Homebrew PCBs
GBC laminator Question
2009-06-24 by sailingto
Hello all, the $25 GBC Personal Laminator it says to use a carrier with the laminator - is this really needed?  I've just used a piece of paper folded around the item as a carrier.
OR is the toner transfer paper wrapped around the copper board all that is required?  It seems to feed thru just fine and isn't that the only reason for the carrier - to assure the item does not wrap around the roller and feed out the back?
Thanks to all for comments.
Ken H> K9FV
Re: GBC laminator Question
2009-06-24 by a3v03v0
A PCB does not require a carrier.
I tape the artwork to the PCB with blue painters tape.  The other side
of the PCB is bare.
A common reason for bad transfers is a laminator that is not hot enough.
If in doubt let it run longer prior to using it.  Even the units with a
ready light can get warmer if allowed to warm up for a few extra
minutes.
Daniel Johnson
aka 3v0
> Ken H> K9FV
Re: [Homebrew_PCBs] Re: GBC laminator Question
2009-06-24 by Ed Smith
The only time I use a carrier is with photo-resist to keep from contaminating the rollers with resist. Even then, only a thin paper carrier is needed.
Also, I added a foot switch to mine to stop the drive so I can carefully get everything in place before running the material. With photo-resist, it is easier to hold the film away from the board as it feeds. I get less bubbles / pinholes that way. Or, in some cases, I apply the photo-resist using a printer's brayer, then laminate.
Ed Smith
--- On Wed, 6/24/09, a3v03v0 <a3v03v0@...> wrote:
Subject: [Homebrew_PCBs] Re: GBC laminator Question
Date: Wednesday, June 24, 2009, 11:29 AM
of the PCB is bare.
minutes.
Daniel Johnson
aka 3v0
> Ken H> K9FV
Re: [Homebrew_PCBs] GBC laminator Question
2009-06-24 by DJ Delorie
I'm guessing there are two issues here:
1. Sticking to the rollers.
2. wrapping around the rollers.
#1 is solved with some paper.
#2 doesn't happen with PCBs.
