Homebrew PCBs
[Homebrew_PCBs] DLP Final Update
2010-06-01 by Mark Lerman
Unless anyone has any questions, this should be my final DLP update.
I will be making additions and corrections to the pdf in the files
section and adding a few jpegs to the pbase site
<http://www.pbase.com/mark10970>. With regard to double sided boards,
the printer is not structurally robust enough to do them "blind" -
they are as much as 15 mil out of registration. It is possible to
make ds boards by drilling registration holes, then printing the
image to match these holes, wiping the board between runs till you
get a perfect registration, but it may not be worth the effort. If I
were regularly doing ds boards I would make two boards and either use
epoxy or solder paste (as detailed previously) to make the board. Or,
I would make a flat bed printer.
That limitation aside, for me DLP is the way to go for the hobbiest
or for prototyping. It is very fast, you can erase mistakes with the
wipe of a paper towel, and it works every time.
If anyone wants a programmed mcu board, contact me off list - they
should be available later this week at a cost to be determined, but
no more than $5.00 USD.
Mark
