Homebrew PCBs
[Homebrew_PCBs] Vinyl Cutter Conversion
2013-02-27 by Mark Lerman
Hello all,
We've visited this before - the Silhouette cameo vinyl cutter that
Mike used to directly cut traces in copperclad. Unfortunately, I was
not able to get his technique to work very well, but now I'd like to
use the machine to "print" traces using heat cured electrically
conductive one-part epoxy. What I'd like to do is convert the cutter
to a plotter. As it is now, the vinyl cutter uses its proprietary
software to cut (or sketch, using a pen holder) around the edges of
the traces, which is fine (sort of) for isolating the traces, but not
what I want here. What I'd really like is to use it like a plotter,
drawing the traces down the middle of the designed trace. The width
of the trace could be controlled by using different needles on the
dispenser or controlling the air pressure.
I'm willing to rip out the electronics and make my own stepper
drivers, but I'd like to know what software I would use to run the
converted machine, presumably using some form of HPGL. Does anyone
know how this would be done? I really don't want to reinvent the
wheel here, but I'm willing to do a bit of soldering if someone could
point me in a reasonable direction. Thanks for any help or insight!
Mark
Re: [Homebrew_PCBs] Vinyl Cutter Conversion
2013-02-27 by Cristian
Mark, why not output the HPGL in 'multiline' format, with fixed pen width?
Kcam4 is free and good for controlling a standard stepper driver.
Cristian
I'll look into it - thanks. I know very little about the specifics of
HPGL, but it sounds like the way to go, here. The physical stepper
driver is very easy since these are very small steppers. I'll have to
pull the pcb, but I wouldn't be surprised if I could hack into the
pcb and use the on board stepper drivers.
Mark
>Cristian
>Be sure to visit the group home and check for new Links, Files, and Photos:
>http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
Re: Vinyl Cutter Conversion
2013-02-27 by jeremy youngs
i would have to strongly suggest linuxcnc.org
as an active user this is the best supported most configureable
machine controller out there and its free :)
jeremy youngs
2013-03-03 by tda7000
Unfortunately it doesn't look like it's free anymore.
> Cristian
Re: [Homebrew_PCBs] Re: Vinyl Cutter Conversion
2013-03-03 by Mark Lerman
No, but it isn't that expensive, either. Another (free) alternative,
as has been mentioned before is Linux and linuxcnc. You would have to
become familiar with Linux if you haven't used it (I haven't), but it
should be pretty easy if you are only using it for one program.
I just ordered a 3 axis controller on ebay ($42 USD including
shipping), though I think I could use the parts from the on-board
controller to make my own controller, especially if I use the parallel port.
Mark
> > Cristian
2013-03-03 by Harvey White
As a note culled from the CAD/CAM group.  Please be aware that the
chip/chipset used in the boards can be a limiting factor.  Some chips
cannot be pushed all that close to their limits.  Almost all (if not
every one) of the chips/chipsets do NOT tolerate removing the load
(stepper) from the chip with power on.  It generally blows the output
in the chip (requiring either replacement of the entire chip or the
driver for that channel, if separate).
You need to be aware that connectors used to run the board to the
stepper need to be as robust (read: lock in place) as possible, and
the wires need to be reasonably flexible (wiring from the connection
to the stepper will flex, so you don't want that to break).
That said, I think, (without any kind of data to the contrary), that
these boards will work well within their limits (NO overvoltage, NO
overcurrent, NO disconnects).  The only boards/drivers that I know
about that are as rugged as possible are made by gecko, and are the V
series (vampire.... Mariss has a sense of humor).  Even then, the
warranty is outstanding.
What I use (because I'm thoroughly cheap and had the chips) is an
L297/L298 chipset with jumper settings for parameters and optical
isolators for step and direction.  I haven't blown any of them, *but*
I have been very careful with what I've been doing.  Roughly 35 volts
and about 2.5 amps maximum, no behavior compensation, so not the best
in the design.
I'm doing a parallel port if I mess with a controlling PC, a custom
program (to be written) using an XMEGA otherwise, and for a full blown
solution, an FPGA hardware pulse generator (it works, but I need to
see how good it is, implemented in the simulator).
Harvey
>Mark
2013-03-04 by Mark Lerman
Thanks for the input, Harvey. This little vinyl cutter uses very
small steppers (1.7" dia x .6" thick) that draw about 500ma at 24
volts. The original  board uses BD6395 driver ICs which are rated to
1.2 A at 28 volts; The board I bought will do at least 2.5 amps, so
it shouldn't be a problem.
Mark
>in the design.
>Harvey
> >Mark
