Homebrew PCBs
Trying to layout a PCB; do you use LTSPICE then PCB SW?
2010-06-21 by Frank P
In trying to layout a PCB, do you guys use LTSPICE to perform a simulation first?  Then proceed to use a PCB layout software like KiCAD/FreePCB (after importing from LTSPICE)? Or, if the PCB is simple enough just start using KiCAD?
Thanks.
Frank P.
Re: [Homebrew_PCBs] Trying to layout a PCB; do you use LTSPICE then PCB SW?
2010-06-21 by Andrew Villeneuve
I build my circuit on a solderless breadboard before designing the PCB (I
use EagleCAD).  Then I see the problems before doing any of the layout.
If you've got surface mount components, you can solder them to small
breakout boards for fitting onto a breadboard.
If you've got a lot of SMT, that may not be practical, but I do mostly
though-hole stuff (right now, at least).
-Andrew
> KiCAD?
> Thanks.
> Frank P.
2010-06-21 by Leon Heller
You only need SPICE if you want to simulate an analogue circuit you are
using. Otherwise, just create a schematic and lay out the PCB.
Leon
Leon Heller
G1HSM
Re: Trying to layout a PCB; do you use LTSPICE then PCB SW?
Leon,
In looking at the KiCAD webpage (http://www.lis.inpg.fr/realise_au_lis/kicad/), it says:
With the schematic entry, you can:
    * Create simple or hierarchical sheets.
    * Test it with the Electrical Rules Check tool (ERC),
    * Create netlists for Pcbnew, or for Spice.
So, I was wondering if people were using KiCAD and SPICE software together (and in what order). It sounds like you can use KiCAD and then run a simulation on SPICE software (maybe LTSPICE?).
Frank P.
> Leon
> Leon Heller
> G1HSM
Re: [Homebrew_PCBs] Re: Trying to layout a PCB; do you use LTSPICE then PCB SW?
2010-06-21 by Donald H Locker
I've been doing more simulation lately.  Quicker than breadboard and the smoke stays inside the monitor.  I like LTSpice a lot, so I'll enter a schematic in it, work out the kinks, transfer to KiCad for design and layout, then make a board.
Donald.
"Plain Text" email -- it's an accessibility issue
()  no proprietary attachments; no html mail
/\  ascii ribbon campaign - <www.asciiribbon.org>
----- "Frank P" <qz9090@...> wrote:
> Leon,
> Frank P.
> are
> > Leon
> > Leon Heller
> > G1HSM
> Be sure to visit the group home and check for new Links, Files, and
> Photos:
Donald,
Do you happen to know of a good tutorial on using LTSpice or another SPICE software? I tried messing around with this about 3 years ago, and didn't get very far ... I wouldn't mind trying again, if I could find some help! :)
> Donald.
> > Leon,
> > Frank P.
> > --- In Homebrew_PCBs@yahoogroups.com, Leon Heller <leon355@>
> > are
> > > Leon
> > > Leon Heller
> > > G1HSM
> > Photos:
2010-06-22 by Leon Heller
On 21/06/2010 22:28, Frank P wrote:
> Leon,
The Pulsonix PCB software I use has an integrated SPICE engine, but I
very rarely use it. It requires that I use special SPICE parts instead
of the usual ones used for PCB creation.
Leon
Leon Heller
G1HSM
2010-06-22 by Donald H Locker
My first recommendation would be to check out the LTSpice Yahoo! group <http://groups.yahoo.com/group/LTspice/>  There are a huge number of libraries, example circuits, tutorials, and a goodly number of very helpful and experienced users (and developers) there.
I'm finding it very useful and usable.
These came recommended to me; I haven't tried them myself, yet.
<http://cmosedu.com/videos/LTspice/LTspice_videos.htm>
<http://claymore.engineer.gvsu.edu/~steriana/Videos/>
HTH,
Donald.
----- "Andrew" <a_wake@...> wrote:
> Donald,
> find some help! :)
> > Donald.
> > > Leon,
> and
> > > Frank P.
> a
> simple
> you
> > > are
> > > > Leon
> > > > Leon Heller
> > > > G1HSM
> and
> > > Photos:
> Photos:
2010-06-22 by Frank P
Donald,
You said you "transfer" from KiCad to LTSpice, are you using an automated import/export utility to move the data between the apps?
Thanks.
Frank P.
> Donald.
> > Leon,
> > Frank P.
> > are
> > > Leon
> > > Leon Heller
> > > G1HSM
> > Photos:
Not yet.  I just redraw in KiCad.  Most of my circuits are dead simple these days.  No more than a half dozen components.
Donald.
> Donald,
> Thanks.
> Frank P.
> > Donald.
> > > Leon,
> and
> > > Frank P.
> a
> simple
> you
> > > are
> > > > Leon
> > > > Leon Heller
> > > > G1HSM
> and
> > > Photos:
> Photos:
2010-06-22 by Andrew
Yes, thanks!
> HTH,
> Donald.
> > Donald,
> > find some help! :)
> > --- In Homebrew_PCBs@yahoogroups.com, Donald H Locker <dhlocker@>
> > > Donald.
> > > ----- "Frank P" <qz9090@> wrote:
> > > > Leon,
> > and
> > > > Frank P.
> > a
> > simple
> > you
> > > > are
> > > > > Leon
> > > > > Leon Heller
> > > > > G1HSM
> > and
> > > > Photos:
> > Photos:
