UV LED differences
2013-02-26 by James
Hi all, does anybody know much about UV LEDs and the differences between them? I have a batch of UV leds from ebay, and a batch of UV leds from another chinese wholesaler. The ebay ones were sold as 395-400 nm, viewing angle 20-25 degrees, 30mA, 3.2-3.8v The other ones were sold as 395-400 nm, 3.2-3.4v, 20mA, viewing angle 30 degrees. The ebay ones stated 2000 mcd, but I wouldn't believe that (nor is it useful for UV to state an mcd which is about visible spectrum), the other ones claim 150-200 mcd which seems a reasonable claim for the visible output. I had some time ago made an exposure box out of the ebay ones, and killed some over time (was pushing a bit much current through them I think, being they are tightly packed the heat was building up pretty good), so I replaced 1 complete column and a couple of other failing ones with some of the chinese wholesaler batch, in the slideshow here I've tried to capture the difference... http://www.flickr.com/photos/93638530@N08/sets/72157632863117628/show/ The two batches in the off state are both water clear, 5mm, identical appearance, but as I hope you can see they differ REMARKABLY in their visible light in the on state - naturally visible light isn't too important here anyway, but such a big difference surprised me enough to think I'd been sold fakes. The ebay ones look "like you would expect UV leds to look" they emit a little violet light, the other ones emit a quite strong light blue, cyan, sort of colour. At an angle, the ebay ones in the on state are largely visibly transparent, the other ones are opaque with visible colour. I did a quick test exposure (with dry film) and interestingly the wholesaler ones exposed MORE strongly, that is, the exposed areas were noticeably darker, so definitely they are putting out a decent amount of UV in at least a wavelength suitable to expose dry film, but I'm curious as to why there would be such a large difference visibly. So, anybody able to share any insights into this phenomenon? --- James Sleeman [Non-text portions of this message have been removed]
