Homebrew PCBs
Shelf life of HCl/H2O2
2009-01-04 by Matthew Mucker
I etched my first board a few weeks back with HCl/H2O2 and was very happy
with the results.
I saved the etchant, since I'd only etched one small board with it, and
today tried to etch a second board.  I saw no evidence of a chemical
reaction at all.
Now, I know that H2O2 will spontaneously decompose, but it seems that the
etchant should last longer than a couple of weeks. Has anyone else had
issues with storing etchant and using it at a later date?  Is there anything
I can do to increase the shelf life of my etchant?
Re: [Homebrew_PCBs] Shelf life of HCl/H2O2
2009-01-04 by leon Heller
To: <homebrew_PCBs@yahoogroups.com>
Sent: Sunday, January 04, 2009 11:15 PM
Subject: [Homebrew_PCBs] Shelf life of HCl/H2O2
> with the results.
> reaction at all.
> anything
You need to make up fresh etchant each time, it doesn't keep.
Leon
2009-01-05 by Wayne Topa
leon Heller wrote:
> From: "Matthew Mucker" <matthew@...>
>> with the results.
>> reaction at all.
>> anything
> Leon
Leon
  I found a bunch of Curric Chloride (HCL+H2O2) links on Answers.com
that say it does keep.
I even went back in my archived mail and found a message from you, on
Feb 22 2006, where you
said  you stored yours in plastic Milk bottles.
  I hope you just forgot because I just got together  come HCL and 30%
H2O2 to ecth a bunch of small
boards.  I was sure I had read some time ago that is did store for a
long time with rejuvination.
  Am I mis-remembering, which I seem to be doing a lot lately, or has
something changed.
Wayne
2009-01-05 by Gaurav Verma
Hi
It is my understanding that H2O2 will decompose readely into H2O and O2
hence you will have to add fresh H2O2 to existing solution until the etchent
becomes too dilute.
Thanks
Gaurav
On Mon, Jan 5, 2009 at 8:36 AM, Wayne Topa <linuxone@...> wrote:
>    leon Heller wrote:
> > From: "Matthew Mucker" <matthew@... <matthew%40mucker.net>>
> > To: <homebrew_PCBs@yahoogroups.com <homebrew_PCBs%40yahoogroups.com>>
> happy
> >> with the results.
> >> reaction at all.
> the
> >> anything
> > Leon
> Leon
> something changed.
> Wayne
Gaurav Verma
Email - Gaurav.Verma.MCA@...
Phone - 9910732960
2009-01-05 by Stefan Trethan
Now there's your problem. You don't have CuCl, you have HCl and H2O2.
The one will keep, the other won't.
You can make CuCl from HCL and H2O2 simply by etching copper, but
until you get there you have to add H2O2 each time you want to etch.
ST
2009-01-05 by leon Heller
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Monday, January 05, 2009 3:06 AM
Subject: Re: [Homebrew_PCBs] Shelf life of HCl/H2O2
>>> happy
>>> with the results.
>>> reaction at all.
>>> the
>>> anything
>> Leon
> Leon
> something changed.
I was referring to the cupric chloride. The HCl-H2O2 simply doesn't keep.
Leon
Ah Ha, the rejuvination process, adding H2O2 before each etching
session, until it becomes
CuCl.  Is that the stage where the solution changes color?
Thanks guys for refreshing my ageing memory.
Wayne
The solution does get darker as more copper is dissolved, but slightly
green doesn't mean there is anywhere near enough copper to etch a
board.
If you want to measure this, you can get a hydrometer. The ones sold
for car battery acid checks will usually do. A refractometer should
work as well.
Or you can just keep on etching and not worry about it, one day it
will be strong enough to make a board without adding any H2O2.
If this feature is very important to you just throw some scrap copper
in and etch it away, that'll rapidly increase the density.
ST
> Wayne
2009-01-05 by DJ Delorie
"Stefan Trethan" <stefan_trethan@...> writes:
This is what I ended up doing - I wasn't using the HCl/H2O2 solution
often enough and had to keep evaporating off water to fit in more
H2O2, so one day I just dumped about half a pound of copper into the
bucket and let it dissolve over a couple of days.  *Then* I dumped in
some H2O2 to "charge" it (it turned from brown to green) and it's been
stable since then.
At this point, my solution is so dark green that you can't see the pcb
when you're etching it.  Etching takes about 5-6 minutes, plenty fast
enough for me.
I calculated the ratio at about 1 lb copper to 3 l solution.
> stable since then.
> enough for me.
Thanks Stefan and DJ.  That is what I remember (now), that I read a few
years ago.  I
believe that it was you fellows that got me interested in the first
place to try this.
Stefan, was it you who kept your CuCl in a double capped bottle with
small holes in each
"plastic?" cap to slow down the evaporation of the H2O2?  And do you air
bubble the
solution?
DJ, do you keep yours CuCl in a rubbermaid  kitchen container, with a
lid on it?   If so, do
you air bubble the solution?
Thanks for your replys.
Wayne
Wayne Topa <linuxone@...> writes:
> lid on it?  If so, do you air bubble the solution?
I keep it in a rubbermaid container, yes, with the lid on it when not
in use.  There's a hole in it where the air tube goes through, so it's
not 100% sealed (just 99.9% :).
I use an air stone bubbler when I'm etching, as well as an aquarium
heater.  I turn both on about half an hour before etching (i.e. early
in the whole print/develop/etch process) but remove the lid at that
time.  I don't store the heater in the etchant, but I do leave the air
stone in.
I do have a vent hood over the whole works, too.
At first i was going to say you must be mistaken, but then i
remembered a few years ago i actually kept this etchant in the
described bottle. You have a better memory than myself it seems.
Now i just keep it in the etching tank, which is by now second
generation already, made of 4mm glass with a phenolic board lid. The
lid sits on a rubber surface, to form a bit of a seal (but it's not
really airtight). To keep dust out (and maybe the fumes at bay a
little) i use a large plastic container over the whole setup, as a
lid. A similar container is underneath as a emergency catch basin so
this forms a neat closed box.
ST
> small holes in each
> bubble the
> solution?
I should point out that I, also, keep my etchant tank in a big catch
basin.  I also keep the sink water running whenever I'm messing with
the chemicals, in case I need a quick rinse.
Actually I don't.  In researching Leon's reply, which I mis-read, I went
back to try
 to refresh my memory before I mixes the chemicals.  I read a lot of
2006 posts and
thought it was you the used the double-cap bottle for storage.
Thanks to you an DJ, I am now, back in the loop so to speak.  I went
back to my PCB
box and found the container that DJ mentioned in 2006.  I had started
accumlating the
necessary items back then.  It seems I have everything but the air pump
& stone so
I'm about set to finish projects I started way back then.
Many Thanks Stefan for all your help not only on this subject but from
all of your very
informative posts to this list over the years.
Happy New Year to you and yours,
Tschuss
Wayne
> stone in.
Thanks DJ.  As I mentioned to Stefan, it was your post in 2006 that I
followed when I was
putting together my PCB junk box.  I see I have all but the air pump so
I'm good to go,
Thanks again for the help, this time, and for the years of  relaxation
that the Ace of Penguins
 has given me and many others.   You are a multi-tasker of the best kind.
Happy New Year to you and Yours,
Best regards,
Wayne
2009-01-06 by Markus Zingg
I would like to switch to cucl for a while cause having a solution that
lasts virtually for ever seems to be very beneficial. Besides, I'm just
before building a new etching tank and thought that this would be a good
moment for a switch of the etchant too. Since english is not my native
language, I always felt a bit unsure if I understood things correctly if
you guys were talking about cucl in the past, and there were always some
open ends. In particular the following things are not yet clear to me:
So, one would i.e. need to build 3l HCL/H2O2 and put in half a pound of
copper into it? Correct?
How many HCL and H2O2 to get to a 3l solution to start with? I mean
what's the ratio of HCL to H2O2?
Any restrictions regarding the kind of copper? I do have copper left
over that I use for the anodes in my through plating station. Would that do?
Then, Stefan wrote " If you want to measure this, you can get a
hydrometer. The ones sold for car battery acid checks will usually do. A
refractometer should work as well."
A hydrometer - when useing google - seems to be a device to measure
humidity? Correct? What is a "refractometer", which of the two would be
easier to get and where, and how would one measure what? Regarding the
"air stone bubbler", I think I remember that one uses this to regenerate
the solution. If so, does one have to do this every once in a while, or
only during etching, or just before?
I'm sorry if these are dumb questions, but since working with chemistry
might be dangerous I want to be very sure I understand things correcly
bevore I start to experiment.
TIA
Markus
> <mailto:stefan_trethan%40gmx.at>> writes:
> stable since then.
> enough for me.
2009-01-06 by Zoran A. Scepanovic
Hello Markus,
  Device for measuring humidity is named HyGrometer:
  http://en.wikipedia.org/wiki/Hygrometer
  There are no dumb questions, only dumb answers :)
  For Hydrometer: http://en.wikipedia.org/wiki/Hydrometer
  For Refractometer: http://en.wikipedia.org/wiki/Traditional_handheld_refractometer
 Best regards,
 Zoran A. Scepanovic
 zastos@...
COINCIDENCE happens.
Please be advised what was said may be absolutely wrong,
and hereby this disclaimer follows.
I reserve the right to be wrong and admit it in front of the entire world.
Local time: 10:40
2009-01-06 by Stefan Trethan
I can't actually give you the requested exact ratios since i built my
etchant bit by bit and do not know them.
However, i think you will have to do the same, since at least the H2O2
must be added gradually. At first there would not be enough Cu2Cl2 to
oxidise, so much of the H2O2 would dissipate.
The copper should be thin pieces, like sheets or stranded wire.
Electrode nuggets may take forever to dissolve.
A hydrometer is not for measuring humidity, that is a hygrometer and
many people are simply mistaken.
A hydrometer is used to measure fluid density, it is a glass tube,
with a weight at the bottom end and a scale at the top end. The higher
the hydrometer floats the denser the liquid is and you can read this
on the scale (the water line is the pointer). The ones sold to test
car battery acid cost only like 2 eur and are just about sufficient.
I recently bought a refractometer from china, for like 20eur. It is
also designed to measure car battery acid, but it tried it with
etchant and it seems to work. The refractometer is an optical
instrument where you place a drop of liquid on a prism and the
refraction coefficient is measured (Brechungsindex for you). You look
into it like in a telescope. It is very quick, accurate, and less
messy than the hydrometer in my opinion. But it does measure optical
density, not physical density, as long as the two correspond there is
no problem though. Also, of course, it is a measuring instrument and i
just had to have one, no matter what.
You only need the hydrometer to see how much copper there is in the
etchant. There's an ideal density range for this etchant where you get
the best speed.
Another analysis tool you should have is a way to determine the HCl
concentration in the etchant. This can be done by titration with NaOH
and methylorange as indicator. That's actually quite easy to do, but
not really needed that often.
Bubbling, yes you can use it for regeneration but that is dead slow.
H2O2 is more efficient. I just use bubbling to agitate the etchant so
it is quicker and more even. You definitely want some form of
agitation, CuCl is not the fastest etchant if you do not push the
chemical parameters into the ideal range.
ST
On Tue, Jan 6, 2009 at 10:02 AM, Markus Zingg
> TIA
> Markus
Stefan,
Thanks for your information. Still some more questions :-)
- Can you give a ratio to at least start? I mean how much HCL and H2O2
should I use for the first "run"?
- Do you have a link to the refractometer? Cause at that cost, I
probably also would apreciate to avoid the mess involved with a hygrometer.
- what refraction coefficient or fluid density ranges would be good for
etching?
Since I'm only makeing prototypes, I don't mind if cucl is not that
fast. The Fe3Cl I used so far is also not that fast after a couple of
boards. I'm more after a solution which etches evenly and where I don't
have waste to dispose thereafter (or as few as possible).
Markus
> the best speed.
> ST
> that do?
> > TIA
> > Markus
This is the one i bought:
<http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&item=230309376059>
I wish it had a scale just for specific gravity, down to 1.0. I don't
really care about the antifreeze scales.
1.2 to 1.4 is pretty much the range you need, and 1.0 to 1.2 is
interesting while you grow the bath. Luckily car battery acid operates
in the same range which gives us easy access to cheap hydrometers.
You MUST read these two documents from the links sections, these are
the ones where the link still work:
<http://members.optusnet.com.au/~eseychell/PCB/etching_CuCl/index.html#analysis_SG>
By our very own Adam Seychell, probably the best document about
homebrew CuCl you can find.
<http://www.xertech.net/Tech/CuCl_ech.html> Also quite interesting.
Which should also answer your question about stating quantities.
ST
On Tue, Jan 6, 2009 at 12:51 PM, Markus Zingg
> Stefan,
> etching?
> Markus
2009-01-06 by DJ Delorie
Markus Zingg <homebrew-pcb@...> writes:
> of copper into it? Correct?
Well, that's what I did.
Assuming you're using 37% HCl and 3% H2O2, it's two parts H2O2 and add
one part HCl (always add acid to water, not the other way around).
> that do?
Any copper should do.  Any "tarnish" comes off really fast as it's
pre-oxidized.
> humidity?
That's a hygrometer.  A hydrometer measures the density of liquids.
Alternately, just weigh 100ml of solution; it should weigh 120-130 g
when you're done (plain water weighs around 100g).
> Regarding the "air stone bubbler", I think I remember that one uses
> this to regenerate the solution. If so, does one have to do this
> every once in a while, or only during etching, or just before?
I run it during etching, because it also stirs the solution and helps
keep the etch even.  Otherwise, run it whenever the solution starts to
turn brownish.
2009-01-06 by kabowers@NorthState.net
As to hydrometers; it might cut down on mess to remove the "bobber"
from the tube and just drop it into the container and leave it there
all the time. It would also allow one to keep track of concentration
all the time 8:)
