Homebrew PCBs
Re: [Homebrew_PCBs] Heating etchant: Re: “D ragon’s Blood” resin reduces undercut?
2009-06-26 by Daniel Johnson
Sodium Persulphate does not etch unless it is heated.  I have used the sponge with Ferric Chloride but most of the times I etch indoors without a hood it was too dangerous.  If you try the sponge thing you have to use a hood.
I have not tried the sponge with Sodium Persulphate.  I have not had and undercutting problems that I noticed.
--- On Fri, 6/26/09, jc805sb <jc805sb@...> wrote:
Subject: [Homebrew_PCBs] Heating etchant: Re: “Dragon’s Blood” resin reduces undercut?
Date: Friday, June 26, 2009, 5:22 AM
      --- In Homebrew_PCBs@ yahoogroups. com, Daniel Johnson <a3v03v0@... > wrote:
> I switched from ferric chloride to sodium persulphate (MG Chemicals).  It is a much easier to handle are requires somewhat less care.
> I often etch single PCBs in a glass bread pan sitting on a foam rubber block while read mail.  A slight rocking of the pan is enough to keep the etchant moving.   I heat the etchant to about 130 degrees prior to starting.  Depending on how worn out the etchant is I may have to reheat.
> One of these day I should make a real etching tank.
> The heavier the copper is the more you will have undercutting. This post on Electrotech has some images of a PCB I was working on a while back.  Compare the edges to what you are getting.
> http://www.electro- tech-online. com/chit- chat/86683- cricut-2. html#post674243
How are you heating the etchant?
Have you tried "sponging" the surface or not bothered with
trying it?
Also, do you keep your boards etching copper up, or copper down.
