From: David Sent: Saturday, November 24, 2012 16:14
If I understand you correctly, is it only Pdf files you have? this being the
case, I dont think there is any software that can make gerber files from
pdf's, send me the images silkscreens and the schematics with dimensions and
specifics for any components you will be using, I will see if I can make the
gerber files for you.
David
--- In Homebrew_PCBs@yahoogroups.com
<mailto:Homebrew_PCBs%40yahoogroups.com> , Andrew Hakman <andrew.hakman@...>
wrote:
> If you already have the layout done, most software will export to a
gerber.
> The only ones that I'm aware of that won't are the ones that are tied to
> one PCB manufacturer, such as expressPCB, but then you can just get it
made
> with them directly, and there's no need to export to gerber. I would
> suggest googling for "[whatever layout program you used] export gerber"
and
> I'm sure you'll find some simple instructions.
> On Fri, Nov 23, 2012 at 1:00 PM, trvrlock <trevor@...>wrote:
> > I have two small pcb designs that I need converted to gerbers
> > Is there anyone that does that.
> > I have the copper tracks and silk in pdf files
> > all firms I have asked to make the pcb,s
> > say they can not do without gerber file
> > so as a model railway fan prefer not to have to learn
> > all about making these files
> > will/would pay for convertion to gerber file
> > trevor
