What is a Via?
2010-03-31 by Chris Maness
I am using gEDA PCB and it has VIAS as one of the options. Is this referring to a hole that jumpers over a line on a PC board to the other side of a trace? Thanks, Chris KQ6UP [Non-text portions of this message have been removed]
2010-03-31 by Leon Heller
On 31/03/2010 21:17, Chris Maness wrote: > I am using gEDA PCB and it has VIAS as one of the options. Is this > referring to a hole that jumpers over a line on a PC board to the other side > of a trace? Yes. Leon -- Leon Heller G1HSM
2010-03-31 by Paul Mateer
it's a thru hole that connects traces from one layer to another. On Wed, Mar 31, 2010 at 3:29 PM, Leon Heller <leon355@...> wrote: > > > On 31/03/2010 21:17, Chris Maness wrote: > > I am using gEDA PCB and it has VIAS as one of the options. Is this > > referring to a hole that jumpers over a line on a PC board to the other > side > > of a trace? > > Yes. > > Leon > -- > Leon Heller > G1HSM > > -- Paul Mateer, AA9GG Elan Engineering Corp. www.elanengr.com NAQCC 3123, SKCC 4628, FPQRP 2003 [Non-text portions of this message have been removed]
Like if I cannot find a way around a trace on a single sided board, I would cheat and use a via? Chris On Wed, Mar 31, 2010 at 1:34 PM, Paul Mateer <paul.aa9gg@...> wrote: > it's a thru hole that connects traces from one layer to another. > > On Wed, Mar 31, 2010 at 3:29 PM, Leon Heller <leon355@...> > wrote: > > > > > > > On 31/03/2010 21:17, Chris Maness wrote: > > > I am using gEDA PCB and it has VIAS as one of the options. Is this > > > referring to a hole that jumpers over a line on a PC board to the other > > side > > > of a trace? > > > > Yes. > > > > Leon > > -- > > Leon Heller > > G1HSM > > > > > > > > -- > Paul Mateer, AA9GG > Elan Engineering Corp. > www.elanengr.com > NAQCC 3123, SKCC 4628, FPQRP 2003 > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Be sure to visit the group home and check for new Links, Files, and Photos: > http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links > > > > [Non-text portions of this message have been removed]
2010-03-31 by DJ Delorie
A via is a hole in the PCB that lets you connect copper on different layers. While they're physically the same as the holes for component leads, PCB keeps them separate so that you can do things like "select all vias" or "increase all pin sizes by 5 mil". Note that PCB automatically adds vias if you're drawing a trace (line tool) and select a different layer (number keys).
2010-03-31 by Brian Pingree
The via hole is a plated hole through the board that connects to a trace on the other side hence the board becomes double sided (or indeed to any intermediate plane in multi -layer boards). Not very DIY friendly. Use the lead of a non-radial through hole device or a short link to effect the connection. --- On Wed, 31/3/10, Chris Maness <chris@...> wrote:
Subject: Re: [Homebrew_PCBs] What is a Via?
Date: Wednesday, 31 March, 2010, 21:42
Chris
> On Wed, Mar 31, 2010 at 3:29 PM, Leon Heller <leon355@btinternet. com>
> > side
> > > of a trace?
> > Yes.
> > Leon
> > Leon Heller
> > G1HSM
> Paul Mateer, AA9GG
> www.elanengr. com
> http://groups. yahoo.com/ group/Homebrew_ PCBsYahoo! Groups Links
[Non-text portions of this message have been removed]2010-03-31 by Paul Mateer
Correct On Wed, Mar 31, 2010 at 3:42 PM, Chris Maness <chris@...> wrote: > > > Like if I cannot find a way around a trace on a single sided board, I would > cheat and use a via? > > Chris > -- > Paul Mateer, AA9GG Elan Engineering Corp. www.elanengr.com NAQCC 3123, SKCC 4628, FPQRP 2003 [Non-text portions of this message have been removed]
No, technically if you have a *single* sided board, there's no copper on the other side to connect to, you'd have to use a wire jumper. However - in PCB, (or any layout package), you can use another copper layer to keep track of where you need jumpers. In that case, a regular via would serve that purpose, as well as the copper traces on the fake layer. That also makes the design rule checkers happy.
2010-03-31 by David Griffith
On Wed, 31 Mar 2010, Chris Maness wrote: > Like if I cannot find a way around a trace on a single sided board, I would > cheat and use a via? Yes. Jump over to the other side just long enough to make your jump, then go back. Try to minimize their number and length (make one jump over many instead of many jumps over one). Keep them as straight as possible. This makes it easier to put in jumper wires when you're soldering the board. -- David Griffith dgriffi@...
2010-04-01 by sailingto
Finally someone gives a clear answer to the op's question. The following is for the home DIY type boards that at most are double sided. I expect there are very few 4 layer homebrew boards in normal use. DJ, was it you that did some 4 layers? While a via can be used to get across a trace on the same layer, a "via" is simply a hole thru the board from top side to bottom side and is used with double sided boards. (home use) As said before, a short piece of wire cab be used to connect the two sides (layers). Even better is a rivet to connect the two layers. Since getting smoe rivets - I LOVE those for connecting vias. Using vias to keep track of jumpers on the top layer is a good idea - I'll try to remember that trick. Great group of folks here and I've learned a LOT. Ken H> --- In Homebrew_PCBs@yahoogroups.com, DJ Delorie <dj@...> wrote:
> > A via is a hole in the PCB that lets you connect copper on different > layers. While they're physically the same as the holes for component > leads, PCB keeps them separate so that you can do things like "select > all vias" or "increase all pin sizes by 5 mil". > > Note that PCB automatically adds vias if you're drawing a trace (line > tool) and select a different layer (number keys). >
