Homebrew PCBs
More on - Produce Quick & Cheap PCBs with a CNC paper cutter
2012-09-08 by Mike Sinclair
I'm back for a second round. This time I changed tacks - I have turned the $270 CNC paper cutter into a 2.1D mill for mil-etching PCBs - instead of the original drag-knife method. See video here http://www.youtube.com/watch?v=rDRN1_i0vJU and some updated info here http://research.microsoft.com/en-us/projects/papercutterpcbs/
I haven't calibrated the setup yet like ipm, position tolerance and repeatability and minimum isolation track width & repeatability but that will come. The original method I was trying to perfect was to drag a carbide knife through copper cladding to affect electrical isolation but the swarf remaining was a problem.
Mike
Re: More on - Produce Quick & Cheap PCBs with a CNC paper cutter
2012-09-09 by AlienRelics
Mike, nicely done!
Steve Greenfield AE7HD
> Mike
Re: [Homebrew_PCBs] More on - Produce Quick & Cheap PCBs with a CNC paper cutter
2012-09-10 by Mark Lerman
You've inspired me - I just ordered a Sillhoute Cameo! I have a few
other ideas on how to use it and will post the results!
Mark
>Mike
>Be sure to visit the group home and check for new Links, Files, and Photos:
>http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
2012-09-11 by Mike Sinclair
Mark - Great o your purchase.....I don't think you'll be disappointed.
Soon I will post what I had to do to get the Dremel extension handpiece fitted to the cutter. I was hoping this would be a "no-mod" hack but I did have to craft this little piece and a add a spring to take up the extra weight of the handpiece. I also am a little worried about the fiberglass and metal dust being produced but I believe a little attention to a blower or vacuum would be in order.
I am presently discovering a simple method to use the Pen mode to label parts and a solder resist pen for that function. I also believe there's a way to apply solder paste for surface mount parts, but that'll be later. In the meantime, the Cameo can do a fair job at cutting acetate sheets for silkscreening the above. I have access to a laser cutter but this machines does a respectable job at cutting stencils.
Happy PCBing!
Mike
>Mon Sep 10, 2012 7:48 am (PDT) . Posted by:
>"Mark Lerman" mark_from_pomona <mailto:mlerman@...?subject=Re%3A%20More%20on%20-%20Produce%20Quick%20%26%20Cheap%20PCBs%20with%20a%20CNC%20paper%20cutter>
>Mark
>Mike
2012-09-12 by teknochaman
Amazing idea using a Dremel.
btw, does anybody know which is the pictured Dremel model ?
That will help to understand  works that can be done with it
Mine is far thicker and heavier to be supported by a small cutter
Hint or comments about the drilling  part are highly appreciated.
Best,
Samuel
________________________________________________________
I have a few
Mark
>http://www.youtube. com/watch? v=rDRN1_i0vJU and some updated info
>here http://research. microsoft. com/en-us/ projects/ papercutterpcbs/
>Mike
2012-09-12 by tda7000
I think he's using a flexible shaft extension like this:
http://www.dremel.com/en-us/attachments/Pages/ProductDetail.aspx?pid=225-01
> Best,
> Samuel
> I have a few
> Mark
> >Mike
Re: [Homebrew_PCBs] Re: More on - Produce Quick & Cheap PCBs with a CNC paper cutter
2012-09-12 by Mark Lerman
I would guess that there's a lot of runout on this, which does limit
the minimum trace width. One thing I might try when my Sillhoute
comes in is to use a laser to remove paint resist. You should also
use some sort of vacuum system to suck up the fiberglass dust.
If the machine is mechanically adequate for pcb milling, the next
step would be to convert it to use gcode like a standard cnc. This
should be relatively easy for someone "skilled in the art".
Mark
> > Best,
> > Samuel
> > I have a few
> > Mark
> > >Mike
2012-09-12 by Mike Sinclair
Yes, I did use a Dremel extension but the one that Dremel supplies in some kits and you can buy separately is too stiff and is a fairly significant load on the machine by itself though the handpiece bearings may be better for low runout. Please see my website I posted above. There's a list of parts I'm using. My Dremel tool is Model 4000 but many of the others should work (but probably not the battery operated one). With the extension attached, I get about 30K rpm.
Yes, dust could be a problem The flexible hand-piece holder coupler I had to make has a plastic "nose" that rides against and pneumatically seals to the copperclad. I am experimenting with evacuating this coupler with a flexible hose for removing the dust.
The weight of the Dremel tool itself isn't relevant here as the flexible extension minimizes this. I also use a spring to neutralize the extra weight of the hand-piece. See the video. I will also update my website soon.  I am working on acceptable_degrees_of_success  (my call) for
1.      Making of the hand-piece coupler a relatively easy to accomplish task. (I had to use a lathe for the 1st version :()
2.      Registering the top and bottom images for double sided PCBs (almost there)
3.      Being able to cut out the PCB and large routing outlines. (not started)
4.      Labeling the parts on the PCB (almost there)
5.      Dust collection (in process)
6.      Document minimum repeatable trace & line widths. (not started)
7.      Work out a few small "kinks" in the Silhouette Cameo software with the GREAT support team there.
8.      Converting the Excellon drill file to a Silhouette readable code. (not started).
9.      Use the normal drag-knife in the cutter to produce stencils for solder paste, NAMES, solder mask, etc. (not started)
Note - the Silhouette Cameo does not read G-code so a Drill file to G-code to ? may be a difficult route. The Pro version of Silhouette Studio does accept .svg vector files. Using the Silhouette's software, you cannot specify with in-line code, the spindle speed, rapid speed, feed (speed) or vector order. You can globally specify feed rate and rapid rate. Given these constraints, I've still managed to produce some very usable PCBs using my fairly quick and easy method.
Just to understand, my overall goal was to produce a list of parts that require no modifications (or VERY little), free software (today it's EagleCAD and what comes with the Silhouette), no programming knowledge and an easy to follow recipe to produce a usable PCB.
Thanks for your interest.
Mike
Mike,
I strongly agree with your goal(s). It would be awfully nice to be
able to produce a usable pcb in under 10 minutes from design to
finished board. I use mostly smt and can often get by with single
sided, especially if I use zero ohm 1206 size resistors as "jumpers".
I'd like to be able to do tqfp parts, which require about 11-12 mil
spaces and 15 mil traces, but I doubt that the Silhouette/dremel can
do that reliably, but maybe ???
I'm probably going to take a somewhat different tack than you are,
using adhesive copper foil on a thin substrate, but since I've never
used a vinyl cutter, I'm not sure what it can reliably do.
Mark
>(almost there)
>(not started)
>Mike
2012-09-13 by teknochaman
AFAIK  gcode is programming code for CAD/CAM software to routing holes in the drilling process
Wondered if  bundle software come with  X/Y axis easy design , this is vector-graphics enabled
rather than "bitmapped" (points instead of lines)
At first glance it would be an asset if an average user shouldn't be involved with learning gcode
programming  if the cutter comes with a visual oriented interface
So design can be transparent to the
user even without knowing the intricacies  of CAD/CAM software.
Comments about Silhouette Studio software are welcome specially from those already using it.
btw, I have seen only the so called CriCut that seems having similar concept to  Silhouette Cameo.
How they can be compared ?
Are these paper cutters suitable for an average electronic hobbyist/diyer trying to do their own PCBs  at home with only a cutter with X/Y blades and a Dremel flexible shaft ?
TIA
Samuel
Wed Sep 12, 2012 5:46 am        (PDT)        . Posted by:
the next  step would be to convert it to use gcode like a standard cnc.
This  should be relatively easy for someone "skilled in the art".
Mark
>http://www.dremel. com/en-us/ attachments/ Pages/ProductDet ail.aspx? pid=225-01
>--- In Homebrew_PCBs@ yahoogroups. com, teknochaman <teknochaman@ ...> wrote:
> > Best,
> > Samuel
> > ____________ _________ _________ _________ _________ ________
> > I have a few
> > Mark
> > >Mike
2012-09-13 by David Mitchell
I attempted to make an RFID tag on a PCB by designing the circuit in Eagle,
then running the "Cam Processor" to export in EPS format, which can be read
by Make-the-Cut. Although I wasn't running the knife and rotary tool,
everything else is the same.. No GCode required.
GREAT idea on drilling with a tiny spiral!!
Make-the-Cut is an easy-to-use and full featured vector cutter control
program that works with Silhouette and many other brands, but no longer
with Cricut due to lawsuits by Provocraft.
http://www.make-the-cut.com/
Here's a blog post I wrote with screenshots.
http://everhack.blog.atxhackerspace.org/2012/02/26/smd-pcb-rfid-fail/
regards
David
> already using it.
> TIA
> Samuel
2012-09-13 by tda7000
I never understood this sort of behaviour.
Surely the more software the product is supported by or can work with, the more likely people will buy it because they know they can use it with that software.
Blocking 3rd party vendors out says to me "Don't buy our product, as we won't let you do anything with it"
2012-09-13 by Mark Lerman
I think they make much of their money by selling "cartridges" with
designs, so they probably don't want users to be able to import their
own designs. Sort of like Epson trying to force users to buy Epson ink.
The "designer" version (extra $50) of the software that comes with
the Sillhoute allows import of svg files. There is also an eagle ulp
that exports svg files, so there you go! Should work! There are also
numerous other software out there that can read bitmaps, pdfs, etc
and work with this cutter.
>TIA
>Samuel
>Mark
> > > Best,
> > > Samuel
> > > I have a few
> > > Mark
> > > >Mike
2012-09-14 by Mike Sinclair
Great comments everyone!
Good idea using 0-ohm chip resistors as bridges.
I believe this method can produce 10mill trace or spaces reliably. Now it's up to me to prove it :-)
Cutting copper foil w adhesive is also a good idea. I now that al lot of folks at the MIT MEDIA Lab use this method. You're limited In how a trace/space you can make and how well the copper sticks (or doesn't).
Cricut is  much cruder in how it moves though smilar. I have SureCutsALot, another hacked software that ProvoCraft went after. It does similar functionality thru the USB port and lets you cut sgv files. It has no drag-blade compensation though not many of the good vestor tools the Silhouette has.
A little more on the operation of the Silhouette:
It can't accept G-Code nor be controlled like a CNC machine can in real-time. Once you have the vector file produced or loaded, it cuts on its own. I import a high resolution .bmp image of the Top and Bottom traces, vias and pads. It has an excellent tracing program that produces near-perfect vector objects. I let the machine move the 30Krpm spinning carbide etching tip on its own rather than try to control it intimately from the USB port as a G-Code CNC controlled mill would do. It keeps the tangential speed constant and also the rapids.
The holes are drilled with a hack. The Z-xis is ust  solenoid with a spring return. I needed to fool the machine to keep it's "blade" down long enough to drill through the PCB. I generated a multiturn spiral vector image reduced  to .001"x.001" that I place at each desired hole location. The XY stepper motors don't respond to this small movement...but takes time to try so it works fine. I also discovered a way of aligning the top and bottom for 2-sided PCBs.
I'm still close to my altruistic goal - to make this a low effort project for the user......so good....so far :-) Keep the great comments coming.
Mike
RE: [Homebrew_PCBs] Re: More on - Produce Quick & Cheap PCBs with a CNC paper cutter
2012-09-14 by MIKE DURKIN
My wife loves her silhouette ... I might too now.
Mike KC7NOA
Date: Fri, 14 Sep 2012 06:21:40 +0000
Subject: [Homebrew_PCBs] Re: More on - Produce Quick & Cheap PCBs with a CNC paper cutter
Mike
