Homebrew PCBs
Anybody use AQ-3000
Anybody use AQ-3000
2009-08-25 by pr0pert
Saw a water based photoresist called AQ-3000 Has anybody used it?
Did a search, there were only two posts about it and they weren't
very informative. They also have solder mask and legend ink
products. Tried to google it and didn't see a lot there either.
Product is being sold on ebay for $68 for a 1 kilo bottle. A bit
steep for me to experiment with at the moment, especially while
trying to rediscover how to turn out a decent PCB at home.
Re: [Homebrew_PCBs] Anybody use AQ-3000
2009-08-25 by leon Heller
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Tuesday, August 25, 2009 3:56 PM
Subject: [Homebrew_PCBs] Anybody use AQ-3000
I think that stuff was discussed here about a year ago. I don't think that
anyone had tried it, though. I can't see any product safety data, which is a
bit worrying.
Leon
Sent: Tuesday, August 25, 2009 4:30 PM
Subject: Re: [Homebrew_PCBs] Anybody use AQ-3000
> From: "pr0pert" <propert@...>
> a
> bit worrying.
I just found it:
http://genesismt.com/yahoo_site_admin/assets/docs/MSDS_AQ_3000_DC.17663530.pdf
Leon
Re: Anybody use AQ-3000
> bit worrying.
> Leon
There are MSDS for all their products on their website at http://genesismt.com/ under " TDS AMD MSDS "
Roger
2009-08-25 by Zoran A. Scepanovic
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
> bit worrying.
> Leon
Check: http://www.genesismt.com/
 Best regards,
 Zoran A. Scepanovic
 zastos@...
 www.zastos.com
 www.zastos.biz
 +381 63 609-993
 Adding manpower to a late software makes it later.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.9 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iEYEARECAAYFAkqUBccACgkQeEZQoPqyQm1HzgCdF+1NhBkX87LleBKqF7f/s9kU
3xgAnR0oVtKZraMnqv6fpNaOiPGetv8Z
=Tz0m
-----END PGP SIGNATURE-----
I've been reading up on that type of water-based polymer, and it ought to
work. It should be probably available much cheaper from the actual
manufacturer (I haven't found who makes it), but one probably has to buy it
by the drum. For the small number of boards I make it isn't really cost
effective, so I'll stick to the pre-coated material.
Leon
> Leon
I gave you the manufacturers website. They do sell directly at the
$68 a kilo price. Same as on ebay with $14 shipping. They are
located in Ohio, USA. Prices would be in US dollars, so it's
getting cheaper by the minute.
Roger
It's probably something like the material discussed here which is used for
coating wood and other materials:
<http://www.cytec.com/uv/Downloads/Water-based%20Radiation%20Curable%20Polyurethane%20Dispersions.pdf>
This is the stuff his company makes:
http://www.cytec.com/uv/Downloads/UCECOAT%20-%20Wood%20Coatings_EMEA_En.pdf
Leon
Re: [Homebrew_PCBs] Re: Anybody use AQ-3000
Sent: Tuesday, August 25, 2009 5:05 PM
Subject: [Homebrew_PCBs] Re: Anybody use AQ-3000
>> it
>> Leon
I doubt if they actually manufacture it, they aren't a chemical
manufacturer. They probably buy it in bulk and repackage it.
Leon
2009-08-27 by jcarlosmor
What kind of information do you specifically need?
I bought AQ-3000 photoresist, soldermask, and ink legend from the original manufacturer (before Genesis distribution or commercial arrangement).
They are professional products for industrial PCB making. Nothing to do with that silly products for coating woods and other materials, or the hobby Positiv stuff. I also have all of the datasheets and MSDS for the three products. Very clear their instructions, but must be followed whithout change a bit of them. And for soldermaks and ink legend, you must have an air-forced oven, or the PCB surface does not conform to the quality stated.
It is a great advantage to have those products sold for that low price ($68 kilo), when other manufacturers/distributors only sell for minimum $1,000/month.
And yes, you are right, this is the only way (using inustrial PCB-making products) to make decent PCBs at home.
2009-08-27 by pr0pert
Whatever information I can get. Is it easy to use? What method of
application do you use? Shelf life? Things to look out for? Is it as
good as it sounds? I have an old Blue M oven from when I had a
business, so it looks like I have a start on it. I was at first
thinking of going with spin coating then decided that it would be
easier to make a dip system
2009-08-31 by jcarlosmor
< Is it easy to use? >
Yes, very easy, but follow all the instructions and procedures exactly as stated in the datasheet.
< What method of application do you use? >
You must use dip coating.
< Shelf life? >
It is stated as six months, but however it last longer in cool places.
< Things to look out for? >
Be prepared to work as in industry PCB making. No hobby procedures allowed. Always do Stouffer test, measure and mix exactly the right quantities of Calcium Carbonate and Sodium Hydroxide. Work with safety UV light, etc. Use the correct temperatures, etc.
< Is it as good as it sounds? >
Yes, I prefer dry films but this product is very good.
< I have an old Blue M oven from when I had a business, so it looks like I have a start on it. I was at first thinking of going with spin coating then decided that it would be easier to make a dip system >
The viscosity is designed for dip coating inmersion. I think that you cannot coat properly with spin coating. You should make a dip system, with a container very slim, or you may need galons of liquid. Also, the dip system must be tuned to get the right micron coating in your PCB. The speed of getting out the PCB must be controlled and be made variable in time. If you design and make your dip coating setup, email me to explain details of how to do that.
Regards.
