Homebrew PCBs
HELP: UV Light box
HELP: UV Light box
2008-06-07 by Howard
Hi all
I need a timer for my uv light box that i have just made this week
range from about 0 to 10 mins would do the trick.
Anyone got any diagrams and pcb layouts (single side) for making one ?
something like, counts down then switchs off and sounds a buzzer ??
Thanks in advance
Howard
Re: [Homebrew_PCBs] HELP: UV Light box
2008-06-07 by Leon
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Saturday, June 07, 2008 3:21 PM
Subject: [Homebrew_PCBs] HELP: UV Light box
> Hi all
I just use a timer program for my Palm PDA. I occasionally forget to start
it when I switch the unit on, or don't notice the alarm, though.
Leon
Leon Heller
Amateur radio call-sign  G1HSM
Yaesu FT-817ND transceiver
Suzuki SV1000S motorcycle
leon355@...
http://www.geocities.com/leon_heller
Re: HELP: UV Light box
--- In Homebrew_PCBs@yahoogroups.com, "Leon" <leon355@...> wrote:
> From: "Howard" <hj.payne@...>
> > Hi all
week
one ?
buzzer ??
to start
> Leon
> Leon Heller
> leon355@...
Hi
Thats why i would want it to have a shut off relay
just looking around the net at the mo!
Howard
2008-06-07 by John Coppens
On Sat, 07 Jun 2008 14:21:18 -0000
UV exposure not being too critical, maybe the easiest thing would be to
look around for some cheap mechanical timer like those used in small
ovens, egg-timers, toasters, etc. After all, you're not interested in
sub-second precision here, are you?
John
2008-06-07 by René Eskesen
Hi
I'm making one, the range is from 1 sec to 99m99s
there is a LCD, 3 buttons start/stop, min and sec + buzzer.
It will be finished in the next comming week.
regard rene
Denmark
2008/6/7 Howard <hj.payne@...>:
>   Hi all
> Thanks in advance
> Howard
2008-06-07 by warrenbrayshaw
How about an electronic digital timer. The kind you plug into a wall
outlet having programmed it to turn on , say a table lamp, to convince
the burglars someone is at home. These can be programmed in 1 minute
increments.
Simple,low cost and readily available. Could be programmed to do a 10
minute warm up for the fluoro tubes, then off for a minute to place
the PCB then on for the
desired exposure. It would turn off by itself so you could walk away
and have 24 hrs or a week to return   before the cycle repeated if it
did not have the one time event option.
May be inconvenient for doing many exposures unless it has the
settable countdown feature,as mine does. I can set it for, say,  3
minutes and it will only provide power to the lamps for 3 minutes.
Additionally it has other uses around the home when needed.
Here's mine, available in New Zealand/Australia
http://www.kambrook.com.au/product.asp?id=50
Warren
2008-06-07 by Matthew Smith
Quoth Howard at 2008-06-07 23:51...
> Hi all
Mine does more than that - when it finishes, the display says "Enjoy
Your Meal!".
It is, as you may have guessed, the control panel from a microwave oven.
I always found dead (supposedly - I managed to resurrect a good few)
microwaves easy to scrounge from the local repair shop.  Most people
would rather buy a new unit than pay $200 to replace a $5 light bulb...
There are a couple of microswitches (door interlocks) that plug into the
main board that need to be accounted for - the pins may need to be
shorted out as these are safety devices to stop the thing from
operating.  Once that's figured out, the magnetron relay is used to
control the tubes (or whatever you are using).
Were I designing something from scratch, I'd probably use three BCD
switches to set the time (measure in seconds - easier than
minutes/seconds) and 7-segment LED displays or Nixie tubes.  You may
wish to read this specification that I started writing for a kitchen
timer for ideas:
<http://www.smiffysplace.com/nixie-kitchen-timer>
Cheers
M
Matthew Smith
Smiffytech - Technology Consulting & Web Application Development
Business: http://www.smiffytech.com/
Personal: http://www.smiffysplace.com/
LinkedIn: http://www.linkedin.com/in/smiffy
2008-06-08 by Bill Maxwell
Might be worth a look ar www.siliconchip.com.au.  They published a light
box design from a fellow Tasmanian.  He included a PIC timer pcb and
code with the article.  I'm sure pcb pattern and code are downloadable
from that site.  Cant quite remember which month it was published but
I'm sure it was late in 2007.  Sing out if you cant find it.  I have the
magazine here somewhere.
Bill  VK7MX
>> Hi all
> Leon
> Leon Heller
> leon355@...
2008-06-08 by Leon Heller
I'm in the process of making the display PCB for my prototype. It uses
two 7-segment LED displays and will plug into the little PCB supplied
with the PICkit 2, and use the supplied 16F690. When the software is
working, I'll design a PCB for the whole system, with a reed relay etc.
Leon
2008-06-08 by electrophilip
I am using an old flatbed scanner as a light box at the moment and have
a Jaycar kit timer. It has adjustable start\stop times. I have wired a
buzzer across one set of relay "NC" contacts so when not active buzzer
sounds, and my light box is wired through th "NO" contacts. When I
power it up the buzzer sounds while i'm placing boards etc. When I
press the start button buzzer goes off and light comes on and vice
versa when timing is done.
Philip
2008-06-09 by Howard
--- In Homebrew_PCBs@yahoogroups.com, "Leon Heller" <leon355@...>
uses
etc.
> Leon
Hi Leon
Would this design be able to use single side board, as iam not up to
speed on making double side one's ??
As your uesing two 7-segment LED displays, is the time displyed as
mins or secs, and what is the max time ?.  Instead of useing a reed
relay, can it use a dpdt one ?.
Thanks again for your help
Looking forward to hearing from you soon
Howard
Re: [Homebrew_PCBs] Re: HELP: UV Light box
2008-06-09 by Leon
Sent: Monday, June 09, 2008 1:19 PM
Subject: [Homebrew_PCBs] Re: HELP: UV Light box
> uses
> etc.
>> Leon
> Hi Leon
Yes, it will be single-sided. Time will be in unit minutes and tens, up to
99 minutes. I need 11 minutes.
I haven't decided on the relay, but I'll accomodate a DPDT one.
I've assembled most of the display PCB for the PICkit 2, but I've used a
couple of transistors which I didn't have in stock and which have unusual
pinouts, I should have them tomorrow. I can then get on with the software.
Leon
2008-06-09 by JB
Hi Leon  and group
Here a link to a small component count PIC count-down timer.
(100 minutes) and only need that relay to add.
Page is in spanish but explanations in english are at the bottom
links
http://www.pablin.com.ar/electron/circuito/mc/timer/
Just my 2 cents.
Will look forward to your desing.
Jose
Sent: Monday, June 09, 2008 3:19 PM
Subject: Re: [Homebrew_PCBs] Re: HELP: UV Light box
>> uses
>> etc.
>>> Leon
>> Hi Leon
> Leon
> Photos:
2008-06-09 by Myc Holmes
Thats a pretty standard design.
For the beginner, klook the PICAXE chip. A PIC micro that is programmed in
BASIC, needs only a couple resistors to program, the software is a free
download, and it's cheap. http://www.rev-ed.co.uk/picaxe/
Rather play play around with the 7 segments LED displays and the drivers and
the wiring,, just get one of the low cost LCD's. Brain at Wulfden has some
nicLCDs along with a serial interface. I've used a few of them.
http://wulfden.org/k107/order.shtml
Myc
On Mon, Jun 9, 2008 at 1:36 PM, JB <123@...> wrote:
>   Hi Leon and group
> links
> Just my 2 cents.
> Jose
> From: "Leon" <leon355@... <leon355%40btinternet.com>>
> To: <Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs%40yahoogroups.com>>
> > From: "Howard" <hj.payne@... <hj.payne%40ntlworld.com>>
> >> --- In Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs%40yahoogroups.com>,
> >> uses
> >> etc.
> >>> Leon
> >> Hi Leon
> to
> software.
> > Leon
> > Photos:
