Homebrew PCBs
PCB-Milling
PCB-Milling
2013-02-24 by Hans
Hi ,
I make sometimes a pcb as hobby . I use the pcb program sprintlayout , convert the file to dxf and with a cam program to g-code . My milling machine is a bridgeport cnc with a highspeedspindle . It works well .
When there are two copperlines with a very small distance then is between this lines a small copperline that can become loose and can make a short circuit . Does some knows a programm that automaticly combine two lines ?
Thanks
Hans
Re: [Homebrew_PCBs] PCB-Milling
2013-02-24 by Cristian
>combine two lines ?
If so, after doing the design in C1 or C2, switch to O (outline) and
draw  false outlines between the initial C1 or C2 tracks.
Use only the O output further.
Cristian
2013-02-25 by HaHoLang@...
Hi Christian ,
what kind of software do you use ?
Thanks
Hans
2013-02-25 by Cristian
At 11:57 AM 25-02-13, you wrote:
>Hi Christian ,
SprintLayout 5.0 of Abacom/Germany.
Cristian
