Homebrew PCBs
Hmm, bead blasting?
Hmm, bead blasting?
2009-03-12 by flightofharmony
I've been pondering methods to improve/hasten/detoxify homemade PCBs, and had a thought occur yesterday: bead blasting. has anybody tried this or seen it done?
There are numerous types of photosensitive laminate out there, including hardier varieties created specifically for blast-etching. The same goes for blasting media, which is available a wide range of hardnesses and bead/shot size and shape.
Of course, really high density, fine-pitch traces may be quite difficult to do, but that's about the only real drawback I have been able to see so far. There are even mini-tabletop blasting chambers (or you can just do it outside if you feel like constantly buying new media).
Another cool possible benefit is to use it to drill! You would probably need to do the drill-blasting before the trace-blasting, and would need a drill stencil (I'm thinking a brass or nylon mask like a solder stencil but for the holes) and a jig to hold the nozzle perpendicular to the board. Adhere the stencil to the board (so the blast media doesn't creep between) then, using a fine hard grit, blast the holes. Then peel off the mask, use the photoresist as usual and blast the copper.
I'm sure it would be fun to try if nothing else. :)
~flight
RE: [Homebrew_PCBs] Hmm, bead blasting?
2009-03-12 by Tony Smith
had a
done?
hardier
blasting media,
shape.
to do, but that's
even mini-
constantly
> buying new media).
need to do the
(I'm thinking a
hold the nozzle
media doesn't
off the mask,
Why not a water jet?  :)
The media usually isn't that fine, and anything capable of wearing away the
copper layer, and FR4 would probably eat thru the stencil as well.
That's not to say it can't be done, but you're going to need better gear
than what the typically hobbyist has, such as very fine media, tiny nozzles
and very high pressure (blasting is typically done at 60-100 PSI).
Tony
Re: [Homebrew_PCBs] Hmm, bead blasting?
2009-03-14 by William Alford
yes, i do art glass carving and have such equipment. bead blasters
will not cut materials and are used to clean motor parts, etc.
silicon carbide (sand) blasters will quickly cut brittle substrates
like glass, ceramics, etc but will only surface etch metals. it would
not cut through the copper foil, but likely would attack the fiber
board. the mask for sand carving must be very aggressive to withstand
the blast, typically plotter-cut vinyl or photosensitive resists. the
air pressure for 'pressure pot' blasting is hardly ever over 30 psi
while 'siphon' blasters use much higher pressure and air flow. also
you must use a blast chamber/dust collection system to contain the
dust or risk silicosis of the lungs. good thought, but won't hasten
and has some toxic attributes.
William Alford
GI Motility Medical Research Page
http://alford.grimtrojan.com/
Re: Hmm, bead blasting?
2009-03-14 by Steve
I can't say enough to warn about silicosis. Tiny bits of sharp glass that you can't cough out, that slowly work their way through your lungs, scarring and hardening the tissue. Your body can't eject it, encapsulate it, or absorb it.
In many ways, worse than smoking because one early exposure will theoretically keep causing damage your entire life.
Steve Greenfield
