Homebrew PCBs
GBC H535 Laminator
GBC H535 Laminator
2009-05-02 by michael tenore
Hi All1
I just bought a GBC H535 laminator from eBay for $95 with shipping!
Is anyone using this for Toner Transfer?
I think I got a good deal on this as others were listing them for between $300 and $450.
The seller listed it as us3ed but good condition!
I ws surprised no one else bid for it/
Thanks
73
Mike
Re: GBC H535 Laminator
2009-05-02 by trevwhite74
Yeah, I managed to buy one here in the UK. It was a similar price, maybe a little bit more. I paid £70 delivered but it was a bargain as there were a few on sale for around £200 and new they seemed expensive. I have used it a little and it is just fantastic. Feels really solid and heats up nicely. Pretty happy with it.
Trev
--- In Homebrew_PCBs@yahoogroups.com, michael tenore <wb2lcw@...> wrote:
> Hi All1
> Thanks
> 73
> Mike
2009-05-02 by sailingto
Any idea how hot the GBC H535 laminator gets?  I'm using a Brother 2140 laser printer and the toner seems to require pretty high temperature.  I do the toner transfer in a toaster oven at about 450F for 10 minutes to get a good transfer.
Thanks for any info.
73 de Ken H> K9FV
--- In Homebrew_PCBs@yahoogroups.com, "trevwhite74" <trevor.white100@...> wrote:
> Trev
> --- In Homebrew_PCBs@yahoogroups.com, michael tenore <wb2lcw@> wrote:
> > Hi All1
> > Thanks
> > 73
> > Mike
Re: [Homebrew_PCBs] Re: GBC H535 Laminator
It has been said in other post's that the Brother toner needs a very high temperature!And is not recomended
I have a HP 1200 laser printer ($25 Craigslist)and using HP Presentation paper($13 Staples)
 it is very easy to get a excellent transfer with my dry iron and only about two to three minutes of ironing.
I have not had a single bad transfer using this HP paper!
73
Mike
Sent: Saturday, May 2, 2009 10:52:29 PM
Subject: [Homebrew_PCBs] Re: GBC H535 Laminator
73 de Ken H> K9FV
--- In Homebrew_PCBs@ yahoogroups. com, "trevwhite74" <trevor.white100@ ...> wrote:
> Trev
> --- In Homebrew_PCBs@ yahoogroups. com, michael tenore <wb2lcw@> wrote:
> > Hi All1
> > Thanks
> > 73
> > Mike
2009-05-03 by Brian Gracia
Mike,
Do you have a model or reference # for this paper?  What type of
paper is it, Photo?
Brian
>73
>Mike
2009-05-03 by drmail377
Hi Mike, What is the part number for the paper you mentioned? I see two possibilities at Staples. Judging by the price you mentioned, it is probably the first one listed below. I looked on the HP site and both types are for laser printers, not ink jet. 73's David
HP P/N Q2546A
HP Color Laser Presentation Paper
A bright, glossy paper that offers superior quality and reliability
$13.99 for 300 pcs.
HP P/N Q6541A
HP Soft Gloss Presentation Laser Paper
Double-sided soft gloss finish for rich, vibrant colors and graphics on both sides
$15.70 for 200 pcs.
> 73
> Mike
> From: sailingto <sailorman@...>
> 73 de Ken H> K9FV
> > Trev
> > > Hi All1
> > > Thanks
> > > 73
> > > Mike
2009-05-03 by michael tenore
Hi!
HP Presentation paper 130g Glossy, Product  Q2546A
Some one else in this group said he used it with great success and he is right!
I hope you will be as happy with it as I am!
When using glossy paper you can get trace and pad spreading from too much heat and pressure!
This is not a problem with Photo paper but this  HP Presentation paper seems not to have this problem.
73
mike
tome glossy papers will om: Brian Gracia <briangracia@...>
Sent: Saturday, May 2, 2009 10:59:03 PM
Subject: Re: [Homebrew_PCBs] Re: GBC H535 Laminator
Mike,
paper is it, Photo?
Brian
>high temperature! And is not recomended
>73
>Mike
Yes Q2546A is the right one
73
Mike
Sent: Sunday, May 3, 2009 11:04:35 AM
HP P/N Q2546A
$13.99 for 300 pcs.
HP P/N Q6541A
$15.70 for 200 pcs.
--- In Homebrew_PCBs@ yahoogroups. com, michael tenore <wb2lcw@...> wrote:
> It has been said in other post's that the Brother toner needs a very high temperature! And is not recomended
> 73
> Mike
> ____________ _________ _________ __
> From: sailingto <sailorman@. ..>
> To: Homebrew_PCBs@ yahoogroups. com
> 73 de Ken H> K9FV
> > Trev
> > > Hi All1
> > > Thanks
> > > 73
> > > Mike
2009-05-04 by flightofharmony
Yup, Q2546A. Works excellent!
Spreading/pressure: Yes, the toner DOES spread easily with this paper (I'm pretty sure it has to do with the thermal transfer rate of the paper and its thickness).
You don't need much pressure at all with the Q2546A - you don't WANT much pressure at all - the weight of the iron is usually enough.
> Hi!
> 73
> mike
> Mike,
> paper is it, Photo?
> Thanks,
> Brian
> >73
> >Mike
2009-05-04 by Piers Goodhew
Having recently switched from 220gsm paper to 150 (60 to 40 lbs
roughly), the shift was surprisingly large: from as-hot-as-it-can-go-
and-push-real-hard to just-medium-iron-and-work-it-up-and-down-a-few-
times.
Sometime this week DJ Delorie said "you just want to make the toner
sticky, not melt it", so I'm going for a less-heat-more-pressure
approach. And, I think, getting reasonable results.
PG
> wrote:
> > Hi!
> he is right!
> > 73
> > mike
> > Mike,
> > paper is it, Photo?
> > Thanks,
> > Brian
> very
> > >73
> > >Mike
2009-05-05 by drmail377
Thanks Mike, I live outside the USA, so it is hard to come by the Q2546A product. However I think these two products available to my locale might be the same but 120 gsm instead of 130 gsm. Has anyone tried this paper?
HP Professional Laser Paper 120 Glossy
Bright white for high-contrast colour images and photos Professional-weight paper that looks and feels impressive two-sided, coated gloss finish for eye-catching images and vibrant colours on both sides
HP Q6547A, A4 size, 120 gsm, 200 sheets
HP Q6548A, A3 size, 120 gsm, 200 sheets
> 73
> Mike
> From: drmail377 <drmail377@...>
> HP P/N Q2546A
> $13.99 for 300 pcs.
> HP P/N Q6541A
> $15.70 for 200 pcs.
> > 73
> > Mike
> > From: sailingto <sailorman@ ..>
> > 73 de Ken H> K9FV
> > > Trev
> > > > Hi All1
> > > > Thanks
> > > > 73
> > > > Mike
GBC H535 Laminator
2009-05-06 by michael tenore
Hi !
I recieved my GBC H535 laminator today from UPS and I checked out the manual!
It says the maximum passtrough thickness is .1 inch 2.54mm.
I willl not have a board to try out for a couple of days.
The max temperature so far is 338 degrees F. But the speed is variable.
Stay tuned
Regards Mike
2009-05-07 by sailingto
Good deal Mike - we will "stay tuned".  What printer/toner are you using?
As you saw from an earlier post, I'm VERY interested in a laminator that will work with the Brother 2140 printer.  That toner seesm to require a higher temperature than normal toners. There is a label inside the cover on the printer that says "Caution - 415F" and shows the toner as "TN-330/TN-360"
Does anyone know what that toner label means?  Are there two types of toner?
Thanks to all for any info.
73 de Ken H>
> Hi !
> Stay tuned
> Regards Mike
2009-05-07 by DJ Delorie
"sailingto" <sailorman@...> writes:
> that will work with the Brother 2140 printer.  That toner seems to
If you want to mail me a sample print (or one page with a couple of
smaller prints), I can run it through my laminator and see.  Mine has
been hacked to include a temperature controller, so I can make it
hotter than normal, which seems to help with my toner.  Doesn't need
to be on fancy paper or mailed flat; it either sticks or it doesn't.
http://www.delorie.com/electronics/laminator/
2009-05-07 by michael tenore
Hi ! am using a HP2100 ($25 Craigslist) and a Xerox 2125! Both are execellent!
Why dont you look on craigslist for a Used HP laserjet. In New York there are dozens available cheap!
I even found a HP laserjet 4 in the trash across the street the other day.
HP4's and HP 5MP with postscript are easlily found! and genuine HP toner is going cheap..
even on eBay!
My HP 2100 transfres easily with HP presentation paper in only a minute or so.
73
Mike
Sent: Thursday, May 7, 2009 12:46:49 PM
73 de Ken H>
> Hi !
> Stay tuned
> Regards Mike
New York much have a LOT more than here in Fairhope, AL - not too many on Craig's List - been watching that list some before I purchased the new Brother 2140 for $60 shipped.  Then next day after placing the order, I discovered the high temperature toner it has.
Ken H>
