Homebrew PCBs
Cupric Chloride Fumes
2012-12-01 by bruce_fleming
Hi all. I am new to this forum and am working on etching. The ferric chloride has been tried a few times. While searching for better ways to etch using ferric chloride I came across an Instructables on how to etch with muriatic acid so you do not have throw out your solution when saturated with copper.
When I tried the Cupric Chloride the I made sure the area was well ventilated but I believe the cold slowed down the etching process so much that the traces also were partially destroyed.
Has anybody found a fume hood that will handle cupric chloride? Etching outside or with a window open is not a good option in the winter.
Re: [Homebrew_PCBs] Cupric Chloride Fumes
2012-12-02 by Russell Shaw
You only need less than 5% HCl acid in the etchant. There should be minimal fumes.
2012-12-02 by John Anhalt
"etch with muriatic acid so you do not have throw out your solution when saturated with copper."
Are you talking about the peroxide + muriatic acid etchant or the one that is based initially on copper (II) chloride?  While it is true that the former eventually becomes the latter, at the outset, they are not the same.  The peroxide etchant is more aggressive.  I tried using the peroxide method with a photoresist, and it eat the resist that I use (Injectorall).  That might be part of your problem.
Of the three etchants you mention, ferric chloride is the easiest to use and gives the best results in terms of minimal undercutting, a broad endpoint, and fine lines.  I suggest using that until you get a method working.  When I switched to cupric chloride, the biggest change I noticed was at the end point.  It was easier to over etch the PCB.
John
  Sent: Saturday, December 01, 2012 4:16 PM
  Subject: [Homebrew_PCBs] Cupric Chloride Fumes
Re: Cupric Chloride Fumes
2012-12-02 by bruce_fleming
The HCl solution I used is only 3% and the fumes were not too bad. I do not want things in the basement to rust or get that "brown" film from the fumes. Just as important is the effect it can have on the human body.
I might end up using ferric chloride in the colder months and cupric chloride again when it gets warmer when I can do that outside.
The etching solution is made from muriatic acid (1 part) added to HCl (2 parts). Here is the link on Instructables:
http://www.instructables.com/id/Stop-using-Ferric-Chloride-etchant!--A-better-etc/#step1
I had a lot of problems with the ferric chloride while the least problems with undercutting with the new muriatic acid + HCl (becomes cupric chloride) solution. With the ferric chloride, the pcb had thin traces which I think are attributed to undercutting. The cupric chloride did eat away some of the traces but not as much as the ferric chloride.
There were some other factors with the ferric chloride that I can work on eliminating. One of them would be to heat the solution to working temperature varying from 45 degrees Celsius to 55 degrees Celsius and when ready, then place the board in the etchant.
> John
>   ----- Original Message -----
>   From: bruce_fleming
Re: [Homebrew_PCBs] Re: Cupric Chloride Fumes
"I had a lot of problems with the ferric chloride while the least problems with undercutting with the new muriatic acid + HCl (becomes cupric chloride) solution. "
Your chemistry is very confusing.  Muriatic acid is HCl.  The concentrations from your recipe also do not make sense.  I am sure there is a simple explanation, such as some typos.
John
  Sent: Sunday, December 02, 2012 10:23 AM
  Subject: [Homebrew_PCBs] Re: Cupric Chloride Fumes
  > John
  > From: bruce_fleming
2012-12-03 by Russell Shaw
HCl is naturally occuring in the 'body'.
RE: [Homebrew_PCBs] Re: Cupric Chloride Fumes
2012-12-03 by Tony Smith
> fumes.
...so it's perfectly ok to breathe, drink & bathe in then?  Neat!
Just the thing to clean out that stubborn bit of grease under your
fingernails, or add a bit more kick to your evening cocktail.
Tony
> the
>> fumes.
> ...so it's perfectly ok to breathe, drink&  bathe in then?  Neat!
Ok if it's not real concentrated.
The stuff in the hardware shop is "reasonably" concentrated, but i used to
de-rust steel with it diluted 3:1. Gloves weren't needed, but a cut would sting
a bit (like lemon juice or vinegar).
The green enviro wussies would use surgical gloves just to pick their nose;)
> >>> from
> > the
> >> fumes.
de-
sting a bit
nose;)
So not-very-concentrated diluted-down-lots HCL is perfectly ok.  Got it.
I'll pour some on my cornflakes now.
Tony
2012-12-03 by bruce_fleming
Thank you for drawing my attention to the fact that HCl and muriatic acid are the same thing. If I had not been in a rush and thought about the words of hydrogen peroxide I would have determined the HCl thing by process of elimination. It does pay to pay attention to what you are asking.
> John
>   From: bruce_fleming
>   > John
>   > From: bruce_fleming
2012-12-03 by Leon Heller
It's often called Spirits of Salt in UK hardware shops, they won't
recognise hydrochloric acid or muriatic acid.
Leon
Leon Heller
G1HSM
2012-12-04 by smilingcat90254
Joking and kidding is fine for something but not something very toxic. Not sure if there is any antidote if you drink the stuff.
Drink the stuff and you will DIE! here are two MSDS
http://www.sciencelab.com/msds.php?msdsId=9923592
http://www.ch.ntu.edu.tw/~genchem99/msds/exp22/CuCl2.pdf
something to think about and how much safety precaution you want to use or just not use it!!
Wikipedia says something little different but like any transitional metal salt, I'll be extra careful in handling. Always wear gloves.
> Tony
2012-12-04 by dubob4432
anybody have a link to something to store this in?  currently in a clear glass jar but I understand sunlight weakens it?  I can't find any smaller dark glass jars w/out metal anywhere.  meh
bob
--- In Homebrew_PCBs@yahoogroups.com, "smilingcat90254" <smilingcat@...> wrote:
> > Tony
2012-12-04 by John Anhalt
" but I understand sunlight weakens it? "
Where do you hear such stuff?  Sunlight, if anything, helps keep it oxidized.  The copper isn't going anywhere.  I store mine either in its all glass etching tank or Tupperware plastic.
Stay away from Bakelite lids with paper liners; although, if it has a Teflon or PE liner, it probably is OK.
John
  Sent: Tuesday, December 04, 2012 1:25 PM
  bob
  > > Tony
2012-12-04 by lists
In article <k9lf6s+cd68@...>,
Cut up a black plastic bin bag and secure round your existing jar?
Stuart Winsor
Only plain text for emails
http://www.asciiribbon.org
2012-12-04 by Pict
Something like this should workŠ
http://www.bhphotovideo.com/bnh/controller/home?O=NavBar&A=getItemDetail&Q=&
sku=335945&is=REG&si=rev#costumerReview
Any photographic developer bottle should work. Most photo stores that still
cater for the film market should have them. Developer bottles usually are
conecertina so you can force all the air out but they would still work for
etchant being opaque.
John
Reply-To:  <Homebrew_PCBs@yahoogroups.com>
Date:  Tue, 04 Dec 2012 18:25:32 -0000
bob
<mailto:Homebrew_PCBs%40yahoogroups.com> , "smilingcat90254"
just not use it!!
> --- In Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com>
> > Tony
2012-12-04 by Pict
Maybe thinking that light would probably help decompose the peroxide content
if any?
Date:  Tue, 4 Dec 2012 14:01:34 -0500
Subject:  Re: [Homebrew_PCBs] Re: Cupric Chloride Fumes
John
 To: Homebrew_PCBs@yahoogroups.com <mailto:Homebrew_PCBs%40yahoogroups.com>
bob
<mailto:Homebrew_PCBs%40yahoogroups.com> , "Tony Smith" <ajsmith1968@>
 > > Tony
