Homebrew PCBs
[Homebrew_PCBs] DLP mcu simplification
2010-05-18 by Mark Lerman
For anyone who is intimidated by the microcontroller board or just
not in a mood to build one, I believe I can simplify it quite a bit.
You can probably even do without it by using the original sensors to
read slots in the carrier, but as a better and easier compromise I
think you can use a simple 8 pin micro with minimal other components
(a diode and a bypass cap) to control the printer. When I get a few
minutes I'll give it a try.
Assuming this works, I'd like to offer a little board with the mcu
already programmed to anyone who would like to give DLP a try. The
cost will be minimal, should be under $5 USD. I only ask that you
refrain from asking for one till you have purchased a printer and are
serious about the project.
Mark
Re: [Homebrew_PCBs] DLP mcu simplification
2010-05-18 by Cristian
I'd like to buy one.Already bought the printer.
Meanwhile could you post the flowchart, to allow us to try write a
program, please?
Or the hex file for a PIC, as those are more common and the
programmers are widely spread.
Cristian
The program is explained in detail in the pdf. It's been a very long
time since I've programmed in PIC, and as I recall it isn't a very
intuitive language, so I'd rather not struggle with it.  In the
change I want to try you would not be disconnecting the Manual Feed
Solenoid, so the program is very simple. I'll try to get to writing
an actual flowchart if it will help and post it in a few days.
Mark
>program, please?
>Cristian
>Be sure to visit the group home and check for new Links, Files, and Photos:
>http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
Re: DLP mcu simplification
2010-05-18 by sailingto
>I only ask that you
That sounds very fair and the possible $5 price tag is more than reasonable!!  Thank you for all your work.
> Cristian
and here it was I though the AVR chips were most "widely spread" {grinning}..... well, maybe not yet, but they sure are gaining!!!
I do really like this idea, and as I've mentioned before, if the TT method wasn't working so good for me, I'd sure be looking at this..... and once the double sided issue is worked out I might have to try it anyway....
I WILL be following these threads.
Ken H>
Re: [Homebrew_PCBs] Re: DLP mcu simplification
2010-05-18 by Andrew Villeneuve
To anyone intimidated by MCUs, I'd recommend the Arduino platform.  It's AVR
based, costs about $30, and doesn't need any additional hardware for
programming or serial debugging (except for a USB cable).
I particularly like that it comes with an IDE for Mac/Windows/Linux and
doesn't require you to set up a cross-compiler environment.  With my old
SAM7X controller, I think I spent more time setting up and IDE and a
cross-compiler than I ever did writing code or using the controller.
The MCU is socketed and can be built into your project and replaced for
around $5 after you get it working correctly.
-Andrew
On Tue, May 18, 2010 at 9:35 AM, sailingto <sailingtoo@gmail.com> wrote:
> >I only ask that you
> > Cristian
> Ken H>
[Homebrew_PCBs] changed from Re: DLP mcu simplification to microcontrollers for a beginner
2010-05-18 by Steve
Your note below touches on a topic I've been thinking about but haven't
found a starting place.
I'd like to learn about microcontrollers. What they are, what they do,
how to make them do what I want. Eventually use them in some of my
homebrew projects.
You mention Arduino. Someone gave me a beginner's book about the
PIC16F676. There are probably other entry points into this broad topic.
Is there a place to go to get an overview? Learn what's out there,
perhaps get enough insight to enable me to pick a direction? A web site?
A book? An email reflector?
Steve
> -Andrew
> On Tue, May 18, 2010 at 9:35 AM, sailingto<sailingtoo@...>  wrote:
>>> I only ask that you
>>> Cristian
>> Ken H>
Re: [Homebrew_PCBs] changed from Re: DLP mcu simplification to microcontrollers for a beginner
There are a lot of options out there, and I do believe PICs are probably far
more popular in the long run.  They've got a pretty broad line, from very
sophisticated MCs to dirt simple ones you can buy for around $1 to do simple
projects.  I have very limited experience with them, and would be interested
if anyone could recommend a good starter setup.
I'm fond of the Arduino because there's a good community out there answering
the questions of hobbyists and beginners (such as myself), and there are no
obstacles to putting code on it and testing it out.
http://arduino.cc/en/
-Andrew
> homebrew projects.
> Steve
> AVR
> > -Andrew
> > On Tue, May 18, 2010 at 9:35 AM, sailingto<sailingtoo@...<sailingtoo%40gmail.com>>
> wrote:
> >>> I only ask that you
> >>> Cristian
> method
> the
> >> Ken H>
> Photos:
Steve, you might enjoy poking around this site:
http://www.sparkfun.com/commerce/categories.php
> homebrew projects.
> Steve
> > -Andrew
> >>> I only ask that you
> >>> Cristian
> >> Ken H>
I'm using FlowCode 4 for PIC from MatrixMultimedia.
It is good for the beginner.
Cristian
2010-05-18 by Wayne Topa
> homebrew projects.
http://www.amqrp.org/elmer160
Would be a geed place to start.
Wayne
Re: [Homebrew_PCBs] microcontrollers for a beginner
2010-05-18 by Paul Mateer
PICs / Basic Stamp:   Check out http://www.parallax.com/
Atmels: http://www.smileymicros.com/
> Cristian
Paul Mateer, AA9GG
Elan Engineering Corp.
www.elanengr.com
NAQCC 3123, SKCC 4628, FPQRP 2003
Google for PicAxe too.
They can be programmed directly from the serial port, without any
physical programmer.
Also, their FlowCart is free,
You can do simple programs, for the beginning, using intuitive flow charts .
For more sophisticated ones you have to learn programming in Basic or C.
Cristian
Cristian
