Homebrew PCBs
Inkjet or Laser for PCB work?
2010-07-21 by gnuvvekaavaali
I am looking for suggestions on the choice of
Inkjet (for direct inkjet printing) or laser
printer (toner transfer) for the occasional single sided PCB.
I don't see I will be needing very thin or dense tracks.
My experience with toner transfer have not been too good. I
used a Samsung Laser printer, and a hot clothes iron,
with different types of paper.
Best results have been with glossy magazine paper, but still
had some improper transfers.
The Epson Artisan 50 inkjet seems to be moddable for direct pcb printing, and I can get that for cheap.
Wondering if this is a easier and reliable way than toner transfer.
Re: [Homebrew_PCBs] Inkjet or Laser for PCB work?
2010-07-21 by Bob Butcher
I have had a  lot of trouble with toner transfer as well. My Brother 1440 laser printer toner will not release reliably from any paper I have found. I have heard the toner has a higher melting temperature than some other printers, but am not sure what the problem is.
I am not sure how you plan to modify the Artisan 50 inkjet printer to directly print on the rigid PCB material. Another thing to consider, most of the ink jet ink I have seen is water soluble, so the etchant will dissolve the ink before it has a chance. I know there are ink jet printers that are capable of using solvent based inks, but all the ones I have seen are very expensive, in the several thousands of dollar range. You can buy inexpensive "paint pens" from art and craft stores that might be useful if you could find a flat bed printer that could be adapted to pens. I have on old large format HP printer designed for CAD drafting that uses pens, but the pen only moves on one axis, and the paper is fed back and forth by a roller system for the other axis. The paper is wrapped around the rollers, so it cannot be easily adapted to a rigid PCB. If someone had a flat bed printer with a moving pen on two axes, that might work. Sounds like an old school
 chart recorder might work, if you could find a working model that would interface to a modern computer.
Bob
--- On Wed, 7/21/10, gnuvvekaavaali <gnuvvekaavaali@...> wrote:
Subject: [Homebrew_PCBs] Inkjet or Laser for PCB work?
Date: Wednesday, July 21, 2010, 12:22 AM
2010-07-21 by Leslie Newell
Flatbed plotters are available. I have tried this approach and never
found a good solution. The main problems were that the ink tends to
creep so you don't get a very sharp line and the pens block very easily.
About the best result I had was by printing with red ink onto photo
sensitive board. Then expose and develop as as per normal. This saved
the hassle of producing a transparency but was hardly worth the effort.
Les
> Bob
2010-07-21 by P COUNSELL
I have a very good dos program CADPAK and I use an old rowland DXY-880A plotter. Results are fantastic . I modified the height of the plotter pen to accomodate standard thickness PCB board. Only problem is it wont do tracks fine enough for intertrack knecking , itis also very slow on printing directly onto the copperlaminate but I have a cup of tea. Fine for prototyping.
  Sent: Tuesday, July 20, 2010 9:53 PM
  Subject: Re: [Homebrew_PCBs] Inkjet or Laser for PCB work?
  Bob
Re: Inkjet or Laser for PCB work?
--- In Homebrew_PCBs@yahoogroups.com, Bob Butcher <bbutcher85@...> wrote:
> I am not sure how you plan to modify the Artisan 50 inkjet printer >to directly print on the rigid PCB material.
Thanks to James Newton for collecting all this info -
http://techref.massmind.org/techref/pcb/etch/directinkjetresist.htm
http://techref.massmind.org/techref/pcb/etch/Artisan50.htm
2010-08-02 by borgrailuk
Sounds interesting. How did you modify the plotter pen height and which pens/ink did you use?
I have a DXY1200 - not too keen to modify height but am planning on using a slightly thinner pcb, which will fit.
Stephen Freeman
>   ----- Original Message -----
>   From: Bob Butcher
>   Bob
>   From: gnuvvekaavaali <gnuvvekaavaali@...>
Re: [Homebrew_PCBs] Re: Inkjet or Laser for PCB work?
2010-08-02 by P COUNSELL
I modified my DXY880a very easily by using a piece of standard pcb board so that the pen height was perfect for standard thickness pcbs.
  Sent: Sunday, August 01, 2010 9:30 PM
  Subject: [Homebrew_PCBs] Re: Inkjet or Laser for PCB work?
  Stephen Freeman
  > From: Bob Butcher
  > Bob
Unfortunately athough I have some pens whuch were designed for pcbs they are no longer availabe for rowland plotters. I do not see that as a big problem . I intend to use EDDING 404 PEN TIPS with edding 404 refill ink with a homemade holder. I will first try recharging my existing tips when they run out with EDDING PERMANENT MARKER REFILL INK, I expect this to work fine.
  Sent: Sunday, August 01, 2010 10:41 PM
  Subject: Re: [Homebrew_PCBs] Re: Inkjet or Laser for PCB work?
  Stephen Freeman
  > From: Bob Butcher
  > Bob
2010-08-02 by VK3YV
Hi, on seeing you are using a Roland Plotter for pcb drawing I have a query,
I have a Roland DXY 800 for which I have no information i.e.. dip switch
settings etc. that I would also like to use for PCB work. I have no
information at all about it , I don't even know what language it talks. Can
any one help, I have searched for hours but cant find anything regarding
setup or language/ emulation .
Don VK3YV.....
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Monday, August 02, 2010 8:54 PM
> work fine.
>  From: P COUNSELL
>  From: borgrailuk
>  Hi,
>  Stephen Freeman
> for prototyping.
>  > From: Bob Butcher
> school
>  > Bob
> Be sure to visit the group home and check for new Links, Files, and
> Photos:
Checked by AVG - www.avg.com
Version: 9.0.851 / Virus Database: 271.1.1/3044 - Release Date: 08/02/10
04:40:00
2010-08-02 by casy_ch@tbwil.ch
Hi Don
In the past I have had a DXY800 and later a DXY1150.
All use HPGL (Hewlett Packard Graphic Language). Your programm should have a HPGL driver and will generate a <xx.PLT> file.
If you go to:
http://en.wikipedia.org/wiki/HPGL
you will find the language it is using.
73 de Jean-Claude, Switzerland
HE9EZX
  Sent: Monday, August 02, 2010 3:02 PM
  Don VK3YV.....
  > work fine.
  > From: P COUNSELL
  > From: borgrailuk
  > Hi,
  > Stephen Freeman
  > for prototyping.
  > > From: Bob Butcher
  > school
  > > Bob
  > Photos:
  04:40:00
2010-08-02 by VK3YV
Hi Jean-Claude, that is a big help, now I need to know the DIP switch
settings, I will be using the parallel port, and hopefully be able to use it
with win xp, do you still have the dip switch settings?
Many thanks,
Don VK3YV........
Sent: Tuesday, August 03, 2010 12:08 AM
> Hi Don
> If you go to:
> HE9EZX
>  From: VK3YV
> query,
> Can
>  Regards,
>  Don VK3YV.....
>  From: "P COUNSELL" <pcounsell@...>
> they
> ink
> when
>  > work fine.
>  > From: P COUNSELL
> board
>  > From: borgrailuk
>  > Hi,
> using
>  > Stephen Freeman
> DXY-880A
> pen
>  > for prototyping.
>  > > From: Bob Butcher
> have
> some
> most
> printers
> seen
> buy
> if
> on
> but
> a
> rollers,
> bed
> old
>  > school
> would
>  > > Bob
>  > Photos:
>  04:40:00
> Photos:
04:40:00
