Homebrew PCBs
first step into convection etching
2012-11-23 by Rick Sparber
Although I have done analog circuit design for 50 years, I'm a relative
newbie when it comes to circuit board etching.  Furthermore, my last
chemistry class was in 1967. Here is my first step into convection etching.
http://rick.sparber.org/electronics/ce.pdf
How do I improve this process? I understand that bubbling air into the acid
will speed it up but won't that spoil the laminar flow?
Thanks in advance,
Rick
Re: [Homebrew_PCBs] first step into convection etching
2012-11-23 by Donald H Locker
Laminar flow is not good for etching. Turbulence is desirable to enhance the exchange of spent and fresh etchant at the surface of the board. In pure laminar flow, there is no exchange between layers of fluid; the streamlines don't interact except through friction and there is no flow perpendicular to the surface. For etching to work, the etchant near the surface must be replaced by fresh solution from the bulk, so agitation and turbulence are used.
HTH,
Donald.
*Plain Text* email -- it's an accessibility issue
()  no proprietary attachments; no html mail
/\  ascii ribbon campaign - <www.asciiribbon.org>
> From: "Rick Sparber" <rgsparber@...>
> To: "Homebrew PCBs" <Homebrew_PCBs@yahoogroups.com>
> Sent: Friday, November 23, 2012 7:15:53 AM
> Subject: [Homebrew_PCBs] first step into convection etching
> relative
> etching.
> acid
> Thanks in advance,
> Rick
> Be sure to visit the group home and check for new Links, Files, and
> Photos:
RE: [Homebrew_PCBs] first step into convection etching
I wish more of the discussion from the electronics_101 BBS had been done over here. Some felt that laminar flow had a lot of advantages although was slower. I'm just the newbie sitting on the sidelines.
I see that the etch tank sold by Circuit Specialists has an air pump plus the board is held vertically. I've seen it in action and it is certainly fast.
Rick
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com] On Behalf Of Donald H Locker
Sent: Friday, November 23, 2012 5:49 AM
To: Homebrew PCBs
Subject: Re: [Homebrew_PCBs] first step into convection etching
HTH,
Donald.
()  no proprietary attachments; no html mail /\  ascii ribbon campaign - <www.asciiribbon.org>
> Subject: [Homebrew_PCBs] first step into convection etching Although I
> have done analog circuit design for 50 years, I'm a relative newbie
> when it comes to circuit board etching. Furthermore, my last chemistry
> acid will speed it up but won't that spoil the laminar flow?
> Thanks in advance,
> Rick
> Photos:
Be sure to visit the group home and check for new Links, Files, and Photos:
2012-11-23 by John Anhalt
@Rick Sparber
Your last picture is most revealing.
Apparently, you are faced with a difficult etching process as described in the Electronics_101 thread you sent.  I would recommend getting a good etching process first, then tackle that harder problem.  I suspect that is what you are doing.
When I etch a PCB, I do not seek convection etching as a goal; although, I am sure there is some of that going on.
1)  Why do you want convection and laminar flow?  Considering the chemistry, even without considering the interaction of oxygen and oxidized forms of copper, I would think that turbulent flow would be better.  With laminar flow, there will always be that surface layer of etchant in contact with the copper that is not well mixed.
2)  Your experiment shows "edge effect," i.e., the edges etch faster than the center.   I am sure there are several reasons for that to occur, but certainly having laminar flow across the board will make it worse.  I do my boards either copper on top or inverted with continuos magnetic stirring and heated to 60 to 70°C.  Copper down goes faster.  I made some glass trivets from 3 mm glass stirring rods to rest my boards on.  Depending on the severity of any edge effect, I remove the board and use a sponge with etchant to speed up the central etching.  With 1/2 oz and 1 oz copper, that is generally not necessary to do.
3)   You don't say what your resist is. If it is a photoresist, underdevelopment and/or underexposure (for positive resist)can lead to difficulty etching.  With my photoresist (Injectorall), it is easy to tell when development is complete.  When properly developed, a water rinse will show wetting of all exposed copper.  If in doubt, a quick dip in ferric chloride will show if there are any areas that are to be etched that still have remaining resist on them.  If so, it can be rinsed and put back in the developer for more time.  That final picture, however, shows far more scratches and defects than I have ever seen with photoresist.  That is not meant as criticism, but only as an observation that something is wrong.   Now, if you are using the toner-transfer method, then such defects may be more common.  I don't use toner transfer and can't comment on that further on that.
My recommendations for ferric chloride would be to:
1)  Increase your etching temperature to 60°C
2)  Improve stirring and/or agitation.  Remember, of the etchants available to hobbyists, ferric chloride provides the least undercutting and best edges.  You may get better results, if you dilute concentrated ferric chloride a little bit -- say 10 to 20% with water (i.e., 1 part water to 4 to 9 parts concentrated ferric chloride).  The Edinburgh etch (http://www.lawrence.co.uk/acatalog/etch.pdf), which adds citric acid to the ferric chloride has been reported to give sharper etching.  I have tried it, but found the difference for what I do was negligible.  It might be worth a try for you, though.
Regards, John
  Sent: Friday, November 23, 2012 7:15 AM
  Thanks in advance,
  Rick
2012-11-25 by Rick Sparber
John,
I think I have a good process now. I made 4 1" square samples to verify
repeatability. The root cause of my problem was inadequate exposure time.
What a difference that made! Warming up the ferric chloride did help shave a
few minutes off the etching time but it was still less than 10 minutes. I
was getting etching times over 30 minutes when my exposure time was way off.
I'll put the rest of my comments in line.
Thanks!
Rick
___________________________________________
On Behalf Of John Anhalt
Sent: Friday, November 23, 2012 6:12 AM
@Rick Sparber
>>>> what do you see that you call difficult?
>>> someone recommended it so I have it a try. One of my 4 samples used it
but I found the sloshing method was just as good and didn't require floats
on the board.
>>> So the glass rods don't block etching?
difficulty etching.
>>> you nailed it. I am using pre-treated photo resist board and did have
the exposure time way off. My process now has the UV bulb 2.5" from the
board and I expose for 8 minutes. Then after about 15 seconds in the
developer, I see clean copper. Etching takes less than 10 minutes.
exposed copper.
>>> great test!
>>> I had developed that board the previous day and had it kicking around
the bench. The resist was damaged but since it was a test board, no loss.
>>> your guidance is most welcome!
>>> The warning on the bottle says to not get above 140F. I'm leery of going
that hot.
>>> I found that rocking the translucent plastic container with a strong
light under it works well to monitor progress. Now that I have the exposure
right, I'm happy with the etch time.
Regards, John
etching.
acid
  Thanks in advance,
  Rick
