Homebrew PCBs
Need a single-side prototype board made
2009-01-12 by Rick Henry
It's been prob 30 years or more since I did any PCB design and etching
and I really don't want to get back into all the stuff just to check a
single design.
I have a 3" x 16" artwork made with software that I would like to have
one or two boards made for testing and fitting.  It's almost something
that could be point to point wired, but if I like what I've come up
with, I may require 20 or 30 similar boards.  If so, I'll probably go
with a commercial route to make better looking, double sided (no
jumpers) and silk screening process at that time.
Would anybody be interested in producing a couple of boards for me?  I
know the size is a bit long, but in reality, they could be done in half
and I'll just bridge solder the boards together to test.  Looks are not
that important at this point.
Thanks.
Double to single sided board
2009-01-14 by Kurt
I was wondering, I have a pretty good stash of double sided board, but very
little single sided.
I have been using Eagle to design my boards so far, and for the sake of
simplicity, I have been trying to keep to one sided designs. Plus the fact
that I have just learned about how to make a ground plane in Eagle, there is
not too much to etch on the bottom side, and a great big field to etch away
on the top.
Has anyone come up with a way to quickly strip the copper from one side of a
double sided board?
With practice, I hope to be able to align the patterns well enough to make a
good double sided board, but for now, I have been just trying to etch it
away.
Any suggestions would be appreciated.
Kurt   WU8V
Checked by AVG.
Version: 7.5.552 / Virus Database: 270.10.6/1891 - Release Date: 1/13/2009
8:17 AM
Re: [Homebrew_PCBs] Double to single sided board
2009-01-14 by Malcolm Parker-Lisberg
Heat one corner with a hot air paint stripping gun so that you lift enough copper to be able to grab it with the pliers. Clamp one end firmly, apply the heat gun to heat just infront of the area of copper you are lifting and pull on the copper to remove it. The price you pay is like all soldering and electronic work is you loose your fingerprints.
--- On Wed, 1/14/09, Kurt <wu8v@...> wrote:
Subject: [Homebrew_PCBs] Double to single sided board
Date: Wednesday, January 14, 2009, 2:08 AM
on the top.
double sided board?
away.
Kurt   WU8V
Checked by AVG.
8:17 AM
RE: [Homebrew_PCBs] Double to single sided board
2009-01-14 by Kurt
Thanks Malcom, I will give that a try... it does not affect the opposite
side copper?
I always wanted to be an anonymous type anyway, thay are mostly gone, maybe
this will finally finish off those pesky fingerprints.
Thanks again...73
Kurt   WU8V
[mailto:Homebrew_PCBs@yahoogroups.com]On Behalf Of Malcolm Parker-Lisberg
  Sent: Wednesday, January 14, 2009 11:20 AM
  Subject: Re: [Homebrew_PCBs] Double to single sided board
very
is
away
  on the top.
a
  double sided board?
a
  away.
  Kurt WU8V
  Checked by AVG.
  8:17 AM
Checked by AVG.
Version: 7.5.552 / Virus Database: 270.10.7/1893 - Release Date: 1/14/2009
6:59 AM
Kurt
Don't overheat as you are more likely do damage the laminate surface on the side you are removing copper from than the underside. If you get it too hot you may cause the board to curl. I have used this method many times to obtain bare board make electrically insulating terminations.
Subject: RE: [Homebrew_PCBs] Double to single sided board
Date: Wednesday, January 14, 2009, 7:23 PM
side copper?
Thanks again...73
Kurt   WU8V
[mailto:Homebrew_PCBs@ yahoogroups. com]On Behalf Of Malcolm Parker-Lisberg
  To: Homebrew_PCBs@ yahoogroups. com
very
is
away
on the top.
a
double sided board?
a
away.
Kurt WU8V
Checked by AVG.
8:17 AM
Checked by AVG.
6:59 AM
Re:Double to single sided board
2009-01-14 by Lee Studley
You could paint the unused side with clear lacquer or polyurethane, etch
the trace side, then
make an isolation drill bit. Where ever you need a through-hole item,
drill the hole from the trace side, then on the
other lacquered side use the isolation bit to scrape/make a pad on the
other side.
This way the lacquered side can also be a big ground plane and wont need
to be etched away, wasting etchant.
2 ways to make a isolation bit:
1) if you are good with a dremel, use a disc or grinding bit and grind
the tip of a spare drill bit so that the cutting edge is slightly a W
with the center able to go into the tiny hole, and the outer W legs able
to cut the pad. Be careful or it will cut all the way thru.
2) Use a large enough drill bit that can be centered in the hole, but
the V of the cutting edges is wide enough to give about a 1/16" or 1.5mm
wide insulating crater in the the PCB. Turn the drill bit by hand or
carefully in a drill press.
-Lee
[Homebrew_PCBs] solder paste stencils
2009-01-16 by Mark Lerman
I'm working with some QFN leadless components and I want to make
solder paste stencils to apply solder paste before putting them in my
toaster oven reflow solderer. I want to just drill holes in some very
thin (.008) laminate and align it with 000 screws, then smear solder
paste over it with a flat blade. Does anyone have any guidelines for
volume of solder paste for various size ic contacts? Thanks for any
links or advice!
Mark
Re: [Homebrew_PCBs] solder paste stencils
2009-01-16 by James Bishop
I've soldered a couple of qfn's by simply laying a 'sausage' of solder
paste in a line across all the pads, and then reflowing in an old
frying pan on my gas stove, and it worked fine! The sausage would have
been around 0.5mm thick, I tihnk (my paste came in a syringe-type
dispenser). With this amount the solder will happily flow onto the
pads, the part should align itself, and I didnt have any problems with
shorts.
There is some good info on diy reflow soldering here:
http://www.sparkfun.com/commerce/tutorial_info.php?tutorials_id=59
http://www.sparkfun.com/commerce/tutorial_info.php?tutorials_id=58
The quantity of paste is defined by the size of the hole in the
stencil, and the thickness of the stencil. Check the ic manufacturer's
datasheets. Here is a random datasheet from TI for a QFN-48, it
specifies the dimensions of the holes and the thickness of the stencil
(2nd last page):
http://focus.ti.com/lit/ds/symlink/tps65010.pdf
> links or advice!
> Mark
Re: solder paste stencils
2009-01-19 by derekhawkins
This would be commercial stencil thickness x the area of the SMD pad.
You can calculate pad areas from data sheets. In your case it would be
stencil thickness x pi x r^2 where r (half the diameter) would be the
radius of your drilled hole.
You can see that if your drilled stencil thickness is slightly greater
than that of a commercial stencil then this would compensate for
smaller circle area. That's the theory but in practice the solder paste
volume isn't all that critical. Don't waste your time trying to be too
exact.
http://www.pbase.com/eldata/stencils
--- In Homebrew_PCBs@yahoogroups.com, Mark Lerman <mlerman@...> wrote:
Re: Need a single-side prototype board made
2009-01-19 by Steve
I see someone hijacked your thread. Please, people, when starting a
new thread, don't do so by replying to another message. Even when you
delete all traces of the old thread that you can see, Yahoogroups
manages to link them to the old thread. Just put the group address in
your address book and start a new message.
As to your topic- for that number of boards, you might consider going
to one of the board houses. Many offer relatively low prices on a few
to start with. Check the links under "Commercial PCB Prototypers".
http://tech.groups.yahoo.com/group/Homebrew_PCBs/links
Steve Greenfield
--- In Homebrew_PCBs@yahoogroups.com, "Rick Henry" <hitophikers@...>
> single design.
> Thanks.
