PCB construction help
2008-06-07 by steve kibort
Hello, I am looking for someone who can help me build some some very simple PC boards. These boards would be used to install lighting in N scale model trains. The boards would only have to accommodate a surface mount resistor and two 2mm x 3mm LED's. Total size of the board is about 3/8" x 3/8 " (approx). Inputs to the board are a common for the cathode side if LED's with the resistor (need to drop from 14dvc to 3.6vdc) and two individual feeds for the anode side of the LED's to connect the 30 gauge wire feeds. I am hoping to find someone who can give me some simple and direct input on 1) materials for me to quickly and simply construct these boards one at a time as needed or, 2) is willing to construct the boards ( I will mount the components) for me at a nominal fee in small lot sizes on a periodic basis. Thank you. Steve
