing paper with a big price tag) that I use.  Don't use just one
sheet per board unless 1) you are actually producing A4 sized boards or
b) you are very rich.
I create my layouts in Eagle.  When I create the PostScript file in the
CAM processor, I keep changing the X/Y offsets of each design so that I
can fill a whole sheet of paper.  As my printer is actually a PCL type
rather than PostScript, I convert PostScript to PDF and print the
designs using Acrobat Reader, feeding the same sheet of paper back in
each time.  To make sure that I have calculated the correct offsets, I
first perform this procedure using a sheet of plain copier paper.  Once
I am satisfied that I have no designs overlapping or too close together,
I then print all the PDFs again onto the Laserstar film.
Note - after about the third pass through the printer, the Laserstar
film starts to curl a little; I have found that gently rolling it up in
the opposite direction to the curl seems to get things straight again.
The one thing that would make my process easier is if I had a tool that
could merge my PostScript or PDF files.  Tried it using an art package
(the Gimp), without success.  I also tried a bit of raw PostScript
programming a year or so back, but that just gave me a headache ;-)
Cheers
M
Matthew Smith
Smiffytech - Technology Consulting & Web Application Development
Business: http://www.smiffytech.com/
Personal: http://www.smiffysplace.com/
LinkedIn: http://www.linkedin.com/in/smiffy
Re: Laser Printer Alternative
2008-05-04 by Robin
I have to travel 20 minutes to go to any kind of place where I can
photocopy anything.
--- In Homebrew_PCBs@yahoogroups.com, Mike <k4gmh@...> wrote:
> Hello,
Re: [Homebrew_PCBs] Re: Laser Printer Alternative
Quoth Robin at 2008-05-05 08:09...
> photocopy anything.
If you only have an inkjet, as a previous poster suggested, just print
on an appropriate type of paper and use positive photoresist coated boards.
I have had just as good results doing this with an inkjet as I have with
a laser.  (I don't use an injket any more because my printing is so
infrequent that the heads always get clogged up with disuse.)
Cheers
M
Matthew Smith
2008-05-04 by Chris Hart
Matt -
I use Eagle as well, but instead of having it create postscript files, I
have it create HPGL files. I then import them into CorelDraw, and move
them around easily. Then it's only one pass.
Chris
KC8UFV
> Cheers
> M
> Matthew Smith
> Business: http://www.smiffytech.com/ <http://www.smiffytech.com/>
> Personal: http://www.smiffysplace.com/ <http://www.smiffysplace.com/>
> <http://www.linkedin.com/in/smiffy>
2008-05-05 by Matthew Smith
Quoth Chris Hart at 2008-05-05 09:14...
Hmm - interesting.  I wonder if there are other packages that can also
manipulate HPGL.
I don't actually have CorelDraw and can't really justify buying it just
for that.  (There's also the issue that I run GNU/Linux on the desktop
and that using CorelDraw would involve firing up Windows through VMWare,
which does tend to slow the system down a bit).
Have to do a bit of Googling to see if there are any other tools out
there that talk HPGL.
Thanks for the tip.
Cheers
M
Matthew Smith
2008-05-05 by Andrew
> <SNIP>
> there are any other tools out there
> that talk HPGL.
How about using vanilla gerbers and use
a gerber veiwer to lay them up.
Veiwmate by pentalogix is free and will
do that.  The free version wont let you
save layups though.
Quoth Andrew at 2008-05-05 10:59...
> save layups though.
Thanks Andrew - I've grabbed a copy of that and will give it a try.
It may mean firing up a Windows virtual machine, but that's far quicker
than what I was doing before!
Cheers
M
Matthew Smith
Quoth Matthew Smith at 2008-05-05 11:42...
>> save layups though.
OK - I went into Eagle and selected GERBER as the device.  It wants a
wheel file.  What's a wheel file?
Matthew Smith
2008-05-05 by James Bishop
You might want to have a look at 'HPGS', an open source app to convert HPGL
files to eps or png.
I made a pcb plotter a while back, and used HPGS to convert HPGL to EPS
format. The reason i used it and not the PS output from the CAM processor is
that the EPS output from HPGS looks a lot neater and was easier to parse
from my plotter program. Depending on your scripting or coding skills, it
might be possible to write something to tile your board layouts.
> >> save layups though.
> Matthew Smith
The link for HPGS:
http://hpgs.berlios.de/
> HPGL files to eps or png.
> > >> save layups though.
> > Matthew Smith
2008-05-05 by Jeff Stevens
> that
There are many ways to concatenate PDF files -- unfortunately, none of
them are likely to be 100% reliable for strange edge cases.  You can get
pretty darn close to 100% though with a few methods.
Take a look at the pdfjam package [1].  It comes with a bash script
called pdfjoin:
pdfjoin first.pdf second.pdf third.pdf --outfile joined.pdf
It uses pdflatex to do the voodoo and does so extremely well.
[1]
<http://www2.warwick.ac.uk/fac/sci/statistics/staff/academic/firth/software/pdfjam>
As an interesting aside, with "simple" PDF files, you can actually do
the following:
cat first.pdf second.pdf > joined.ps
ps2pdf joined.ps
ps2pdf will complain about errors but usually recover and provide a nice
concatenated PDF file.  The pdfjoin script is much more elegant and
proper, however.
-Jeff
2008-05-05 by Myc Holmes
Matt,
"Gerber" was originally a photoplotter format. The photoplotter had a
"wheel" or disk with the shapes around the circumference. Think photo
negatives of geometric shapes. Each wheel had a file with the corresponding
shapes with their position on the wheel.
In the older gerber formats, the wheel file was separate, in the newer
gerber format, it is included.
Of course, today the photoplotter was replacedd by software.
Myc
> >> save layups though.
> Matthew Smith
2008-05-05 by TonyB
Hi, Can't you combine PDFs with Acrobat Pro??   afn  T
> > that
> called pdfjoin:
> [1]
> the following:
> ps2pdf joined.ps
> proper, however.
> -Jeff
2008-05-05 by Dennis
Hi Robin,
If you can spend US$50-60, you might be able to get a used laser
printer on eBay.  I picked up several Lexmark Optra E+ for around
US$50 each (including shipping/handling) and consider them a prudent
purchase.
I do almost all of my printing in B&W these days and the cost of
toner refills is much, much lower than ink refills.  A toner refill
costs me about US$10 and is rated at 5000 sheets (at 5% coverage).
I've refilled my cartridge twice and don't even think twice about
printing board layouts for review.
I still use an inkjet for color printing, but now refill much less
frequently.
I haven't found any significant difference between OEM toner and the
refills I got from a place in Canada (they sell on eBay).  I use
inkjet transparencies instead of paper and have had very good
results with 8 mil traces and 8 mil spaces; though I usually use
wider traces and spaces to make the boards easier to make and less
susceptible to mild pitting.  I size my traces so pitting is only a
cosmetic issue.
I've found that, as with paper, not all inkjet transparencies work
well.  I'm using an HP brand.  I tried another members idea of using
a heat gun to "fuse" the toner after transferring and found that it
works well.  I did it on one of my "goof" boards and it turned out
okay; more pitting than usual, but I didn't spend much time touching
up (only traces that transferred very poorly).
If you can't spend $50, finding a place to make laser copies on your
paper would be one method.  But with the cost of gas being what it
is, a laser printer would quickly pay for itself if you also used it
for general B&W printing...
Dennis
--- In Homebrew_PCBs@yahoogroups.com, "Robin" <skeeterb_2002@...>
in a
All I
Z12
I saw a Samsung Laser printer in the Staples flyer this weekend for $59.
I've benen using one for toner transfer for a number of years.
Myc
On Mon, May 5, 2008 at 12:55 PM, Dennis <dl5012@...> wrote:
>   Hi Robin,
> purchase.
> frequently.
> cosmetic issue.
> Regards,
> Dennis
> --- In Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs%40yahoogroups.com>,
> in a
> All I
> Z12
2008-05-05 by martin_schoenegg
in the
that I
type
in
> each time.
This may Produce a lot of hassle. Try out Ghostscript (and may be
ghostview as GUI) and you will have a lot more fun. I don't know the
postprocessing of eagle. Very often the created postscript files are
well structured and ascii readable texts. Just take a few minutes to
study the header. Mostly there are a few commands defined in the
prologue. Windows postscript driver defines a lot of unused commands
here;-) you may keep the file easier to analyse if you go to the
settings and use there postscript level 2 and no compression...
Laserstar
You only have to find the "showpage" commands, remove them (or
comment them off, also the headers and merge them by hand by copying
the relevant rows together after the first prologue. Ghostview will
help you to preview the result on the monitor. You don't have to
create pdf or anything other. Print your postscript using ghostscript
on your printer will do the best.
that
package
I guess the only problem was the wrong literature or a too high
sophisticated printerdriver. postscript is a very powerful and
amazing programming language and every hour you spend with it is
worthful. I managed a lot of workaround with very basic knowledge of
this language.
Good luck
Martin
2008-05-06 by Myc Holmes
Myc,
I realise this ias blasphemy for EAGLE users, but take a look at DIPTRACE,
another free pcb program.There is a direct printout of the board, so you do
not have to jump through hoops.
Diptrace also includes a panelization oo printouts and well as the ability
to import EAGLE files.
Myc
On Mon, May 5, 2008 at 5:35 PM, martin_schoenegg <Martin.Schoenegg@...>
> in the
> that I
> type
> in
> > each time.
> Laserstar
> that
> package
> this language.
> Good luck
> Martin
2008-05-07 by Lee Studley
I like DipTrace also over Eagle. Eagle just isn't intuitive like Protel,
Orcad Diptrace.
The only thing I do like about Eagle is the export features. Sorry.
