Homebrew PCBs
HELP: Making CuCI
HELP: Making CuCI
2010-03-29 by Howard
Hi
I have been doing etching with HCI (Spirits of salt 32%)
and H202 (6%) in a mix of 1 part HCI to 1 part H202, in small
amounts (.5ltr), after etching i then put the acid into a 3ltr
bottle, now the bottle is full of medium to dark green stuff!
So now i would like to make use of it to make CuCI.
Now i think that i need to add some copper to the mix and pump
some air in.
I have a Mega-UK type of tank with a built in air pump and heater
it holds about 5ltrs. Could i just put the 3ltrs of used mix into
the tank, add some copper(how much?) and turn on the air(how long for?)
When will i know when it is converted to CuCI ?
Hope that someone can put me right on this
Howard
Re: [Homebrew_PCBs] HELP: Making CuCI
2010-03-29 by Leslie Newell
You don't need to add more copper. The dark green is cuprous chloride.
Add more H2O2 or bubble air through it to convert it to cupric chloride.
It will turn a lighter green as it converts. You may need to add acid if
it doesn't etch very well. IME bubbling air through it takes quite a
long time. You need fine air bubbles like you get from an air stone but
air stones disintegrate in the acid.
Les
Howard wrote:
> Hi
> some air in.
> Regards
> Howard
2010-03-29 by Mark Lerman
Do you think porous polyethylene rod would work as a bubbler?  See
<http://www.smallparts.com/Polyethylene-Porous-Diameter-Average-Microns/dp/B000FN1FCY?ie=UTF8&qid=1269869358&sr=1-14&pf_rd_r=151FSQ0N41GE7V0WYX7V&pf_rd_m=A2LPUKX2E7NPQV&pf_rd_t=301&pf_rd_i=0&pf_rd_p=493388211&pf_rd_s=center-3>
Mark
>Les
>Howard wrote:
> > Hi
> > some air in.
> > Regards
> > Howard
>Be sure to visit the group home and check for new Links, Files, and Photos:
>http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
2010-03-29 by Howard Payne
At $50 a go, i dont think it is cost effective, but prob will work
Howard
> Mark
> >Les
> >Howard wrote:
> > > Hi
> > > some air in.
> > > Regards
> > > Howard
> Photos:
73's Howard G7LQY
GQRP: 12549
Loc: IO83UO
LARGE FILES TO: hjpayneg7@...
Sorry NOT cost effective
Howard
> Howard
>> Mark
>> >Les
>> >Howard wrote:
>> > > Hi
>> > > some air in.
>> for?)
>> > > Regards
>> > > Howard
>> Photos:
> 73's Howard G7LQY
> GQRP: 12549
> Loc: IO83UO
73's Howard G7LQY
GQRP: 12549
Loc: IO83UO
Ok i have put the mix into the maga-uk bubble etch tank pa104 and put the
air pump
on and after a short time the mix starts to froth up and the froth starts to
come over
the top of the tank! the air pump was only on for a few mins
Is this normal!! ??
Howard
> Howard
>> Howard
>>> Mark
>>> >Les
>>> >Howard wrote:
>>> > > Hi
>>> > > some air in.
>>> for?)
>>> > > Regards
>>> > > Howard
>>> Photos:
>> 73's Howard G7LQY
>> GQRP: 12549
>> Loc: IO83UO
> 73's Howard G7LQY
> GQRP: 12549
> Loc: IO83UO
73's Howard G7LQY
GQRP: 12549
Loc: IO83UO
2010-03-29 by Chris Maness
I have had success mixing 1:1 15% HCl and 3% H2O2.  The Copper (I) Chloride
is not very soluble and will make the solution opaque.  If it is a clear
emerald green you are good.  If brown and murky looking add a capfull of
H2O2.  It is also good to evaporate the solution a little after every use so
that adding H2O2 will not dilute the Copper (II) Chloride too much.
Chris Maness
KQ6UP
2010-03-29 by DJ Delorie
If you have dark green, you have CuCl.  Pour it into your other tank and
turn on the bubbler, that's all.  Note: dark GREEN is good, dark BROWN
needs more air time.
See http://members.optusnet.com.au/~eseychell/PCB/etching_CuCl/ for the
rest of the chemistry :-)
Yes it is dark green\black, it go's darker with use, but when i put the
air pump on, it foams up (frothy) and starts to come out the top of the tank
is this ok ? am using the pump cos i think that it needs more air time!
> See http://members.optusnet.com.au/~eseychell/PCB/etching_CuCl/<http://members.optusnet.com.au/%7Eeseychell/PCB/etching_CuCl/>for the
73's Howard G7LQY
GQRP: 12549
Loc: IO83UO
Can you reduce the volume of air?  Or, you might want to add H2O2
instead of air, it might have too much HCl in it, or if it's too dark,
too much Cu.  Check Adam's site for details on how to tell what's going
on in your tank.
Re: HELP: Making CuCI
2010-03-29 by James
Did it get contaminated with detergent of some sort? Was the peroxide you used just peroxide, or some sort of hair product with additives? Mine doesn't froth at all.
Re: [Homebrew_PCBs] Re: HELP: Making CuCI
2010-03-30 by Howard Payne
Hi
The ingredients as on the bottle are:
Aqua, Hydrogen Peroxide, Sodium Salicylate, Pentasodium  Pentate and
Phosphoric Acid.
It is 6% 20vol in a 1ltr bottle
Would any of these things that are in it, make it foam up (frothy) when i
use
the air pump ??
Howard
> tank
73's Howard G7LQY
GQRP: 12549
Loc: IO83UO
2010-03-30 by Simao Cardoso
On Tue, 2010-03-30 at 15:55 +0100, Howard Payne wrote:
> Hi
> Phosphoric Acid. It is 6% 20vol in a 1ltr bottle
> use the air pump ??
Resuming the top query results from google on Pentasodium Pentate:
It's a metal chelating agent that 'inactivates' copper or metals in hard
water "creating superior foaming and cleaning performance."
2010-03-30 by James
Yeah that sounds like the problem. The stuff you want is straight peroxide diluted with water. The 3% drugstore stuff for washing cuts and scratches works, but the beauty supply shop near me carries 40 volume stuff without additives.
