Homebrew PCBs
Solder paste mask with a vinyl cutter
2009-10-14 by Steve Greenfield
I've got some solder paste coming in the mail. I thought a bit about solder paste masking, I have a vinyl cutter.
JoAnn Craft stores sells a transparent vinyl, sort of a cling-film. I'm going to stick some to a carrier (probably some transfer tape) and try cutting out a paste mask. It is thick enough to leave a reasonable amount of solder paste on the board. And stiff enough, I think, to survive being used on several boards.
 Steve Greenfield, CET Consumer and Computer
Electronic Engineering Technician student
Re: [Homebrew_PCBs] Solder paste mask with a vinyl cutter
2009-10-14 by Brian Gracia
Try finding a local shop that does laser engraving.  You can get
cheep thin plastic shim stock and use as a stencil.  Just find out
what you need to output the graphic to.  Many use plot or gerber files.
Brian
2009-10-14 by Stuart Schaffert
The accopunt has been deleted.
Please include all previous e-mail messages regarding this subject when replying to this message.
Thank You,
Stuart
WeatherWarn Support
support@...
  Sent: Wednesday, October 14, 2009 3:37 PM
  Subject: Re: [Homebrew_PCBs] Solder paste mask with a vinyl cutter
  Brian
I'm not at all sure how this e-mail got sent but it's not true, please ignore.
Stuart
  Sent: Wednesday, October 14, 2009 3:46 PM
  Thank You,
  Stuart
  WeatherWarn Support
  support@...
  Brian
