Homebrew PCBs
Need More Heat - GBC Laminator (pics included)
2012-11-10 by dubob4432
Hello,
I need to get a bit more heat out of this GBC Creative Laminator.  Very close but probably another 10-20C would be what I need (ability to adjust would be EXCELLENT). How do I go about accomplishing my goal.  Has the Daewoo KSD602 thermostat - http://www.daewood.com.hk/en/productdetail.asp?id=122&sortid=210&pid=.
http://www.bnkz.com/GBC/Laminator001.jpg
http://www.bnkz.com/GBC/Laminator002.jpg
http://www.bnkz.com/GBC/Laminator003.jpg
http://www.bnkz.com/GBC/Laminator004.jpg
http://www.bnkz.com/GBC/Laminator005.jpg
Any assistance would be greatly appreciated.  I did not remove the power board area but have no problems going into that area - I am so close, I just feel the toner is not being 'baked' onto the copper clad quite enough to stand up to the time in the muriatic acid / H2O2 w/ the bubbler and small, important pieces are coming off.  Doing .5mm pitch smd work.
Thanks in advance,
Bob
Re: Need More Heat - GBC Laminator (pics included)
2012-11-11 by tda7000
The easiest way would probably be just to replace the thermostat with a higher temperature one, like the process here:
http://ultrakeet.com.au/write-ups/fritzHack
and here:
http://ultrakeet.com.au/write-ups/superFuserV2
Or if you wanted an adjustable controller, something like these:
http://kmprojects.wordpress.com/2011/01/29/pic-lam/
or
http://screwdecaf.cx/yatc.html
or
http://www.delorie.com/electronics/laminator/
or just search Google for "open source temperature controller" or such.
--- In Homebrew_PCBs@yahoogroups.com, "dubob4432" <dubob4432@...> wrote:
> Hello,
> Thanks in advance,
> Bob
2012-11-11 by RDHeiliger
Insulating the snap switch (temperature switch) from the aluminum heater bars will raise the temperature. On mine the snap switch is held on by a screw, put a piece of bare circuit board or cardboard on each side of the tab on the switch. Experiment with thickness till you get good results.
RD
2012-11-11 by smilingcat90254
I've been using a thermal press with direct temperature read out on the aluminum heat plate. I can set temperature and pressure on the thermal press.
HP toner will melt around 110C. might be even lower around 105C or so. At lower temperature, the toner may have a harder time fusing onto the copper.
Copper needs to be ultra clean. I use 0000 steel wool. followed by scrubbing with TSP solution using scotch brite (green) pad, then rinse with water then cleaned with isopropyl alcohol. Wear glove through out the process. Laminate image immediately to reduce contaminating the copper surface and oxidation. Someone thought oxidizing in the etcher for few second made the image adhere better. Haven't tried so have no comment about oxidizing surface.
I really do need reliable repeatability down to 6/6 mil. I may go to photoresist. Found a source at around $3.00/ft^2. Not cheap but claims to get images down to 1/1 mil. Stuff is called puretch. Distributor is an artist out of South Carolina. Think and Tinker has similar material not as high performance at around ??$2.00?? per square feet but you need to spend over $100.00 for the minimum quantity.
Result I'm getting out of photopaper of all different kinds, specially formulated toner transfer paper is just not cutting it for me.
Anyway, temperature set it around 105C to about 130C. At 115C and above the plastic coating on the photopaper will decompose and will turn into hard white film.
> Hello,
> Thanks in advance,
> Bob
RE: [Homebrew_PCBs] Re: Need More Heat - GBC Laminator (pics included)
2012-11-11 by Jeff Heiss
There is photoresist available on ebay.  DuPont Riston costs $2.20 per
square foot for example (item number 170919606000).  An average board size
for me is 6"x3" double sided which is $0.50 in photoresist.
On the topic of etching, has anyone used electroetching?  Does it compare
with ferric chloride or muriatic acid?
Jeff
  _____
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com]
On Behalf Of smilingcat90254
Sent: Sunday, November 11, 2012 1:05 PM
Subject: [Homebrew_PCBs] Re: Need More Heat - GBC Laminator (pics included)
press.
white film.
<mailto:Homebrew_PCBs%40yahoogroups.com> , "dubob4432" <dubob4432@...>
wrote:
> Hello,
<http://www.daewood.com.hk/en/productdetail.asp?id=122&sortid=210&pid=.>
&sortid=210&pid=.
> Thanks in advance,
> Bob
2012-11-11 by John
Perhaps a little fiberglass insulation between the sensor & heat source?
> Hello,
work.
> Thanks in advance,
> Bob
2012-11-12 by dubob4432
Is that this - http://www.bnkz.com/GBC/Laminator004.jpg
In there is one of these - http://www.daewood.com.hk/en/productdetail.asp?id=126&sortid=237&pid=
> RD
Maybe I am using too much heat - I prep as you recommend and once done, I put the piece in water and let the paper come off.  Once it dries, the traces are black but slowly turn white as if paper is adhered to the paper.
Possibly I am going the wrong way?  Maybe just 1-2 passes through the laminator and not 10?
Thoughts?
--- In Homebrew_PCBs@yahoogroups.com, "smilingcat90254" <smilingcat@...> wrote:
> --- In Homebrew_PCBs@yahoogroups.com, "dubob4432" <dubob4432@> wrote:
> > Hello,
> > Thanks in advance,
> > Bob
Re: [Homebrew_PCBs] Re: Need More Heat - GBC Laminator (pics included)
2012-11-12 by Spencer
Mine do that also, after I remove the paper when it is done soaking. I rub my fingers over the traces underneath running water just to get rid of the paper residue. Your tracks should stay on the board as it takes a lot to remove the toner.
Sent: Monday, November 12, 2012 12:27 AM
Thoughts?
> > Hello,
> > Thanks in advance,
> > Bob
Maybe I will remove the paper like you describe and then heat up the toner w/ hot air?
>  From: dubob4432 <dubob4432@...>
> Â
> Thoughts?
> --- In Homebrew_PCBs@yahoogroups.com, "smilingcat90254" <smilingcat@> wrote:
> > > Hello,
> > > Thanks in advance,
> > > Bob
2012-11-12 by DJ Delorie
The trick to toner transfer is to get all the toner hot enough to become
"sticky" but not hot enough to actually melt.  There's a small range of
temperatures for each specific toner; the closer you can get to (and
hold) this temperature, the better.
I did a few experiments with transparencies...
	http://www.delorie.com/pcb/transparencies/
The copper needs to be clean enough to let the toner stick *and* needs
to be "roughed up" with an appropriate grit sandpaper so the toner can
get a mechanical bond with the copper.
2012-11-12 by Mitch Davis
On Mon, Nov 12, 2012 at 2:04 AM, smilingcat90254
Interesting post Mr. Cat.  Some people say don't use steel wool, as
traces of iron will stay embedded in the pores of the copper.  That
can lead to corrosion due to galvanic action.  However those dark
green 3M pot scourers work really well :-)
Mitch.
2012-11-12 by tda7000
I get the white residue when using magazine paper. You won't get it if you use proper transfer paper.
It doesn't make a difference to the board, just looks weird.
> Thoughts?
> > > Hello,
> > > Thanks in advance,
> > > Bob
2012-11-12 by Kevin Byrne
What is the thickness of the copper clad boards of this project talk as I have been studying a different GBC Laminator of pulsar pro product number. I need info due to this Lamanitor found on E-Bay is about 1/2 price or less. Thanks Kevin
Sent: Monday, November 12, 2012 1:57 AM
> Â
> Thoughts?
> > > Hello,
> > > Thanks in advance,
> > > Bob
What is the ingredients of TSP Solution as I need that to go to drug store? Thanks Kevin
Sent: Monday, November 12, 2012 5:08 AM
> Thoughts?
> > > Hello,
> > > Thanks in advance,
> > > Bob
Re: [Homebrew_PCBs] Re: TSP
2012-11-12 by Roland F. Harriston
*From WIKI:
Trisodium phosphate* (TSP, E339) is a cleaning agent, food additive,
stain remover and degreaser <http://en.wikipedia.org/wiki/Degreaser>. It
is a white, granular or crystalline solid, highly soluble in water
producing an alkaline solution. The item of commerce is often partially
hydrated and may range from anhydrous trisodium phosphate, Na_3 PO_4 ,
to the dodecahydrate, Na <http://en.wikipedia.org/wiki/Sodium>_3 P
<http://en.wikipedia.org/wiki/Phosphorus>O
<http://en.wikipedia.org/wiki/Oxygen>_4 �12H_2 O. Most often found in
white powder form, it can also be called *trisodium orthophosphate* or
just plain *sodium phosphate*. Trisodium phosphate was at one time
extensively used in formulations for a wide variety of consumer grade
soaps and detergents, but ecological problems have largely ended that
practice, at least in the western world. Substitutes are not as
effective, but the raw chemical can be bought in bulk to add to other
detergents.^ <http://en.wikipedia.org/wiki/Trisodium_phosphate#cite_note-2>
Roland F. Harriston, P.D.
2012-11-12 by Andrew Volk
I found TSP at my local hardware store (Ace Hardware in my case) in a small plastic tub.
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com] On Behalf Of Kevin Byrne
Sent: Monday, November 12, 2012 7:16 AM
Subject: Re: [Homebrew_PCBs] Re: Need More Heat - GBC Laminator (pics included)
From: tda7000 <Tda7000@... <mailto:Tda7000%40xtra.co.nz> >
To: Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com>
--- In Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com> , "dubob4432" <dubob4432@...> wrote:
> Thoughts?
> --- In Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com> , "smilingcat90254" <smilingcat@> wrote:
> > --- In Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com> , "dubob4432" <dubob4432@> wrote:
> > > Hello,
> > > I need to get a bit more heat out of this GBC Creative Laminator. Very close but probably another 10-20C would be what I need (ability to adjust would be EXCELLENT). How do I go about accomplishing my goal. Has the Daewoo KSD602 thermostat - http://www.daewood.com.hk/en/productdetail.asp?id=122 <http://www.daewood.com.hk/en/productdetail.asp?id=122&sortid=210&pid=.> &sortid=210&pid=.
> > > Thanks in advance,
> > > Bob
2012-11-12 by smilingcat90254
TSP (Trisodium phosphate) can be had at Home Depot, Lowes or any paint shop. It is a very strong degreaser with good wetting characteristics. only need about teaspoon to about a tablespoon per quart of water. Quart is about a litre off hand. I'll weigh out TSP in grams later and will advise. It is also alkaline so it doesn't corrode the copper.
The thin white film left over after cleaning is a very thin plastic layer with lower MP than the clear film on the photopaper you are removing. Photopaper has a very thin plastic layer at the top. Underneath is a thicker clear plastic layer with higher MP. Underneath is the paper backing. Backside has another layer of opaque matt plastic layer. There may be more to it but this is what I found out so far.
from top to bottom:
very thin plastic with low MP  (top layer)
thick clear plastic with higher MP
paper
matt white plastic with even higher MP (bottom layer or backside)
Ms. Smilingcat
>  From: tda7000 <Tda7000@...>
> Â
> > Thoughts?
> > > > Hello,
> > > > Thanks in advance,
> > > > Bob
Thank you for the info and quick reply. I will print it for studys. Best Kevin
Sent: Monday, November 12, 2012 10:44 AM
Subject: Re: [Homebrew_PCBs] Re: TSP
*From WIKI:
<http://en.wikipedia.org/wiki/Oxygen>_4 ·12H_2 O. Most often found in
Found TSP on E-Bay, add for Lowes  and add for technical grade thru E-Bay. Have letter scale and could use exact weight in grams if possible. I have .94mm or .034inch board stock. What is the size of GPC Creative board stock.
Max thickness? Thanks Kevin.
Sent: Monday, November 12, 2012 1:08 PM
from top to bottom:
paper
Ms. Smilingcat
> Â
> > Thoughts?
> > > > Hello,
> > > > Thanks in advance,
> > > > Bob
2012-11-13 by bebx2000
I always thought the copper needed to be super clean, but now I just use Scotch-Brite to give the surface a little tooth and CitraSolv concentrate. CitraSolv is a cleaner, but it is also a solvent for toner (and flux residue). Just go over the copper surface in different directions with the Scotch-Brite and then clean the residue off with CitraSolv (concentrate) until the wipe-off is clear. I usually give the surface a final wipe and let it evaporate. The CitraSolv residue acts as an adhesion promoter for the toner.
Baxter
2012-11-13 by DJ Delorie
"bebx2000" <bebx2000@...> writes:
> concentrate.
You need the copper to be super *oil free* - i.e. keep your grubby
fingerprints off it!  You normally don't need to make the copper shiny
or remove the oxides (in a CuCl bath, the oxides etch faster than copper
anyway).  Shiny is actually bad if you're using transparencies, where
mechanical grip on the copper is key to keeping the toner there.
