Homebrew PCBs
Electroplating and VIAs
2009-01-19 by Juan EA7FNJ
Hi guys!
I'd like to make the vias of my board and I think the best method is
electroplating. But, I was looking for some information about it, and
I didn't find something that I can understand.
My question:
How can I make a good vias using electroplating? I was reading and I
have some ideas: clean the copper side of my PCB, use an acid bath,...
But I don't know how many volts and amps to make it, concentrations...
is there any good manual step-by-step?
Thanks.
Re: [Homebrew_PCBs] Electroplating and VIAs
2009-01-19 by J Deringer
There are several methods to choose from, here's a video demonstrating one of them.
Pay close attention to safety instructions. This should give you an idea of what is involved, so you can decide if its something that you want to try, or if it would be better to have it done.
http://hackaday.com/2008/07/28/how-to-etch-a-single-sided-pcb/
--- On Mon, 1/19/09, Juan EA7FNJ <esp7xx@...> wrote:
Subject: [Homebrew_PCBs] Electroplating and VIAs
Date: Monday, January 19, 2009, 4:00 AM
            Hi guys!
My question:
But I don't know how many volts and amps to make it, concentrations. ..
Thanks.
Re: Electroplating and VIAs
2009-01-19 by Steve
Have you checked the Links under "Plated Through Holes" yet? Not many
links there, but it is something. Markus Zingg's page on through hole
plating has been down for a while, but I just found where someone
mirrored it and put that link in place of the missing site.
http://tech.groups.yahoo.com/group/Homebrew_PCBs/links
If you find any other links on through-hole plating, please place them
there.
Steve Greenfield
--- In Homebrew_PCBs@yahoogroups.com, "Juan EA7FNJ" <esp7xx@...> wrote:
> Hi guys!
> My question:
> Thanks.
Hi guys!
Ok, great machine! but, I can see how to make one but, where is the
manual 'how to use it'?
xD
> there.
> Steve Greenfield
Re: [Homebrew_PCBs] Re: Electroplating and VIAs
2009-01-19 by Markus Zingg
Juan,
How to use it greatly depends on the chemistry used. The chemistry even
defines howmany tanks you need, wether they are heated, the processing
parameters etc. etc. My best advice to you is to first organize a
chemistry, cause it's supplier will be able to tell you the processing
requierements. Then build your station along them.
HTH
Markus
Juan EA7FNJ schrieb:
> Hi guys!
> xD
> <http://tech.groups.yahoo.com/group/Homebrew_PCBs/links>
> > there.
> > Steve Greenfield
2009-01-19 by Simão Pedro Cardoso
I have operated a plating pcb line in the past. The people there just
buy a box of chemicals from a supplier and made the boards. The chemical
supplier just ripped the manufacturers name from the chemical label and
placed their own name. This chemical sets are available from many places
(locally cost 400eur) and are easy to operate, the machine is just some
plastic tanks with 2 of them heated, one with air pump and a 3-6V 40A
psu, and a simple agitation moving the board holder from left to right
and back again.
I never read what was on Markus Zingg's page or others but the chemical
set seems easy to understand and from a lot of what i am been reading it
seems easy to make all the chemicals from any local store. From car
anti-freezer, ammonium, caustic soda, fine table salt, hydrochloric
acid, tin solder wire, wine pH neutraliser, sulphuric acid, copper parts
and a fertilizer bag (just the plastic bag clean for filter). I think it
can be done but still didn't test.
It has a resin desmear bath made with resin etch and solvent to etch fr4
resin inside the hole in a two components complex of anti-freezer, a
bath to kill the remaining of the first based on acid salt, a activation
bath made with tin colloidal, a ph neutraliser and the normal sulphuric
acid copper plating with phosphorizated copper and anode bags. From what
i understand of course.
The secret is making the holes electrical conductive before copper plating.
Another thing is the copper anode bags, they act as filters. If not used
the copper is plated in big chunks and deposits on tank, eating the
copper anode in less than 50% efficiency.
I will make some tests and give them here, but from
http://nr.stpi.org.tw/ejournal/proceedingA/v23n3/365-368.pdf
You can read was used in the past tin lead colloidal as activation bath,
so my idea is put pieces of tin/lead solder wire in hydrochloric acid
let the solder dissolve in bath add water to make 1% acid solution and
place the drilled and clean board there for 5min. Then try to plate in
the sulfuric acid copper bath at 30mA per square cm by half hour and see
if the copper plates inside the holes.
Simao
Juan,
HTH
Markus
 > Hi guys!
 > xD
 > <mailto:Homebrew_
 > > there.
 > > Steve Greenfield
2009-01-20 by Simao Cardoso
I have just remembered other thing, once i read from some already dated
IPC documents, a way to activate the holes, beautiful for it simplicity.
Not much info just named and short explained, and that was still in
development.
It consists in activate while drilling. The drill bit, make de hole and
then entered in a metallic bath, when exit the hole will place the
metallic components in the hole wall, while still rotating.
Because all the dust made while drilling it should be better to drill
and clean first and then redrill with a tin or silver or other type
solution, in a soft cloth or so under the board.
It can be an old, forgotten and bad results experiment, i just remember
to name it here.
Simao
Markus Zingg wrote:
 > Juan,
 > HTH
 > Markus
 > > Hi guys!
 > > xD
them
 > > > there.
 > > > Steve Greenfield
2009-01-20 by Juan EA7FNJ
Hi guys!
Well, my problem is the chemistry: I would like to find a good guide
about electroplating, but I don't find anything.
Do you know about a good guide?
73
--- In Homebrew_PCBs@yahoogroups.com, Simao Cardoso <simaocardoso@...>
simplicity.
> development.
> to name it here.
> Simao
> Markus Zingg wrote:
>  > Juan,
chemistry even
processing
processing
>  > HTH
>  > Markus
>  > > Hi guys!
>  > > xD
>  > > <mailto:Homebrew_PCBs%40yahoogroups.com>, "Steve" <alienrelics@>
Not many
through hole
place
> them
>  > > > there.
>  > > > Steve Greenfield
The problem seems there isn't any. Manufactures and resellers make a lot
of money from this. You will only find the 'users manual'. The most
'newbie' thing out there is Markus Zingg page that is not found
googling. (available on links here, thanks!)
My starting point was those manuals and MSDS from megauk, and some other
manufactures easyly find googling. Then I read what pcb's manufactures
say about they process in about 250 boardhouse webpages. Then google
about those process. Found almost nothing, except patents and so. The
link i give in the last post about pcb hole plating activation history
is the most valuable thing i found.
So
http://www.megauk.com/datasheets/5050_Data_Sheet_ABC_Panel_Plating_Instructions_(ver.11.08).pdf
http://www.thinktink.com/stack/volumes/volvi/copplate.htm
http://electrochem.cwru.edu/ed/encycl/art-e01-electroplat.htm
These are the things that more worth the time reading.
The baths are desmear-activation-platting, and have rinse and cleaners
baths between them. But for few homemade board activation and plating is
enough.
Activation is the most tricky part but is can be done in chemical bath
of many compositions i already told a mechanical way that can work...
and found another way.
Sodium metal is made from electrolysis of salty water. If you could make
an electrolysis between the two copper layers in a sodium bath of NaOH,
NaCO3 etc (NaCl shouldn't work) maybe it can leave the sodium inside the
hole. You need an high impedance power supply for this, limiting current
should be used. When the board short circuits it should be plated inside
the holes. (My guess)
Simao
Juan EA7FNJ wrote:
 > Hi guys!
 > 73
 > simplicity.
 > > development.
 > > to name it here.
 > > Simao
 > > Markus Zingg wrote:
 > > > Juan,
 > chemistry even
 > processing
 > processing
 > > > HTH
 > > > Markus
 > > > > Hi guys!
 > > > > xD
 > Not many
 > through hole
 > place
 > > them
 > > > > > there.
 > > > > > Steve Greenfield
2009-01-21 by Mark Lerman
I found
<http://www.lpkfusa.com/RapidPCB/ThroughHolePlating/proconduct.htm>
very interesting. They have a paste that is essentially squeegeed
into the holes, vacuumed out to clear the center of the hole,  then
baked in an oven to cure. They have a kit,l but the active paste is
available for $240 for 20 of the 2.5 gm packages. Not cheap, but not
too bad, especially if you can reuse open packets.
Mark
>So
>enough.
>Simao
>Juan EA7FNJ wrote:
>  > Hi guys!
>  > 73
>  > simplicity.
>  > > development.
>  > > to name it here.
>  > > Simao
>  > > Markus Zingg wrote:
>  > > > Juan,
>  > chemistry even
>  > processing
>  > processing
>  > > > HTH
>  > > > Markus
>  > > > > Hi guys!
>  > > > > xD
>  > Not many
>  > through hole
>  > place
>  > > them
>  > > > > > there.
>  > > > > > Steve Greenfield
>Be sure to visit the group home and check for new Links, Files, and Photos:
>http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
2009-01-21 by trevwhite74
Someone recommended 'circuitworks CW2400 Conductive Epoxy' as an
alternative to this and it is cheaper. I have some but not had chance
to use it yet.
Trev
--- In Homebrew_PCBs@yahoogroups.com, Mark Lerman <mlerman@...> wrote:
> I found
Eyelets? (WAS: Re: Electroplating and VIAs)
2009-01-21 by flightofharmony
Out of curiosity, has anybody used the old-fashioned eyelet approach?
Definitely not worthwhile for production, but it would be very handy
for DIY.
2009-01-21 by Bob_xyz
--- In Homebrew_PCBs@yahoogroups.com, "flightofharmony" <flight@...>
> for DIY.
As long as you don't have too many of them, I've found that it's
fairly quick and easy to 'stitch' vias using a length of stripped
wire-wrap wire. After running the wire through the vias (going back
and forth from one side of the board to the other), I solder the vias
and then use an Xacto knife to cut the wires at the via pad edges.
If the length of wire required is difficult to work with, you can
always stop the stitching and start again with a new piece of wire.
Regards, Bob
2009-01-21 by Simao Cardoso
Mark Lerman wrote:
 > I found
 > Mark
There is similar things from thinktink and others, they all seem
carbon/silver curable inks. They are for make the vias conductive also
without plating after.
There is also who tried the use of and silver based car motor radiator
hole repair liquid. The bottle was cheaper but he conclude, because of
the less quantity of conductive material wasn't that cheap after all.
 > >So
and also
http://findarticles.com/p/articles/mi_qa3751/is_200501/ai_n9521082
http://www.ecitechnology.com/articles/Detection_of_Accelerator_Breakdown_Products_in_Copper_Plating_Baths.pdf
about adictives
Sodium and water :D It could be simpler but NO CAN DO.
Sodium metal is made from electrolysis of melted NaCl.
I just wrote that to see if someone was reading it :$  ;)
 > >Simao
 > >Juan EA7FNJ wrote:
 > > > Hi guys!
 > > > 73
2009-01-21 by Stefan Trethan
Actually i started a reply, observing that it couldn't work because
when the first hole is connected plating would stop, and all the holes
are parallel. But then i noticed there are so many problems with this
idea it was pointless to reply.
ST
Re: [Homebrew_PCBs] Eyelets? (WAS: Re: Electroplating and VIAs)
2009-01-21 by Harvey White
>for DIY.
Yes.
I find it useful for vias, but I don't use the eyelets (too big, need
about 0.051 hole) for parts leads, although I could for RL07 size (1/4
watt) parts.
I take care to solder and make sure that the solder covers the entire
top (flared) part of the eyelet as well as bridges to the pad, and the
lower (swaged) part of the eyelet is also soldered as well.  So far, I
have not had problems with thermal stress and breaking of bonds.
I have tried pins, and find them less satisfactory.
Harvey
2009-01-21 by JanRwl@AOL.COM
In a message dated 1/21/2009 1:32:02 P.M. Central Standard Time,
flight@... writes:
Definitely not worthwhile for production, but it would be very handy for  DIY.<<
I do that where the holes are "under" IC-sockets, etc., and MUST be almost
PTH.  For others, "out in the open" I use bits of wire, soldered on both  sides.
Use NEW, brightly-tinned eyelets, and sweat-solder them to the TOP pad
before populating board!
**************From Wall Street to Main Street and everywhere in between, stay
up-to-date with the latest news. (http://aol.com?ncid=emlcntaolcom00000023)
2009-01-21 by Juan EA7FNJ
Hi guys!
I've just found this video: http://es.youtube.com/watch?v=djr1KmtAYKg
To activate the holes: why don't use copper dust with some disolte
varnish?
I think there is some 'poor man' solution, cheap and low cost hi hi
wrote:
> Mark Lerman wrote:
>  > I found
>  > Mark
>  > >So
> and also
> about adictives
could make
of NaOH,
inside the
current
plated inside
>  > >Simao
>  > >Juan EA7FNJ wrote:
>  > > > Hi guys!
good guide
>  > > > 73
2009-01-22 by Mark Lerman
Is anyone interested in buying some of the LPKF ProConduct to try? If
enough of us are, I would be willing to purchase the 20 packets and
resell them individually at cost. Let me know off list -
Mark
At 09:53 AM 1/21/2009, you wrote:
>I found
>Mark
> >So
> >enough.
> >Simao
> >Juan EA7FNJ wrote:
> >  > Hi guys!
> >  > 73
> already dated
> >  > simplicity.
> >  > > development.
> de hole and
> just remember
> >  > > to name it here.
> >  > > Simao
> >  > > Markus Zingg wrote:
> >  > > > Juan,
> >  > chemistry even
> >  > processing
> >  > processing
> >  > > > HTH
> >  > > > Markus
> >  > > > > Hi guys!
> where is the
> >  > > > > xD
> >  > Not many
> >  > through hole
> where someone
> >  > place
> >  > > them
> >  > > > > > there.
> >  > > > > > Steve Greenfield
2009-01-22 by trevwhite74
Did you watch the videos on how to apply this stuff? You need some
film/foil to cover the holes and then drill them out before applying
the paste. Then it seems it needs to be cured as well afterwards. Have
you got a plan of attack on how to do this?
As said the circuitworks CW2400 stuff appears to be very similar and
is a lot cheaper as you can buy it for something like $30. You will
still need to go through the same application process as the LPKF
ProConduct.
> Mark
I have several thoughts on this. I mill my boards, so the simplest
thing would probably for me to do it the same as the video. I'm
pretty sure I can find something to coat the board, perhaps
laminating plastic (?), then drill the holes, squeegee on the paste.
I would then probably blow out the holes rather than vacuum them out.
To save on the paste, I might put it in a syringe and pack each hole
individually, then refrigerate the remaining paste. Obviously there
is some experimentation to be done.
Since LPKF is selling the stuff, I assume it actually works and they
list the conductivity. I'm a bit nervous about the CW2400 because I
haven't found anyone who actually has used it and demonstrated that
it actually works and has low conductivity.
Mark
>ProConduct.
> > Mark
Yeah, agree with your thinking. CW2400 was recommended by a chap in
America who has an LPKF milling machine and has used it. I do not know
quite how reliable,etc his results are but he did sound to really like
it. He said he was going to send me some pictures of his work but I
have not heard off him yet.
2009-01-22 by Juan EA7FNJ
Hi guys!
Conductive glue: http://www.inklesspress.com/conductive_glue.htm
Can it work to 'activate' the holes and electroplate the vias?
any idea?
--- In Homebrew_PCBs@yahoogroups.com, "trevwhite74"
2009-01-22 by roycepipkins
Wow! What a simple and easy idea. I've been fussing with individual
lengths of wire for each via. I feel like a dolt now!
Anyway, thanks for the post I will definitely give stitching a try.
Royce
--- In Homebrew_PCBs@yahoogroups.com, "Bob_xyz" <bob_barr@...> wrote:
> --- In Homebrew_PCBs@yahoogroups.com, "flightofharmony" <flight@>
> > for DIY.
> Regards, Bob
2009-01-22 by Stefan Trethan
Never mind, you are in good company of other dolts.
My first thought was the same as yours when i read about the method.
My second thought was that'll waste a lot of wire. OK absolutely
worthless wire i can just grab out of the trash, but still ;-)
ST
> Regards,
> Royce
Got to admit I am actually feeling a bit dumb too. The stitching
aproach really makes so much sense and speeds things up so much. I can
not believe I used to do each via seperately. Doh.
Trev
2009-01-22 by Lee Studley
Goto ThinkAndTinker
http://www.thinktink.com/stack/volumes/volvi/condink.htm
Been doing similar for years.
-Lee
2009-01-22 by DJ Delorie
Stefan Trethan <stefan_trethan@...> writes:
I thought that too.  Then I realized that speaker wire, stripped and
strands separated, yields a lifetime supply of cheap via wires...
2009-01-22 by leon Heller
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Thursday, January 22, 2009 8:13 PM
Subject: Re: [Homebrew_PCBs] Eyelets? (WAS: Re: Electroplating and VIAs)
I bought a reel of 28 swg tinned copper wire a few years ago. I use it for
links on the top of the board as well as for vias. It'll see me out, and
then some!
Leon
I always find it hard to separate stranded wire because it is twisted
together. It knots up after only a short length.
However i think i have rescued a couple reels of just the right stuff,
and stashed it safely. That must be a few kilometers, enough for the
immediate future ;-)
ST
What I did was strip the insulation off the last 5 inches of the wire,
then cut off the exposed strands.  That lasts a while, then strip and
cut more, etc...
