Re: [Homebrew_PCBs] Re: “Dragon’s Blood ” resin reduces undercut?
2009-06-24 by Daniel Johnson
DIY is great but at some point the use of affordable products makes sense. Pulsar paper and foil are two examples of this. At $15 for 10 sheets the material cost for using the pulsar paper is $15/((8.5*11)*10 sheets) = $0.016 per square inch. Add the foil and you are still under 3 cents per square inch. Frank, the brains behind pulsar, stands behind his existing products and works to improve the process for better results. The pulsar technology also allows for toner transfer silkscreens in color other then black, and with some modification to the method decals that are just colored toner. I do not work for Pulsar. Daniel Johnson aka 3v0 --- On Wed, 6/24/09, Russell Shaw <rjshaw@...> wrote:
Subject: Re: [Homebrew_PCBs] Re: “Dragon’s Blood” resin reduces undercut?
Date: Wednesday, June 24, 2009, 4:22 AM
You could add starch to your own paper.
http://www.google.com.au/search?hl=en&q="spray+starch"&btnG=Google+Search&meta=&aq=f&oq=
http://frugalliving.about.com/od/colthing/r/Spray_Starch.htm
