Homebrew PCBs
Silk screening solder resist
2009-06-14 by mycroft2152
There is a new silk screening kit for crafters and soccer moms called the Yudu. At $299 it is a bit expensive.
It looks like a real no brainer.
It uses a photo based process and there is some very forgiving technology in it and the supplies are available at your local craft store (Michaels).
I am thinking that it could be used to silk screen solder mask. Or at least use the film and a smaller silk screen.
Myc
Re: [Homebrew_PCBs] Silk screening solder resist
2009-06-14 by leon Heller
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Sunday, June 14, 2009 2:27 PM
Subject: [Homebrew_PCBs] Silk screening solder resist
I don't really se the point, I get very few problems with solder bridging on
my home-made PCBs, even with fine-pitch (0.5 mm) devices.
Leon
2009-06-14 by Myc Holmes
Leon,
It's a personal preference.
Some people like the "look" of a green solder mask, and it does protect the
copper traces form oxidation and shorting.
It is also another tool in the pcb making kit.
Myc
On Sun, Jun 14, 2009 at 9:40 AM, leon Heller <leon355@...> wrote:
> From: "mycroft2152" <mycroft2152y@... <mycroft2152y%40gmail.com>>
> To: <Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs%40yahoogroups.com>>
> (Michaels).
> on
> Leon
Re: Silk screening solder resist
2009-06-14 by a3v03v0
It is a nice setup in that you have everything needed for silk screening in one compact unit.
The main issue with making PCBs via silk screening is alignment.
Without some provisions for aligning the work with a known reference
it is difficult to print in the right place.
You can make a silk screen setup for PCB work.  There should be a lot of good info on basic screen printing on the web and in books.  The major cost would be chemicals.
The video does show the messy part. Mostly you have to rinse/clean the screens out.  It is a lot of cleanup for 1 or 2 boards.
The toner transfer system from PulsarProFx can be used both for etching PCBs and doing silkscreen (like) graphics. As far as I know it can not do a true solder mask.
Daniel Johnson
aka 3v0
--- In Homebrew_PCBs@yahoogroups.com, "mycroft2152" <mycroft2152y@...> wrote:
> Myc
Re: [Homebrew_PCBs] Re: Silk screening solder resist
Creating a solder mask, (for those who want to do one Leon}, has always been
a challenge.
There is a film that can be used, an electrostic powder, or even using
Testors Apple green spray paint has worked for some.
I am sure that with a little effort a "homebrew" screen printing kit could
be made, but this does have everything in one place and supplies are easy to
purchase in small quantities.
Myc
> one compact unit.
> would be chemicals.
> true solder mask.
> Daniel Johnson
> aka 3v0
> --- In Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs%40yahoogroups.com>,
> > Myc
Various acrylic sprays can be used to provide color and protection.  I use a clear acrylic and others have used Testors semi transparent acrylic paint to fake a solder mask.
A thin coat of acrylic is a solder through coating and you can use it prior to assembling the PCB.  To a degree it will act as a solder mask.  Does not work with SMD.
I have used Fusion paint on the top side of SS PCBs prior to adding a toner transfer silk screen layer.  Next I coat with a clear acrylic to protect the toner or laminate a TRF to the toner to color the graphics.
Daniel Johnson
aka 3v0
--- In Homebrew_PCBs@yahoogroups.com, Myc Holmes <mycroft2152y@...> wrote:
> Leon,
> Myc
