Homebrew PCBs
Shipley AZ111 pos photo resist
2009-09-23 by designer_craig
Back in the 70's and 80's I etched several hundred boards using Shipley's AZ111 positive photo resist. Recently I have started to build some boards again using toner method but would like more accuracy.
I have looked all over the net and can't seem to find the AZ111 anymore.  Does anyone know of an equivalent available product that you can buy in small quantities.
Last time I purchased AZ111 it was about $60 per qt. but that was in the 70's.
The AZ111 worked great. For two sided boards I would spin coat one side bake for 15 minutss, spin coat and bake the other side, then UV expose with a film maste and etch.  Shipley had a sodium carbonate develop that worked well, no brushing or wiping was necessary. For etching I initially used ferric chloride but switched to heated ammonium persulfate spiked with touch of mercury chloride. The persulfate was much cleaner to work with and would etch a board in 20 seconds in my splash tank.
The only issue was the spin coating which limited the board size and shape to about 8-10" sq.max. Long narrow boards were a problem to get coated evenly.  I never tried spray or dip coating.
Craig
Re: Shipley AZ111 pos photo resist
2009-09-26 by Ben L
You might want to take a look at the M G Chemical's Series 600 boards, these have positive resist on them.  You can get them thru Mouser, Allied Electronics, Digi-key, Circuit Specialist.
Ben
2009-09-26 by designer_craig
I have lots of blank PCB stock here so buying precoated boards is not in the plan.  I also want to use the resist for making stensils.
Craig
> Ben
nano silver ckt ink & 3D printing of ceramics
2009-09-28 by William Alford
future possibilities -
http://www.sciencedaily.com/releases/2009/02/090212141204.htm New
Silver-based Nanoparticle Ink
http://www.sciencedaily.com/releases/2009/03/090331153010.htm - 3-D
Printing Hits Rock-bottom Prices With Homemade Ceramics Mix
William Alford
GI Motility Medical Research Page
http://alford.grimtrojan.com/
2009-09-28 by roycepipkins
Last year folks were talking about Positiv 20.
I have not used it, however.
http://www.soselectronic.com/?str=371&artnum=33241
Best of luck,
Royce
> Craig
> > Ben
2009-09-29 by jcarlosmor
You should try AQ-3000 liquid photoresist. It is for professional use and the results are very good. It is negative-acting and for dip coating. Nothing to do with Positiv20 and so unreliable stuff.
