Homebrew PCBs
Kepping Your Etchant Good? Multiple Use? Muriatic Acid / H2O2
2012-10-28 by dubob4432
I have been using H2O2 from the pharmacy / Muriatic Acid combo, 2:1 - works well and is easy to get, but it doesn't work after the initial use.  It seems every etch, I need to make a new batch.  The etchant turns into a bright lime green color on the first etch and it does what I need to pretty quick and it seems like there is decent activity - bubbles which only happens on the first time use, after that maybe bubbles when I first put in the pcb/Cu but they go away very quickly.
After use, I will put the solution in a clear, sealed glass container and even if I use it the next day, after I start, 45min later my etch is still not done, so I dispose of it and make a new batch at which time I am done in 15mins.
What am I doing wrong or where is the mixture out of balance?  Again, I just did an etch this evening and had to make a new batch, which is now a bright lime green color.
Thanks in advance,
Bob
Re: [Homebrew_PCBs] Kepping Your Etchant Good? Multiple Use? Muriatic Acid / H2O2
2012-10-28 by Harvey White
The etchant uses the oxygen from the peroxide to enable the etching.
To continue to etch with that solution, you need to bubble air through
it.  It will also help to heat the solution to 100 degrees F or so.
The solution will gradually turn a darker green.  If it turns olive
(IIRC), then the chemistry is out of balance.  The peroxide provides
oxygen only for the first day or so, at which point the etchant turns
into a CuCl etchant, which works very well, is a trifle slower, but
never wears out.  I think that there's a good review of this chemistry
in the group archives, which explanation is better than mine.
You'll find that if you add some relatively concentrated peroxide to
the etchant, it will start to work the way you expect, but the word is
concentrated.  Not really needed.
Some people take the peroxide etchant mix and deliberately add copper
to it, producing the CuCl etchant to start with.
You will eventually have to add either Muriatic acid to the mix to
replace the chloride ion, again, IIRC.
Harvey
>Thanks in advance,
>Bob
Re: Kepping Your Etchant Good? Multiple Use? Muriatic Acid / H2O2
Thanks.
When you say 'bubble air through it' you mean like w/ a fish tank air pump w/ those 1 way valves?  Do I know how much air I need based off the color and if so, what color am I looking for?  In the past I had some weak acid and it turned teal blue but this stuff is staying bright lime green.
Also, yes, I did heat it up.  I was using a small 'tupperware' dish in a larger one that was filled w/ water ~120-140F.
When you say a bit slower, I assume you mean than the first batch and not my slow 45min marathon etch?
Bob
> Harvey
> >Thanks in advance,
> >Bob
Re: [Homebrew_PCBs] Re: Kepping Your Etchant Good? Multiple Use? Muriatic Acid / H2O2
2012-10-28 by Russell Shaw
On 28/10/12 16:38, dubob4432 wrote:
> Thanks.
Using my FeCl bubble etcher which has degenerated to a copper-chloride etcher,
doing a double-sided 1oz copper pcb is well done by 12 minutes, without heating.
Add a bit of HCl acid every few months. The FeCl/water ratio started at 1:1 a
few years ago. Keep the tank covered when not in use.
Will do, anybody know if the storage vessel needs to be dark?  Does sunlight dilute it?
Bob
> > Thanks.
Thanks, off to order a fish tank pump...
> Sunlight doesn't affect FeCl or CuCl. Don't let it stay warm unless it's covered
> well to prevent evaporation. Peroxide etchant stuff may go off quicker when in
> sunlight and warmed.
On Sun, 28 Oct 2012 05:38:53 -0000, you wrote:
>Thanks.
Yes, exactly that.  You want a plastic air stone, not a porous stone,
because the acid attacks that stone.  Not sure about this plastic, but
there are kinds of plastic (nylon, for instance) that are not as acid
resistant as you'd like.  Avoid stainless steel, too.
A decent air pump should be fine.  More air is better than not.  It
does several things, one is oxygenate the etchant, the other is keep
it moving so fresh etchant hits the boards.
The bright lime green sounds a bit odd, because most of my stuff is
blue/green, not lime.  The ratio I used was 4x peroxide (the 30 vol or
3% stuff) to 1x muriatic acid (38%, IIRC).  The opaque olive green is
when it needs more HCL, I think.   Adding peroxide to the dark green
stuff turned it blue, as I remember.
120 is fine, but perhaps a little warm.  140 is too hot.  I'd go 100
to 120, warm to the touch, but not burning.
I also use a fish tank heater, sealed.  You have to get ones that you
can misadjust to over temperature, they have dials on top that you can
keep on turning.
I get about 20 minute etches at the end of a batch, where the etchant
is oxygenated a lot, and the etchant is hot.  The first batch can take
almost that 45 minutes, so if that is too long for people, then I need
to tweak the process a little.  I'm looking at building a new etchant
tank anyway, but the distribution of the bubbles is fairly important,
and makes a substantial difference in the etching speed.
Harvey
>Bob
>> Harvey
>> >Thanks in advance,
>> >Bob
2012-10-28 by kabowers@NorthState.net
>>Thanks.
I made a bubbler for use in a plastic storage bottle. Started with 12" of 1/2"
CPVC tubing and two CPVC end caps. I first drilled a bunch of #60 holes
around the tubing from 5/8" to 1 1/2" from one end. I then pressed a
cap on the perforated end; no glue. My WalMart air pump had dual outputs,
so I used a "T" to feed both into the pipe by drilling a hole in the other cap
just large enough to press the "T" into after applying universal PVC/CPVC
glue. I then pressed the cap onto the open end of the pipe. No glue on
the cap to pipe joint here either. Two pieces of plastic tubing between the
"T" and the air pump and it was ready to go.
I can stick the thing into a bottle and get lots of bubbles. I've used this
for over two years with no sign of deteriation.
Keith Bowers WB4LSJ- Thomasville, NC
>Interesting.  Do you have a pic online we can have a look at?
>Mitch.
I'll try to come up with one in the next day or two.
2012-11-13 by smilingcat90254
You can purify 3% (drugstore grade of H2O2) by placing the H2O2 solution in a dark plastic bottle. No grease or other organic except the plastic and definitely not in a stainless steel or other steel vessel and FREEZE IT IN A DEEP FREEZER. When the solution has formed ice, remove the ice and the remaining liquid is concentrated H2O2. And you can use the concentrated H2O2 into your Acid bath without diluting the concentration of HCl (well not as much as if you had used 3% H2O2).
Word of WARNING!! concentrated H2O2 can be very unstable so do NOT make a big batch! Make only what you need for the acid bath. Do not allow it to come in contact with oil, flesh, stainless steel. Steel act as a catalyst to decompose H2O2 in highly exothermic (heat producing) decomposition of H2O2 into water and oxygen. The reaction can runaway and cause the container to explode from too much pressure build up from oxygen generation. H2O2 does not explode chemically.
Far as storage of acid bath with H2O2. keep it away from sunlight, halogen light or any light with blue and UV in it. Light will promote decomposition of H2O2.
---- on slightly different subject using vinegar ----
Vinegar is acetic acid. Grocery store vinegar is only about 4% acetic acid. If you want to concentrate and use it for etching copper I think you can do this... To concentrate vinegar you can also freeze the vinegar and remove the ice. It's relatively easy to get 40% concentration of acetic acid if I remember correctly.
Be safe!
Ms. Smilingcat
Thank you for your note Mitch
> Thanks in advance,
> Bob
2012-11-13 by dubob4432
Thanks for the info, on the hunt for a dark plastic bottle.
Bob
--- In Homebrew_PCBs@yahoogroups.com, "smilingcat90254" <smilingcat@...> wrote:
> Be safe!
> Ms. Smilingcat
> > Thanks in advance,
> > Bob
2012-11-14 by Kevin Byrne
At the hard ware store today. TSP solution off the shelf. Thanks to your E-Mails bathe in the future. Best Kevin
Sent: Tuesday, November 13, 2012 1:25 PM
Subject: [Homebrew_PCBs] Re: Kepping Your Etchant Good?  Multiple Use?  Muriatic Acid / H2O2
Bob
> Be safe!
> Ms. Smilingcat
> > Thanks in advance,
> > Bob
2012-11-18 by dubob4432
since hair dye uses hydrogen peroxide in 10%, 20% and 30% strengths, would this be a better way to go?
reason i ask is because the only freezer i have is a regular freezer/fridge unit and not sure if it would get cool enough?
bob
> Be safe!
> Ms. Smilingcat
> > Thanks in advance,
> > Bob
2012-11-18 by Norm
> bob
Beauty shop H2O2 is 10  - 20  - 30 VOLUME, not %.  It works out to 6  -
9  - 12 %
Norm
Thanks for the clarification :)
Bob
> > bob
> 9  - 12 %
> Norm
2012-11-18 by John Anhalt
@dubob4432
The percentages you give for hydrogen peroxide used to bleach hair are called "volume strength".  Volume strength refers to the volume of oxygen evolved from a volume of solution.  That is, one mL of 20 (volume strength) will evolve 20 mL of oxygen.  That is not the same as wt%, which is the standard way chemists and others measure its concentrations.  It is all explained in Wikipedia.
Here is a table showing volume strengths and wt%:
http://www.h2o2.com/technical-library/physical-chemical-properties/physical-properties/default.aspx?pid=13&name=Equivalent-Values-of-Concentration
John
  Sent: Saturday, November 17, 2012 8:10 PM
  bob
  > Be safe!
  > Ms. Smilingcat
  > > Thanks in advance,
  > > Bob
2012-11-18 by Dave Sage
FYI
If you are using the Muriatic Acid /H2O2 formulation correctly you never
need to add more H2O2. Somewhere along the way the original intent of this
formulation has been lost here. You all should go back and read the original
post on making Cupric Chloride. You start with acid and H2O2 and saturate it
with copper. From there you just have to bubble air into it for an extended
period of time to turn it into Cupric Chloride and it's ready to go. You are
defeating the purpose by using the acid H2O2 for one time use. Do your
etching and then return it to a container for more bubbling in the off time
to convert it to Cupric Chloride again. Lasts forever. In fact you actually
gain slightly more volume of etchant after each use. Cupric Chloride is used
in industry now since it is re-usable "more green - no pun intended - since
Cupric Chloride is green"
Sage
Not quite that simple.  You do have to add HCl occasionally to provide chloride ion.
When I switched from ferric chloride, I started with copper (II) chloride and have been using that bath for several years.  I use air for regeneration; although, peroxide will work too, but common 3% will dilute the bath.  Ozone will also work and is quicker than air, but requires a generator.  Common household air fresheners don't produce enough ozone to be very helpful, though.
John
  Sent: Sunday, November 18, 2012 9:58 AM
  FYI
  Sage
2012-11-18 by AlienRelics
Adam Seychall's page is back. There is also a PDF backup of it in the Files section under Etchants.
http://members.optusnet.com.au/~eseychell/PCB/etching_CuCl/
All the information you'll ever need for keeping your CuCl etchant going.
There is more information in that Files folder, including instructions on proportions of drugstore H2O2 with hardware store 30% HCl muriatic acid.
http://tech.groups.yahoo.com/group/Homebrew_PCBs/files/Etchants/
Steve Greenfield AE7HD
> John
>   ----- Original Message -----
>   From: Dave Sage
>   FYI
>   Sage
Yes, keep in mind that the rocket backpack used in the 007 movie uses nothing but concentrated hydrogen peroxide. It hits a mesh of metal and instantly turns to H20, O2, and an incredible amount of heat.
> Be safe!
> Ms. Smilingcat
2012-11-18 by Harvey White
The metal is platinum, IIRC.
Good reason to avoid using platinum tools when you make PC
boards......
Harvey
>> Be safe!
>> Ms. Smilingcat
2012-11-18 by smilingcat90254
to be on a safe side, don't let any kind of metal come into contact with H2O2.
You can also get reasonable concentration by just putting into your regular freezer and not into deep freezer.
Generally, it is better to distill in steps. And be extremely careful with the concentrated solution. It can burn you on contact, it can cause blindness if the solution splashes into your eye.
More I think about it, I think its better if it is stored in the dark brown bottle it comes in and store in a fridge or freezer. Activation energy for its decomposition is pretty low. So even at room temperature the stuff is decomposing into water and oxygen.
Activated etchant, nuriatic acid + H2O2, should not be stored where food is stored nor partially used etching solution. BIG NO NO!!
> boards......
> Harvey
> >--- In Homebrew_PCBs@yahoogroups.com, "smilingcat90254" <smilingcat@> wrote:
> >> Be safe!
> >> Ms. Smilingcat
