Homebrew PCBs
[Homebrew_PCBs] DLP update
2010-05-13 by Mark Lerman
I have posted the final pictures of the process, including a photo of
the first board run through the converted printer. If anyone is
pursuing this technique, please let me know how you are doing.
<http://www.pbase.com/mark10970>
Mark
Re: [Homebrew_PCBs] DLP update
2010-05-13 by Erik Knise
Wow, great job mark.  How long did this take you?
> Mark
Erik L. Knise
Pacific Shipping Company
Seattle, WA
Re: DLP update
2010-05-13 by sailingto
That sure looks GOOD!!! If my Toner Transfer wasn't working so good I'd sure be looking at your process - Didn't you say you are still working on getting double sided to line up?
Thank you for sharing all your GREAT work.
Ken H>
> Mark
Took me about a week to do the documentation, but I've been playing
with DLP for over a year, though I didn't get serious till 2-3 months ago.
Mark
> > Mark
>Erik L. Knise
>Seattle, WA
>Be sure to visit the group home and check for new Links, Files, and Photos:
>http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
Re: [Homebrew_PCBs] Re: DLP update
I have the theory for ds worked out, but I haven't implemented
it.  The X axis is fixed by the paper guide, but will probably need
to be changed to something longer. The Y (motion) axis needs a sensor
that tells the mcu when the moving pcb has reached a point
approximately where the Paper In Sensor was. It is this sensor that
(I think) starts the timing for the actual print. A slot in the
carrier with an optical sensor should work fine. The rest is just a
tweak in the software.
Mark
>Ken H>
> > Mark
2010-05-13 by Jim
Hello Mark
I have purchased an E260D printer ... I don't yet have an isolated
"CLEAN" workbench that I can give to this project but I have
disassembled the printer to various degrees and reassembled it to get
practice. When I feel comfortable, (can reassemble without referring to
the manual or pictures) I will start cutting wires, plastic and metal.
Thanks for all you have done to show how this modification is done.
Jim KI6MZ
> Mark
2010-05-14 by Andrew Villeneuve
The theory is sound, but I believe you're going to have to improve upon the
alignment accuracy that was originally in the printer to make usable
double-sided prints...most laser printers I've encountered have variations
in the printing alignment of well over 2mm from one page to the next.  This
kind of deviation would be imperceptible when printing documents, but
unusable when trying to align boards.
I suspect you can probably overcome this with some clever timing in your
MCU.  Off the top of my head, running the board though a photointerrupter
instead of using a mechanical alignment switch would probably improve
accuracy.
-Andrew
> Mark
> >Ken H>
> >--- In Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs%40yahoogroups.com>,
> > > Mark
> Photos:
2010-05-15 by Mark Lerman
I'll try it in the next week or so and let you know.
Mark
>accuracy.
>-Andrew
> > Mark
> > >Ken H>
> > > > Mark
> > Photos:
DLP Quesions and Phaser info
2010-05-17 by studleylee
Hi Mark,
I've been following a similar path, but with the Xerox/Tektronix Phaser solid wax ink printers.
I have a 8400 and an 850D that I run 8mil thick flexible single sided stock in the manual feed path.
It works well to a point, except sometimes I have to preheat the board going in.
It's been hit and miss as I think I've been running into electrostatic issues similar to what you've
been working through.
I'm going to try the Carbomer/alcohol/water shared by David yahoo@... (www.laserpcb.com),
1 cup water, 1 cup isopropyl alchohol, 4 tablespoons Carbomer 940
To see if that helps bring the line resolution down.
***Your toner method has really good advantages that are leading me to abandon the solid wax printers:
1) Your line resolution looks better.
2) If the transfer has issues, your method is much easier to dust off clean and redo. I have to strip the wax off & re-clean.
I have a E260DN ready to do your modifications( You do very impressive-creative work, process, and docs!! )
-Bought a small lab supply 0-10kv for experimenting just in case.
Questions:
1)I had a question about your instruction/comment below:
"Interestingly, using an un-coated aluminum carrier will not work –
it seems to require much less transfer voltage!"
Sorry if I sound dense, but does this mean "the coated carrier makes it require much less transfer voltage"
2) It seems as if the carrier and the PCB with the help of the KY make a simple capacitor
between the carrier's( expoxy insulated) inner plate
and the PCB surface. I was wondering if some of the
KY is conductive somewhat, and is it touching/bridging to the PCB surface
copper. Just curious on what you think?
-Lee
Re: [Homebrew_PCBs] DLP Quesions and Phaser info
2010-05-17 by Mark Lerman
At 03:02 PM 5/17/2010, you wrote:
>Hi Mark,
I'm pretty sure what Dave's gel does is help the
powered toner stick to the board as it passed
through the fuser. He uses it in an intact laser
printer on copper foil, not copper clad board.
I suspect the resolution of this process is a
function of the resolution of the laser printer
and the etching process. Thin traces (3 mil) are
easy, but 3 mil traces with 3 mil spaces between
them is not so easy. That's where the ability to
decrease the toner density comes in handy. Using
the toner density at maximum (via the E260
utility program) makes it easy to get dense
lines, but there really is too much toner if you
want the lines close together. For that you have
to back the density to about half (5 out of 10).
Then you have to be able to fuse it without skips
or smudging. Dave's gel certainly might be useful here.
>Questions:
>"Interestingly, using an un-coated aluminum carrier will not work ­
Oddly, it means exacly what it says. A coated
aluminum carrier works perfectly with either a ds
or ss pcb taped on top of it with ky between the
carrier and board. The internal hv transfer
voltage (as measured with my Fluke HV probe) is
about 1600 volts. If I use a plain piece of
aluminum as a carrier, the required voltage seems
to be MUCH less. Unfortunately, by the time I did
that experiment I had removed the external
supply, but I can tell from the horribly
distorted image that the voltage is way too high.
The ky is mildly conductive, but I don't think it
is bridging the sides of the board. In the past I
experimented with soldering copper foil across
the sides and it seemed to make no difference.
Good luck to you - let me know how things work for you.
Mark
>Thanks,
>-Lee
