Re: Undelivered Mail Returned to Sender
2009-09-13 by Stefan Trethan
Steve can you please change drake@... to no email? It bounces every time for the last few days. ST On Sun, Sep 13, 2009 at 12:30 PM, Mail Delivery System < MAILER-DAEMON@...> wrote: > This is the mail system at host sgeorge.spng.org.ec. > > I'm sorry to have to inform you that your message could not > be delivered to one or more recipients. It's attached below. > > For further assistance, please send mail to postmaster. > > If you do so, please include this problem report. You can > delete your own text from the attached returned message. > > The mail system > > <drake@...>: cannot update mailbox /var/mail/drake for user drake. > error writing message: File too large > > Final-Recipient: rfc822; drake@... > Original-Recipient: rfc822;drake@... <rfc822%3Bdrake@...> > Action: failed > Status: 5.2.2 > Diagnostic-Code: x-unix; input/output error > > > ---------- Forwarded message ---------- > From: Stefan Trethan <stefan_trethan@...> > To: Homebrew_PCBs@yahoogroups.com > Date: Sun, 13 Sep 2009 12:35:06 +0200 > Subject: Re: [Homebrew_PCBs] Re: developing immersion tank > > > But this is the step after developing, done with water, not developer. > > To me it seems the resist will turn into gunk in the developer even > without much agitation, and that gunk is washed away in the next step? > > ST > > On Sun, Sep 13, 2009 at 11:50 AM, Adam Seychell <a_seychell@...<a_seychell%40yahoo.com.au>> > wrote: > > > > > All the data sheets I've read have only mentioned developing with spray. > > In my experience the resist simply does not wash away with simple > > immersion or bubble agitation. > > > > From the data sheet http://www.dryfilmresist.com/pds/kg5100.pdf > > > > "To affectively clean between circuit traces to remove all developing > > residue, the panels must be throughly rinsed > > with water at temperatures ranging from 15 to 30℃ (59-86F) and pressures > > greater than 1.4 bar(20psi). Poor > > rinsing may promote ragged edges, rough plating, step plating, resist > > lifting. Rinsing is a most important part of > > the developing process." > > > > Adam > > > > > > Email secured by Check Point > > > [Non-text portions of this message have been removed]
